Topic: script help needed (Read 1730 times) previous topic - next topic
script help needed
Hi everybody,
I need to get the album tag with everything that is in front of three characters (or more): (, [, {. I managed to do so with only one of the three, how can I do this for three of them at once? And also, if the %album% doesn't contain any of them, how can I make it so that it appears as it is? Like "if %album% contains ( or [ or { than return everything that stands before ( or [ or {, otherwise return %album% as it is".
Thanks in advance!
script help needed
I'll make some examples so that it is clearer:
If %album% is "Title (EP)" or "Title [EP]" or "Title {EP}" I want that the script returns "Title"
If %album% is "Title" I want that the script returns "Title".
I tried to use this: http://wiki.hydrogenaudio.org/index.php?ti...g_in_front_of_X
but can't get to adapt it to multiple values (X), i. e. (, [ and {.
Thanks in advance!
script help needed
Slightly modified example:
$puts(tag,%tag%)
$puts(spacer1,$strchr($get(tag),'{'))
$puts(spacer2,$strchr($get(tag),'['))
$puts(spacer3,$strchr($get(tag),'('))
$puts(spacer,$min($min(spacer1,spacer2),spacer3))
$trim($left($get(tag),$sub($get(spacer),1)))
script help needed
$puts(tag,%tag%)
Thanks a lot but I can't get it to work. I'm using this to launch album art downloader with the run service component...
script help needed
It works only with one. Why???
This works:
$puts(spacer1,$strchr(%album%,'{'))$trim($left(%album%,$sub($get(spacer1),1)))
But not if I make a script with more than one spacer, like the one you suggested.
script help needed
in my code, the 5th line should be:
$puts(spacer,$max($max($get(spacer1),$get(spacer2)),$get(spacer3)))
but it also works incorrectly if there are several characters: for "Title (EP) [2012]" the script returns "Title (EP)"...
script help needed
Thanks a lot, you've been very helpful! I don't think I have albums tagged that way, your code works fine for me! I'm now curious to see if there's a way to do it the way I meant tough.
Thanks again!
script help needed
Although not tested, this should also cover the not working part lvqcl mentioned (and it's shorter  ) :
$trim($left(%album%,$sub($strchr($replace(%album%,'{','(','[','('),'('),1)))
script help needed
I'm unable to test it right now, but wouldn't this be enough?
$replace(%album%, '(EP)', '', '[EP]', '', '{EP}', '')
Alessandro
PS: never mind, scratch that. Didn't realize EP was a mere example.
