Topic: rewind on pause (Read 1675 times) previous topic - next topic
rewind on pause
I'm looking for a feature that will rewind the track being played by e.g. 5 seconds upon pausing, similar to the Rockbox feature: Rockbox Playback Settings.
Scouring the internet has so far produces no results.
Anything like this exist?
rewind on pause
you could hide a WSH panel mod panel in your layout and put this code in it.
var limit = 5;
function on_playback_pause(state) {
    if (state) fb.PlaybackTime -= limit;
rewind on pause
Thank you, the plugin and code work perfectly!
But, is there a better to way to hide the panel than simply dragging the border? It's still slightly visible... not a big deal though.
rewind on pause
add this code and it will draw the background the same colour as the splitter.
var ww = 0;
var wh = 0;
function on_size() {
    ww = window.Width;
    wh = window.Height;
function on_paint(gr) {
    gr.FillSolidRect(0, 0, ww, wh, utils.GetSysColor(15));
if you were using columns UI, you can hide panels on the layout page of the preferences.
rewind on pause
Thank you again, that extra code did help its appearance.
