Topic: FLACCL: CUDA-enabled FLAC encoder by Gregory S. Chudov (prev. FlaCuda) (Read 479805 times) previous topic - next topic
Reply #300
c:\Downloads\FLACCL_0.4\FLACCL>CUETools.FLACCL.cmd.exe --verify test.wav
FLACCL#0.4, Copyright © 2010 Gregory S. Chudov.
This is free software under the GNU GPLv3+ license; There is NO WARRANTY, to
the extent permitted by law. <http://www.gnu.org/licenses/> for details.
Filename  : test.wav
File Info : 44100kHz; 2 channel; 16 bit; 00:09:40.1600000
Error    : unsupported residual coding
Catalyst 12.1 Preview.
Reply #301
Hey guys, I've been having MD5 signature mismatches with FlacCL on one of my computers with a nVidia GTX 570 card.  A second computer, with a slower GT 430 card, works fine.  Even with the signature mismatches, files (appear) to be fine, but I'm guessing something will be wrong, somewhere.
I wanted to do some troubleshooting on my own so that it doesn't sound like I'm just punting this out there.
Hardware = Core i7 950, nVidia GTX 570, 12GB RAM
Troubleshooting steps:
FlacCL Level 11 - MD5 signature mismatch (4+ attempts, works ~10% of the time) (Speed = 235x)
FlacCL Level 10 - MD5 signature mismatch (Speed = 254x)
FlacCL Level 9 - No problems (try #1) / MD5 signature mismatch (try #2) (Speed = 281x)
FlacCL Level 8 - MD5 signature mismatch (Speed = 325x)
libFlake Level 11 - No problems (2 attempts) (Speed = 31x)
flake Level 12 - No problems (Speed = 13x)
FlacCL Level 11 - separate computer w/older nVidia card - no problems (Speed = 60x)
File sizes don't even match for a full CD, but they are fairly close. (within a few kilobytes)
Next step - Turned Verify on for FlacCL Level 11 (Speed = 136x)
Got an "Exception: validation failed: iFrame=24603, ch=0"  - it will be in a different spot each time.  Sometimes it works.
Next step - Tried Changing DoRice, GroupSize, and TaskSize.  No consistent results.  Worked a few times, failed most of the time.
Next step - Change GPUOnly to False, and changed threads to 4, left Verify On (Speed = 308x)
Haven't gotten this to fail.  I've done 10 encodes of the same CD now.  flac -t works every time.
Next step - GPUOnly back to True, but leave threads at 4. Fails sometimes.  GPUOnly=False seems to be required for it to work for me.
So, how much should I worry about this?  GPU Bad?  Bug in CUETools with this card?  Why would it work when I split the load with the GPU and the CPU?  I've tried multiple nVidia drivers, including the latest.
I have no problems leaving this the way it is, certainly if it works - it's faster than GPU only.  If there is any other debugging information you want me to collect, I'd be happy to do that.
agressiv
Reply #302
I use FlacCl more or less from day 1 on, first with a GTX260 and now a GTX560Ti. I tried to provoke encoding errors with insane overclocking on the GPU and its RAM but couldn´t create a single one with reaching clockspeeds no game would run.
So my guess is you may have another stability problem with your CPU/Mainboard/GPU combination. You may try some stability test overclockers use.
There only were 2 songs i found since Gregory created these GPU encoders that made problems but i don´t remember the exact errorcode back then. These were outright fixed by Gregory a while back.
Reply #303
c:\CUETools>CUETools.FLACCL.cmd.exe --verify test.wav
Filename  : test.wav
AMD Catalyst 12.3.
Reply #304
Does this happen on some specific input file, or does it happen on lots of files?
CUETools 2.1.6
Reply #305
c:\CUETools>CUETools.FLACCL.cmd.exe --verify "c:\_Music\Stefano Di Battista - Vo
lare\new\01. Prima Di Partire.wav"
Filename  : c:\_Music\Stefano Di Battista - Volare\new\01. Prima Di Partire.wav
File Info : 44100kHz; 2 channel; 16 bit; 00:05:32.5330000
lare\new\02. Blues For Michel.wav"
Filename  : c:\_Music\Stefano Di Battista - Volare\new\02. Blues For Michel.wav
File Info : 44100kHz; 2 channel; 16 bit; 00:03:55.8400000
lare\new\03. Widows Walk.wav"
Filename  : c:\_Music\Stefano Di Battista - Volare\new\03. Widows Walk.wav
File Info : 44100kHz; 2 channel; 16 bit; 00:09:22.0270000
c:\CUETools>flac -t "c:\_Music\Stefano Di Battista - Volare\new\02. Blues For Mi
chel.flac"
flac 1.2.1, Copyright © 2000,2001,2002,2003,2004,2005,2006,2007  Josh Coalson
flac comes with ABSOLUTELY NO WARRANTY.  This is free software, and you are
welcome to redistribute it under certain conditions.  Type `flac' for details.
02. Blues For Michel.flac: *** Got error code 0:FLAC__STREAM_DECODER_ERROR_STATU
S_LOST_SYNC
S_LOST_SYNC
S_LOST_SYNC
S_LOST_SYNC
S_LOST_SYNC
S_LOST_SYNC
S_LOST_SYNC
S_LOST_SYNC
S_LOST_SYNC
S_LOST_SYNC
S_LOST_SYNC
S_LOST_SYNC
02. Blues For Michel.flac: ERROR while decoding data
                          state = FLAC__STREAM_DECODER_READ_FRAME
AudioTester:
3 files scanned in 0.12 seconds
3 files failed
C:\_Music\Stefano Di Battista - Volare\new\01. Prima Di Partire.flac   (LOST_SYNC @ 0m 00s)
C:\_Music\Stefano Di Battista - Volare\new\02. Blues For Michel.flac   (LOST_SYNC @ 0m 00s)
C:\_Music\Stefano Di Battista - Volare\new\03. Widows Walk.flac   (LOST_SYNC @ 0m 00s)
0 files passed
Reply #306
I'm also getting the same error. It happens on pretty much every file I throw at it (although some worked fine, I think), ever since I switched from an NVidia GPU to an ATI one (although I used FlaCuda with the NVidia one, so that's probably not of much help). Oh, and it works just fine if I tell it to encode on the CPU only, instead of the GPU, though, of course, much slower.
Reply #307
Please tell which exactly GPU do you use. And if possible, driver version as well.
CUETools 2.1.6
Reply #308
Right, I meant to include that, but must've forgotten.
It's a PowerColor Radeon HD 6850. The current driver is the latest one, 8.961.0.0, the one that came with the latest release just a few days back. Catalyst 12.4, to be exact.
But it wasn't working with at least 3 previous releases of the drivers as well, if it helps you. Don't know if it worked with earlier releases, as I never tried the earlier ones.
Reply #309
CUETools 2.1.6
Reply #310
I am using Radeon HD 5870.
As I mentioned earlier, on my Nvidia ION with the latest Nvidia driver FLACCL doesn't work, too.
But it works with 267.54 driver.
Reply #311
Having the same "Error : unsupported residual coding" in CueTools. Running an ATI 6950 with Catalyst 12.4 and the latest OpenCL SDK
Reply #313
Very interesting. Thanks a lot!
I'm not entirely surprised that SLI configurations and dual chip cards are often slower than single chip, not all algorithms benefit from this, especially without special fine-tuning.
But it's surprising how Kepler seems slower than Fermi. In theory it should have outperformed AMD. I will have to investigate what's going on here.
CUETools 2.1.6
Reply #314
On my PCIe 3.0 configuration SLI with two GTX 680 cards was only 2% slower than encoding with one card inside. The difference between SLI on and off when two cards were in the machine was about 0.1%.
Reply #315
I hope your investigation brings us working FLACCL back :-)
Reply #317
Intel® Core™ i7-3770, 8Gb DDRIII-1333, Win7 HP x64
CUETools.FLACCL.cmd.exe -o nul --cpu-threads 8 --opencl-type CPU --opencl-platform "Intel® OpenCL" test.wav
-0 = 1552.67
-1 = 1402.22
-2 = 1308.66
-3 = 808.33
-4 = 645.38
-5 = 460.92
-6 = 654.20
-7 = 482.51
-8 = 278.95
-9 = 322.66
-10 = 186.75
-11 = 132.91
Reply #318
I updated today my ION (notebook) video drivers to the latest NVIDIA version (301.42 x64).
FLACCL test failed again but due to other reasons:
- test 1: only 6 of 9 tracks encoded
- test 2: only 8 of 9 tracks encoded
- audiotester showed 0 errors in encoded tracks in both cases
- cuetools showed every time following error:
flaclib encoded all tracks without any problem.
Reply #319
flaclib = libflac :-)
Reply #320
-0 = 1552.67
-1 = 1402.22
-2 = 1308.66
-3 = 808.33
-4 = 645.38
-5 = 460.92
-6 = 654.20
-7 = 482.51
-8 = 278.95
-9 = 322.66
-10 = 186.75
-11 = 132.91
The speed is so high for real use
Can You run the same configuration but with  --cpu-threads 1 or gpu only? It will give a rough idea what to expect from mobile CPUs.
Thank You.
Reply #321
Actually, it won't. --cpu-threads option's name is probably a bit confusing in case of --opencl-type CPU.
There are two types of threads - actual opencl threads, which run on GPU(s) in case of --opencl-type GPU, and run on CPU(s) in cases of --opencl-type CPU.
Number of those threads is not controlled by --cpu-threads option, which controls the number of threads of second type - control threads, that schedule opencl work.
So i should probably rename --cpu-threads to --control-threads and maybe introduce a new option --cpu-cores, to control number of CPU cores used by opencl tasks in case of --opencl-type CPU.
CUETools 2.1.6
Reply #322
CUETools.FLACCL.cmd.exe -o nul --opencl-type GPU test.wav
-0 = 375.28
-1 = 764.13
-2 = 1038.91
-3 = 314.01
-4 = 345.24
-5 = 303.78
-6 = 346.60
-7 = 304.84
-8 = 177.76
-9 = 120.67
-10 = 85.10
-11 = 66.12
Reply #323
Got gass.cuda.cudaexception on i7-2600k/GTX570 with 304.48 drivers. GTX280 worked fine.
Reply #324
Any update on the "Error : unsupported residual coding" error? Perhaps there are some test builds you'd like us (those who experience the error) to run?
