Topic: I heart foo_dsp_delta! (Read 197341 times) previous topic - next topic
Reply #76
LOL, now I can't imagine listening music without this gem. It's the perfect complement to my Logitech Z-5500 speakers. THANKS!!!
Reply #77
seriously, i love this! i came across this accidentally and thought it wouldn't hurt trying it out. the noise sharpener makes the sound so clear - i really cannot switch back.. without it, my music now just sounds dull
YAY
Reply #78
Can we get this updated so it works with 0.9.6?
Reply #79
An updated version of foo_dsp_delta is available from my components page.
Reply #81
Is this overkill if I already have a high quality DAC?
Reply #82
@foosion: Thank you for the update
Reply #83
casedawg: Strictly speaking, nobody really needs this DSP. It's just that some people like the effect. If you want to compensate deficiencies in your playback equipment or listening environment, the convolver or the equalizer are more appropriate tools.
Reply #84
@foosion: thanks.
Reply #85
Oooo... sexy sound
Thanks for the component and thanks for the link! I've just gotten into Fb2k and I must say, this program is absolutely amazing. With all the components I have running, it's still a mere fraction of the system resources as winamp. Let alone that memory-leaking hog called iTunes.
Reply #86
thanks alot !
Reply #87
is there a new version?
Reply #90
Is there a problem with the current version?
Failed to load DLL: foo_dsp_delta.dll
Reason: This component is not compatible with this version of Windows and needs to be recompiled with a newer version of the foobar2000 SDK; please contact the author of this component to obtain an updated version of this component.
I remember getting this message in Windows Vista, it was fixed by forcing Foobar into Windows XP SP2 compatibility mode. However, now I'm using Windows 7 and when I enabling compatibility mode forces Foobar into an elevated state... which disables drag and drop between Foobar and explorer folders.
It'd be nice if there was a new version compiled, but until then (if ever) I'll find ways to work around it.
Reply #91
I got that error message on one of the visulisations, didn't try and put foobar2000 into compmode, I am on Vista x64...will try doing that; however certain plugins should be fixed.
Michael
Reply #92
Okay, I guess I should've done my homework. I must've been using the older version. Did some digging around and stumbled upon version 1.0.0. Then I realized the first post was updated with that version. (doh!) I installed the new version and it works under Windows 7 now without issue.
Sorry for the confusion.
Reply #93
Are you using the version from here?
Reply #94
Yeah, I am now.
Reply #95
many people here are very excited about sound quality using that plugin. I've got quite sensitive hearing (based on ABX's I've already made) and this plugin don't boost my sound quality as much as for others... might that be caused by quite good stuff E-MU 0202 + HD555? on 200% I got treble boost, on 50% I'm not sure if I hear any difference... is there a way to ABX same track on two different DSP sets?
Reply #96
Just started using this today, it's great (set at 50%). I'd like to use Secret Rabit Code Resampler (http://www.mega-nerd.com/SRC/fb2k.html) as well, but it seems to be outdated as I cannot install it (error msg). Is there a newer version or a way I can force install it?
I'm using a Dell laptop (Inspiron 1545). The laptop speakers really don't sound good, and when I plug my laptop into my stereo, it doesn't sound much better. Does anyone know any other methods of increasing audio quality?
Reply #97
There's no new version, and will most likely never be.
Read here why.
http://www.mega-nerd.com/erikd/Blog/CodeHa...e/foobar2k.html
Reply #99
Will there be a version for Foobar 1.0?
