Topic: Audibility of Jitter (Read 118516 times) previous topic - next topic
Reply #50
How many of the references that went into this page meet TOS 8?
2?
[1] yes- and it is quite well-known.
OK
[2] yes- done by Dolby.
OK
[3] objective measurements only- no need to meet TOS 8.
IOW, it sheds no light on audibility
[4] yes- and we have discussed it on this thread. Also there is an addendum from the authors.
The first link is broken, the second link's contents sheds no light on audibility
[5] not referenced above- no need to meet TOS 8.
[6] no- written in 1970, well before David Clark's test in 1982.
IOW, it sheds no light on audibility.
Reply #52
If you just stop being Asianophobic.. nah I'm just kidding. I totally understand your concern. Most of the listening test-related studies from asia do not really follow the proper DBT(BS.1116-1) procedure, thus end up being null.
[3] The paper merely discusses that jitter components in high-end systems are usually less than 1ns. Again, no need to shed light on audiblity.
[4] The Link works fine- an addendum from the authors works too. Another Link FYI.
[5] Again, not even mentioned in the presentation itself. Not sure if it meets the TOS 8. (wish I could obtain a copy)
[6] Certainly outdated. As you've said, does not meet TOS 8.
Except with [6], I still see the excerption as a good outline.
Reply #54
2?
No need for sarcasm.
I have the paper right here before me, and it says quite clearly that the thresholds of audibility that it plots out were "calculated"
That makes the count of TOS8-compliant papers exactly 2, no?
(no sarcasm intended) ;-)
Reply #55
I have not read everything but here is a test I did with my Focusrite ISA828 unit with ADC, RME Multiface II and a Black Lion Audio microclock mkII.
The FLAC files are here and just line them up in a sequencer application and/or just listen.
http://www.interfearingsounds.com/blandat/..._comparison.zip
For the lazy ones, here are the files phase flipped so that you can hear what's been nulled and not:
http://www.interfearingsounds.com/blandat/...se_flipped.flac
This has all been taken from my old topic over at TapeOP messageboard. http://messageboard.tapeop.com/viewtopic.php?t=70170
Reply #56
What's your opinion on the difference in audible difference in my last post? What makes the behaviour? Regards.
Reply #59
Any possible audible differences are effectively masked by a gratuitous warbled tone.
Are you serious?
If  *you* are serious, you'll post a log of your ABX tests based on these files, perhaps using FOOBAR2000 as your comparison software. ;-)
Reply #60
Are you serious?
Why I wrote the last sentence is because of "A gratuitous warbled tone" and "POSSIBLE audible difference" (capitalized two words), like if you didn't really care that much.
Reply #61
Your 05 file is a fraction of a sample earlier than your 04 file - i.e. they are not perfectly in sync. Hence they won't null out. It's somewhat difficult to correct for sub-sample delays - you'd have to add a sub-sample delay to file 05 to make it null properly. However, adding that sub-sample delay will typically change the audio a little, so it's tricky to rely on null tests in this case. It could be done, with the caveat that you'd have to ignore any differences that were due to the sub-sample delay, and hope no actual differences were hidden by this. It would be hard to convince people of the validity of a positive or negative result - especially in comparison with the convincing -100dB result you posted.
But there is some good news - the sync is good enough to run an ABX test, especially on any ABX test tool that doesn't try to implement (or lets you disable) perfect seamless switching.
Without trying an ABX test of the two files and posting your results, you have not demonstrated an audible difference. Expectation bias is too powerful a thing for anyone on this board to believe anyone who says "I hear a difference" without a passed ABX test to prove the fact.
Reply #62
2Bdecided: Interesting about subsamples. So there is actually space that is smaller than the audio file's actual time limit (sample rate)?
Reply #63
File 2 and 3 null out almost perfectly. Amplification of that difference by 50 and then another 20 dB* produces a beautiful example of a quiet muffled song, drowning in a thick ocean of noise. Can we reject any chance of audible difference here right off the bat?
Also, I'm not sure why there are 4 files on offer, but only 2 inverted files. I didn't use the inverted ones. Was I supposed to compare 2/3 and 4/5?
4 and 5 have a tiny subsample difference, so the diff is a complete piece of music, but without the bass. I don't have the qualifications to explain why the bass region vanishes.
The warbled tone extends rather far into the sample, and I suppose it was a basis for Arnold to dismiss the samples immediately. I couldn't ABX any of it, in any case.
How did you know 5 is earlier than 4? Better tools?
*) Audacity apparently doesn't allow more than 50dB amplification in a single step.
Reply #64
There always is. Samples are always separated by a finite amount of time, and anything that is finite can be made smaller.
Adjusting files in increments of less than a sample can be done. What you do is upsample the file to a sample rate by an amount that is as high as you need to make it, or at least is as high as you can practically make it, do the adjustment on the upsampled file, and then downsample the file back to the original sample rate.
This will scare the %$#!! out of some people, but if you have good resampling software, it can have useful results.
Reply #65
Agreed. File synch is generally good enough if its within 1/100th of a second.
I don't think the OP did this consciously, but by not first doing his own test, he's effectively telling us that he doesn't have time to do things right, but figures that we have nothing better to do than to spend the necessary time doing his homework for him.
I don't think he actually claimed an audible difference, thereby escaping the TOS 8 issue.
At any rate I fell for his ruse, tried to ABX the files and found the problem that I identified, which he now seems to want to pick a fight with me about. ;-)
He is either very ignorant or very arrogant. ;-)
I'm about ready to do the good old plonk thing. Should I spend the time to see where his IP address leads?  ;-)
Reply #66
Taking the delta between samples a fixed time interval apart acts as a low-pass filter with a 6 dB roll off, until the period approaches the time delta. It then acts as a notch filter when the period and the time delta are equal.
Reply #67
The sample rate sets a frequency limit, not a time limit. The waveform at times "between" sample points is very well defined. However, frequency components at or above half the sample rate can't exist in a baseband sampled system.
Reply #68
He might be confused. I couldn't follow your argument at all.
Reply #69
Is this right? You're describing the comb filter you get when you add suitably delayed signals together. However, when you subtract delayed signals, I think the basic response is a high pass filter - and if the delay is increased to give a comb filter effect, the lowest frequencies are always attenuated - i.e. DC is always in a notch filter.
(don't take my word for this - far too sleep deprived to be 100% sure of anything today  )
Reply #70
To illustrate the importance of sub-sample accuracy in null-tests I made a new version with an 80 millisample delay manually switching in and out. It makes it easy to hear how much better the null is with the delay. I still can't get it as good as the RME though. It would be interesting to do some lab measurements with the device running on internal and external clock.
null-test flac
null-test wav
Reply #71
Oops...I meant high pass.
BTW, if the period is twice the delay then the signal is amplified 6 dB.
Reply #72
Even after listening to his samples?
Reply #73
Yes. They consist of a bell, then a guitar, and a bloke singing. Fine for the purposes of investigating the audibility of jitter or any other DAC error in a signal consisting of a bell, then a guitar, and a bloke singing
Of course I agree about the necessity of ABXing, and the fact it's a possible audible problem.
