Topic: foo_scheduler (Read 451401 times) previous topic - next topic
foo_scheduler
Download here.
Source code here.
Change log is in about window of plugin.
foo_scheduler
very useful features. Thanks a lot!
foo_scheduler
Wow, I waited this so long! =) Thanks! Trying to migrate from foo_scheduler for 0.8..
Will there be any significant interface modifications? Most of all I miss quick access to events via Components -> Scheduler and current inability to use once-defined action to multiple events (and lack of choosing exact track of playlist to play )..
And, there' s the first founded bug  :
foo_scheduler
Yes, thank you
I only miss a timer instead of using exact time.
Good work!
foo_scheduler
Nice work, i had a bulky freeware program that woke from standby but now i can rely on this thanks a lot man.
Would be fantastic if you could intergrate a shutdown timer into it aswell, but I do understand that this is in it's early stages.
foo_scheduler
Tried it this night and it worked perfectly, it started fade the volume and play in the morning.
foo_scheduler
A "resume playback" or "unpause" option would be nice. Currently, the "Start playback" option restarts to the beginning of the file if it is paused.
Other than that, this is a nice plugin.
foo_scheduler
It is very good if "Exit foobar" action will be added.
By example, when Foobar reach the end of playlist - it must close, but not system shutdown as made in action "Shutdown".
foo_scheduler
I think the long wait for scheduler was worthy. And knowing the development progress^quality of foo_alarm, this will also be a fantastic plugin! Keep up the good work!
foo_scheduler
i didn't see anything,
what's wrong?
i just reinstalled foobar and it's still not working
foo_scheduler
When it's enabled, like in your screenshot, you just rightclick somewhere on the white =)
foo_scheduler
thanks,
i get it now
maybe something like "right click here" when it's empty next update?
foo_scheduler
thanks,
i get it now
you can see this: "use context menu to customise the task tree".
context menu mean "right click"
nobody born sage
please buy a book and learn
Music is my first love.
foo_scheduler
2 requests:
- shortcut to customise page
- timer ( action after xx time)
thank you for your plugin, now i can delete my autohotkey script...
foo_scheduler
Great plugin.  When I first saw it I was ambivalent about the design--and I still can't tell whether its cleanliness is a great advantage or a disadvantage  It's most likely because I've been using this Winamp plugin for the past three plus years until a few months ago I started using foo_alarm.  So, my reluctance is meaningless--in fact, it took me quite some time to get me used to foobar and now I look at Winamp and wonder how I used it.
Request: I would second the request for a "timer".  While you can do it by setting a one time schedule for a certain time that is not preferable.  What I think would be ideal is a third option, the timer, added to date/time event and player event.  It would be a one time event of X minutes and it would start counting down whenever you enabled it.  So, whenever I want my music on before I go to bed I just click the check box and it goes on for 60 minutes.  Then, that same event will be ready for me to click for tomorrow night (unless I chose the remove after done option).
The ability to check the same event night after night and have it count down is what makes it useful since if it was a one time 60 minute event you could very well set a one time alarm.  But being able to check the box and get the same 60 minutes would be very useful (to me).
Two less important issues:  When you add new events should the be checked by default (I almost didn't check it)?  and, would anyone else find it useful to be able to add a label to each event?  Such as "class alarm", "shutdown for the weekend" or whatever.  It could be right aligned or whatnot. and I think it might provide an easier way to navigate many events rather than reading the times.
foo_scheduler
Well, you still need to enter an exact time for an action to start, don't you?
It should be like gren said, enable it and it starts ticking
foo_scheduler
And now about the timer: IT'S ALREADY IMPLEMENTED!!!  See "Delay" action. It pauses action list for a certain amount of time.
But... that's only under a player event or a date/time event.  What I think is useful is delay from right now.  Did what I was saying make sense?  Having a timer of 60 minutes with events under it and whenever you checked the box it would start the timer going?  While I see that it's possible to do timer actions now... you first have to create a date/time that goes off right away to enact the delay which will lead to whatever other actions you schedule.  It assumes that a timer must be started at a certain time event instead of starting a timer 'now'.
Here is what I envisioned:
The event waits there until you want to click on it... and when you do the timer for those actions starts.  Maybe this is laziness... but using your delay you create a date/time event for one minute from now with those actions and then delay X minutes and each time you want to use this you have to change the time to being a minute from now to get the delay timer started.
foo_scheduler
It will be impossible to start timer after click. While you edit options scheduler is stopped. It starts when the preferences window of scheduler is closed.
As for the idea... I'll think about it.
foo_scheduler
Andrew!
Do you know about russian Foobar forum (http://www.foobar2000.ru/forum/)?
If you want joint to this forum, we can discussed with you on russian.
foo_scheduler
Why not introduce named events that can be triggered by main menu commands (one command for each named event)?
foo_scheduler
Great idea! Thanks, foosion!
foo_scheduler
Would you please consider adding the possiblity to add a event like "Do xxx on start of foobar?"
Thank you for you effort!
foo_scheduler
thanks alot. I've been waiting for this one for too long
I have 2 requests:
- is it possible to have an option : On playback end -> Proceed to the next playlist. I have many playlists for single artists or albums and it would be great if scheduler simply rolls to next playlist. With the current settings, it seems I could only specify 1 next playlist.
- An option to specify  which track should be played would be very nice
again, thanks for your effort. most wanted components
