Topic: best settings for 128kbps VBR (Read 17417 times) previous topic - next topic
I'm trying to squeeze the best possible quality out of a 128kbps mp3
so far i've been using "-V 5 -h" with Lame 3.96.1
i wasn't sure about the -h, should i use it? and is there anything else i should add?
These will be streaming off a webserver, that's why i need them to be 128kbps (or close to that since i prefer VBR)
For ~ 128kbps VBR, the general consensus has been to use "-V5 --athaa-sensitivity 1" with LAME 3.95.1 or higher. The ATH adjustment was found to result in less warbling/phasing, but may raise the bitrate a little bit.
The -h is redundant and therefore not needed.
thanks
the reason i was worrying about using "-h" which is the same as -q2, cause without it, the encoder uses -q3 instead
so are you saying theres no difference between the two?
So "-V5 --athaa-sensitivity 1" is better than "--preset 128 --athaa-sensitivity 1"?
I don't know it at all. I would use "-V5 --athaa-sensitivity 1" but I don't know.
/edit: So at those bitrates is it better to use VBR instead ABR? I just don't know.
portable: 128 kbps cbr AAC
local: -7 FLAC
thanks
[a href="index.php?act=findpost&pid=265601"][{POST_SNAPBACK}][/a]
From about 3.94 or 3.95 onward, the default "high-quality" setting is -q3, not -q2. As far as I know, there is not yet been any evidence to show that lower -q values bring higher quality, so just stick with the default. -q0-q2 also take longer to encode, which isn't worth it considering the aformentioned lack of evidence.
[a href="index.php?act=findpost&pid=265607"][{POST_SNAPBACK}][/a]
personally, I think that there is no need for CBR/ABR anymore because of the VBR presets aka -V2 etc. Anyway, -V5 should be better...
thanks for the help
but i was also wondering...does the prefrence of "--athaa-sensitivity 1" apply to all bitrates or just a certain range?
Hello
I just finished encoding about 150 songs with the "-V5 --athaa-sensitivity 1"
(3.96.1 ) setting.  I'm happy. I found this preferable to "--alt-preset 128"  (3.90.3)  for my needs.  I also noticed that when I  tried  "-V4 --athaa-sensitivity 1"  that the file sizes jumped up quite a bit.  I too am not sure when the "--athaa-sensitivity 1" should be used
There is a thread discussing some of the tests recently done  with VBR and lower bit rate encoding. I would suggest reading it as well.
Regards
Randy
AFAIK q2 from 3.90.3 = q3 from 3.96.1. Just a shift in numbers.
thanks for the help
You don't need to use it at -V4 or higher quality levels. Look [a href="http://www.hydrogenaudio.org/forums/index.php?showtopic=21012&view=findpost&p=205737]here[/url] for the explanation by Gabriel. You can also read that entire thread if you want more information on how we got to this.
And for the people that didn't know this already: "-V5 --athaa-sensitivity 1" was also used for Roberto's latest 128kbps test, and it performed quite well (roughly on par with iTunes AAC):
http://www.rjamorim.com/test/multiformat128/results.html
Over thinking, over analyzing separates the body from the mind.
offtopic from my original post....but is 89db the best setting for mp3gain?
cause everything sounds really quiet
edit: nm answered my own question by searching around
Though for lower bitrates there still seems to be some issues with VBR:
http://www.hydrogenaudio.org/forums/index....ndpost&p=264990
...i was also wondering...does the prefrence of "--athaa-sensitivity 1" apply to all bitrates or just a certain range?
Good question... Anybody have an answer?
Are you kidding ?
Think of streaming...
that has been already answered in this thread (just a few posts above yours)...
[a href="index.php?act=findpost&pid=265745"][{POST_SNAPBACK}][/a]
Are you kidding ?
[a href="index.php?act=findpost&pid=266623"][{POST_SNAPBACK}][/a]
who uses mp3 for streaming? And what's wrong with a vbr stream?
Everybody.
Almost
You can stream not only a music, video+sound too.
The main problem is that it's vbr...
D'OH!
Thanks, Jojo...
My apologies for the redundancy...
I use mp3 for streaming. What is the problem with that???
It suits all my needs plus works flawlessly (unlike other streams I tested)...
VBR streaming works ok for me...
EDIT: typo
With fixed channel width, if bitrate exceeds it you will have a glitch...
[a href="index.php?act=findpost&pid=266635"][{POST_SNAPBACK}][/a]
Of course this totally depends on the underlying protocol. Most audio streaming now is done via TCP, which handles the flow control so VBR is not a problem. Of course TCP is not the ideal multimedia protocol, but that doesn't stop people from using it (its easy to use and is network-friendly).
also, talking about 'glitches' in mp3 streams...at what bitrate are those streams usually done? I mean, even if that happens it's not that some one listens to some 320kbps stream...I'd say streams mostly use 128kbps or less...however, I can't think of any web radio or something that streams in mp3...and as freakngoat said, there's a work around to that...
Overall, I think that just a vbr mode in LAME would have many more advantages than disadvantages...
[a href="index.php?act=findpost&pid=266643"][{POST_SNAPBACK}][/a]
Yes most streaming is done at lower bitrates for obvious reasons. VBR creates a variety of problems. One of the problems with using VBR in multimedia streaming is that if you are not using any flow control mechanism, and your bitrate suddenly jumps up above your maximum bandwidth, those frames will be lost (this has a profound effect in MPEG video streaming, since the most likely frame to be dropped is the I-frame, and thus all the frames received up until the next I-frame will be junk). Other problems arise when using a packet resend strategy (like TCP). Peaks and valleys in birates are not network friendly with multiple receivers, since more packets are likely to be dropped at a peak, and so more people will request a resend at once, choking off bandwidth for everyone. Luckily TCP has a congestion avoidance scheme as well, otherwise a "broadcast storm" can occur, where everyone is requesting a resend, but nobody backs off. If this occurs effective playback becomes impossible.
What it comes down to is, VBR creates non-network friendly traffic with multiple receivers.
EDIT: BTW there are lots of radio stations streaming in MP3. Also in my previous post, I should have said VBR is "possible," as I've just described the problems associated with it.
does these VBR drawbacks occur only with mp3 VBR or with other VBR streamable codecs (ogg, aac etc. etc.)?
anyway. i stream mp3 vbr from my home pc to my work pc and never heard any glitch... perhaps I'm just lucky.
Sure, wide channel, one transmitter - one receiver: no problems most of the time...
I think, freakngoat described the problem with vbr very well:
It couldn't be done better with one sentence
EDIT:
That's the nature of vbr, not the codec...
