Topic: Close a program with Scheduler? (Read 1878 times) previous topic - next topic
Can I make the Scheduler close a program, e.g. Thunderbird at a special time?
Win 7, Win Vista, newest stable foobar & EAC & Cue-Tools
Using the "Launch application" action, which is basically running a system command prompt, you have some options.
Ideally, if the program has available a command line switch to close it, then you can just "launch" the program EXE with the termination switch (e.g. "Program.exe -exit"). But most programs do not have such a command.
Alternatively, since "Launch application" is a command line process, you can enter a command to kill the system process. BUT this is usually not a good idea because it is not a clean shutdown. It is basically like the program has crashed, with all the consequences thereof. So for example, you could launch "TASKKILL /f /im thunderbird.exe /t" - which will forcefully close Thunderbird ...but you probably will not like the result.
Better than killing the process would be to find a third-party tool which you could launch to cleanly close the program.
Many thanks, trout,
I wouldn't have the idea, that using the "Launch application" you can shut down a program.
I have just tried, that doesn't work. I have added this line: "I:\Thunderbird\App\Thunderbird\thunderbird.exe  -exit" in "Launch application".
Yes, indeed, that doesn't seem to be the best choice.
Okay, I will try to find one.
Many thanks again.
