Richard Clark $10,000 Amplifier Challenge
Reply #2 – 2014-09-29 16:57:00
I read through the test conditions and I thought it was strange that EQ was used to make the other amps sound the same. Why is that strange? Audiophiles have been claiming for ages that each amplifier has its own specific sound that is not related to "simple" measurements. Frequency response is the most simple of them all. If you cannot distinguish an expensive audiophile amp because you made the other amp's frequency response equally messed up, then you've shown that you probably paid a lot of money for non-defeatable, non-configurable, i.e. fixed tone-"controls". Linear distortion is also trivial to fix. Yes, a proper amp shouldn't exhibit large frequency response deviations (from flat) to begin with, and I'd steer clear of any SS amp that shows a bass or treble boost, but without the EQ I could just take some amp with fixed bass boost compared to a proper (flat) one and win the money 100%. You have to limit the parameters one way or another, because there are always exceptions. He also could've just dismissed any amp with too large deviations from flat as "broken". Nonlinear distortion is not as easily fixed, so amps that don't fit within his defined margins are simply dismissed.Richard Clarke's experiments prove TWO things: there are amplifiers that people can easily and reliably distinguish between aurally in a preliminary round (this is a prerequisite for being allowed to do the challenge at his home where you can win the money, and is actually a proof AGAINST what the proponents always claim), No. The preliminary round uses less trials and is sloppy. It's just a check to see if the person is serious .. If it proves anything, then that without proper level-matching - surprise, surprise - people hear differences. Said people usually then proclaim that the amps sound different and that they have golden ears. This is some sort of self-delusion that is incredibly persistent within audio.
