Topic: foo_title, new version for 0.9 (Read 282242 times) previous topic - next topic
Reply #75
First of all, thank you for this great plugin!
Some suggestions:
  • Turn the plugin on and off in the preferences
  • Refresh the skin list, on opening the foo_title preferences page
  • Make the window invisible to mouse clicks (WS_EX_TRANSPARENT)
  • Or let the window disappear if the mouse is over the window
Thank you!
Reply #76
**sorry, just needed a restart ^^' **
One addition:
Could this be made part of the right click menu of the taskbar icon for moviewatching etc.?
Anyway, great plugin
Reply #77
As for the not working always on top problem: Could you please try some other program that has always on top (like winamp or you IM client) in the same situation ? I need to know whether it's a problem in windows (which is quite possible  or in the .NET framework
Reply #78
well, it works in foo_prettypop and also in YAPP in miranda-im.
Reply #79
This is a plugin I have been wanting for a while now.  I'm curious if .net 2.0 is required or if it could be compiled against the 1.1 framework?  I use foobar at work but do .net 1.1 development.  I'd like to avoid installing the 2.0 framework until I start developing against that (I know, they should co-exist just fine).  If 2.0 isn't strictly required, I would really appreciate a 1.1 binary.
Reply #80
I'm using the new C++/CLI syntax for the wrapper and a few C# 2.0 features in foo_title itself, so it can't be easily compiled against .NET Framework 1.1.
But, at least on my computer, .NET FW 1.1 and 2.0 coexist with no problems (and VS 2003 and VS 2005 as well).
Reply #81
New 0.6 version released. Changelog:
    *  support for bold/italic text, textlayer rewritten
    * fixed a bug that prevented foo_title from loading when foobar wasn't started from it's directory (fooManagedWrapper)
    * added window position storing
    * fixed album art not showing when stored in a directory with unicode characters
    * skins list refreshes when property page is displayed
    * fixed fill-images overlapping it's client rect
    * removed icon from alt-tab
    * option to show/hide/only when foobar is minimized
    * using pure WinAPI to make it stay on top (not sure if it hels though)
    * the text is now updating also on stop and pause
    * support for defaultText - shown when nothing is playing at the moment
    * now it's possible to set the align of scrolling-text when the text is shorter than layer's size
    * support for changing opacity - in normal and mouseover state
    * other bugfixes
These changes are backward compatible, so all your current skins will work in 0.6 as well.
The rest of feature requests may be implemented in future versions
Reply #82
great update! thanks a lot & keep the good job!
Reply #83
Ok, i figured out why it doesn't stay always on top.  It's because I have it over my taskbar and when I click to bring up my start menu or something, it disappears behind the taskbar.  Is there any way to fix this or is this a limitation of windows?
Reply #84
It's a limitation of windows. The only thing I could do is to keep setting it to top every 500ms or so, but that's really an ugly hack.
Reply #85
yeah it's ok, i just decided to put foo_title somewhere else.  it's a really awesome plugin and i like how i can do mouse activation in a way.  and i have a feature request, can it be possible to activate this plugin when a song is changed for example be able to change the opacity when the foobar status is changed?
Reply #86
it could be very good, a bit like a foo_pretty pop up but more powerfull.
Reply #87
thanks Quiark for the unicode folder name support
Reply #88
Is there any way to assign masstagger script to foo_title button layer?
I tried specify "Tagging/Scripts/Rating: +1" as <action> but it don't work for me...
Also, if there would be an option to specify text label for button (w/o picture) - it wolud be great.
Reply #89
I'll see  Probably yes
That does not work, because it's in the context menu and in a submenu. I'll probably need to enhance support for menus.
You should be able to make a label by creating a text layer in the button layer.
Reply #90
This command depends on the context - which song is selected and so on, I don't understand why would you want to execute it from foo_title. And what song should it operate on ? On the currently playing one ?
Reply #91
This command depends on the context - which song is selected and so on, I don't understand why would you want to execute it from foo_title. And what song should it operate on ? On the currently playing one?
It's simple - if I want to set/change rating of song I must open main foobar window and find it in playlist. And since I can control playback without it - it's very inconvenient in case of rating.
And yes - target of script must be currently playing song.
Reply #92
nice plugin! just installed it. though next clean windows install, i dont think i'll be installing .net.
also a few ideas that might be interesting. maybe the ability to click thru (except the buttons) with the left mouse, and drag with the right.
there is one problem i ran into. when right aligning scrolling-text, the end of the text would be up to 10 pixels away from where it should be depending on the string.. other than that, it seems to work well..
i've also modified the included "another" skin. grab it here another.blue.mod.rar.
changes include:
- a slightly darker shade of blue
- changed the play button to play/pause.
- swapped the position of the stop and play button
- added a rating field
- added remaining time
- changed fonts and sizes
- cleaned up text positions and alignment
Reply #93
thanks for the plugin!  really trying to get it to work, as this was one of the four things holding me back from making the switch from winamp (MM keyboard buttons, ipod support, minimize to tray, windowshade).
here are three screens of the errors i've gotten:
http://img439.imageshack.us/img439/3274/onegq2.jpg
http://img439.imageshack.us/img439/2071/twomq5.jpg
http://img399.imageshack.us/img399/5007/threeyr1.jpg
i've read through the documentation and i know i have the files in the correct places.  i'm not sure what's up.  any help would be awesome!
thanks!
Reply #94
Can you make please option, to show this plugin when song start playing and hide it after few seconds? Like prettypopup?
Reply #95
I hope this answers your question.
Reply #96
dmber: Could you please make a screenshot of the first error with "Details" shown ? (and I recommend using PNG or GIF, JPG is for photos only  You can as well copy & paste the contents.
Reply #97
Is there a way to display an 'ellipsized' text when the text is longer than its layer ?
(e.g: very long text --> very long te...)
I found a workaround based on the number of letters ($iflonger / $cut) but, alll the characters have not the same width in pixels...
Anyway, thanks for this amazing tool!
Reply #98
I'd suggest using a fixed-widt font for that, personaly.
There's a storm on the loose, there's sirens in my head...
Reply #99
Thankyou for this plugin, I really like it.
I have one feature request: would it be possible that on mouse over, there can be a delay before the component appears?
I have normal opacity completely transparent and on mouse over completely opaque. It'd be really nice if the component appeared when i wanted it to, as opposed to when my mouse goes somewhere near where it is positioned.
Thanks again.
