Topic: Key checker (Read 9342 times) previous topic - next topic
Key checker
Hi all,
I've searched through a few of the main foo plugin sites but can't find what I'm after.
I'm looking for a plugin that will query the track for the key it was produced in. Quite like what mixmeister does when you load tracks into that.
Mark
Key checker
A plugin for this would be nice, but since the technology behind are quite complicated, 3rd party apps would probably yield better results.
Mixed In Key is considered one of the most accurate for this task. However, it only supports mp3 and wav - No lossless support!
Key checker
Its definitely a start - Thank you
Key checker
After I get foo_vorbisstream tweaked to be just how I want it, I intend to try my hand at BPM/key analysis.
Key checker
Don't suppose there are any freeware apps like this around?
I don't really want to pay $58 for just analysing the harmonic signal.
Key checker
The CLAM Annotator (CLAM = C++ Library for Audio and Music) is capable of extracting the sequence of chords. In the linked download a commandline "ChordExtractor.exe" is included. However, it is probably a bit of overkill for you. A self-written Perl function can be found below for extracting a sequence of chord keys (A, A#, B, C, C#, ...) and modes (Major, Minor, ...) from the program's output.
use XML::Simple;
sub extract_chords {
my $filename = shift;
my $chordPath = '"C:/Program Files/CLAM/Annotator/bin/ChordExtractor.exe"';
system($chordPath." \"".$filename."\" > clam.log 2>&1"); # run CLAM ChordExtractor
my $ci = XMLin($filename.".pool") or die "Error reading result file for $filename!\n";
unlink $filename.".pool";
my @choords = @{$ci->{ScopePool}->{ExtractedChord}->{AttributePool}->{Root}->{Enumerated}};
my @mode = @{$ci->{ScopePool}->{ExtractedChord}->{AttributePool}->{Mode}->{Enumerated}};
print FO "\"@choords\",\"@mode\"\n";
Key checker
That would be AWESOME!!! Which library would you rely on? I know that "Mixed in Key" are using zplane tONaRT and aufTAKT.
Key checker
I've got a couple ideas for my own algorithms which I will probably try. If I fail as miserably as I do sometimes, I might just try those libraries you mentioned. CLAM looks good, but it's pure GPL, so no foobar2000.
Key checker
FYI - Mixed In Key hasn't used tONaRT for about two years now, they've got their own patent pending system.
Chad P
Key checker
My bad, I didn't really follow development after FLAC/lossless support was promised a long time ago, but never implemented...
Key checker
Any news on this, Canar?
