Topic: TAudioConverter (Read 314526 times) previous topic - next topic
TAudioConverter
Reply #725
Ozok: Found a bug in 0.9.5 beta:
Set a ouput folder. For instance: C:\Users\User\Desktop\TAC
Close TAC
Delete the folder
Start TAC.
TAC now resets the "output" to TAC.exe's location. In my case:
C:\Users\Olav\Documents\Stuff\tac64bit_0.9.5BETA_3555
No other versions of TAC have had this problem
TAudioConverter
Reply #726
Close TAC
Delete the folder
Start TAC.
It was suppose to be a feature actually . As you know the program folder is the default output folder in portable version and when user runs the program in a different machine, this path would change. I thought this would be the ideal behaviour.
TAudioConverter
Reply #727
Close TAC
Delete the folder
Start TAC.
Oh my  I liked it better without that feature. Middle way: Option for disabling it?
TAudioConverter
Reply #729
With john33's newest OGG Vorbis build, TAC does not work.
Logs.zip: http://www43.zippyshare.com/v/71524102/file.html
Does it mean that older versions of oggenc2.exe work? Because in the logs I can see:
-q 6    "C:\Users\Olav\AppData\Local\Temp\TAudioConverter\{7A6EEEFF-D09D-46C4-AED6-45147EF01F60}.wav" -o "C:\Users\Olav\Desktop\TAC\\\{DDE59462-42AE-46A0-AC41-FDE632037333}.ogg"
...and all versions of oggenc2 that I tried refuse to work with such paths.
TAudioConverter
Reply #732
New beta2 0.9.5 build 3684 changes:
Added: Several presets for mp3, aac and ogg vorbis
Added: Skinning is disabled as default
Added: TAC will rename encoded files on the fly
Added: Playback now stops at end point (cue, trim etc)
Added: Custom file/folder help is a text file instead of a message box
Fixed: Triple "\" in file path would cause some encoders to fail
Fixed: Cover art image path was written as a tag
Fixed: Couldn't write/read total track and disc no flac tags
Fixed: Stopping cd ripping didn't reset UI elements
Fixed: ID3v1 now has the lowest reading priority
Fixed: Encoding speed information was missing in cd ripping
Fixed: Track no and track count tags read from ID3v2 weren't parsed properly
Fixed: Lame channel option wasn't loaded/saved properly
Fixed: Controls in "Codec Options" window no longer look as if they are disabled
Updated: Tag libraries
Download: https://bitbucket.org/ozok/taudioconverter-...erter/downloads
TAudioConverter
Reply #733
Good release ozok and thanks for this "Added: Skinning is disabled as default".
TAudioConverter
Reply #734
Thanks eahm. This should also fix problems with oggenc2 due to "\\\" in file path.
TAudioConverter
Reply #735
0.9.5 change log:
-Added: [General] "Merge Audio" mode
-Added: [General] Several presets for aac, mp3 and ogg vorbis
-Added: [General] An option to use MediaInfo or libraries from 3delite.hu to read tags
-Added: [General] TAC will rename files right after they are encoded
-Added: [General] TAC will try to create temp folder at startup
-Added: [General] "Filters" button's icon will go grey if filters are disabled
-Added: [General] "Create log.zip" option to "Help" menu
-Added: [General] TAC will remember it's last position, window state and size
-Added: [General] Number of files will be shown at the bottom of the file list
-Added: [General] "Title", "Album", "Artist" and "Genre" columns to file list (thx to o-l-a-v)
-Added: [General] Clicking to column in the file list will sort the list (thx to o-l-a-v)
-Added: [General] "Album Artist" (%albumartist%) tag to custom folder/file option
-Added: [General] Improved FLAC tag writing and reading
-Added: [CDRipper] Will now ask confirmation when user wants to stop ripping
-Added: [General] A few minor features and UI changes
-Added: [General] Skinning is disabled as default
-Fixed: [General] TAC couldn't rename some files if "Custom Folder Tree" was selected and tags contained invalid chars (thx to o-l-a-v)
-Fixed: [General] TAC wouldn't search external gif and bmp artwork files
-Fixed: [General] TAC wouldn't pad track no when "Custom folder tree" was selected
-Fixed: [General] TAC didn't respect start/end points during playback
-Fixed: [General] Codec list and related controls didn't resize/move when window was resized
-Fixed: [General] Main window's dimensions are now smaller
-Fixed: [General] Custom folder tree would fail with some cue files
-Fixed: [General] Lame channel option wasn't saved/loaded propery
-Fixed: [CDRipper] Wouldn't restore window title and menu items when stopped by user
-Fixed: [CDRipper] Wouldn't write artwork to ogg/opus files due to a bug in tag library
-Fixed: [CDRipper] Encoding speed information was missing
-Fixed: [TTagger] A bug where tags couldn't be written because external artwork file was being used by an other process (thx to o-l-a-v)
-Fixed: [TTagger] A bug where ttagger would write cover art path as a tag
-Updated: Opusenc to 0.1.8-git (using libopus 1.1.x-git)
-Updated: Tag libraries
-Updated: QAAC to 2.41
-Updated: RefAlac to 1.41
Known issues:
-Skinning option is not saved
Download
Source
TAudioConverter
Reply #736
Hi ozok. I continue to love using this converter, even over foobar in some instances.
Question, where is this "merge" files function on the latest release?  I can't find it.  Is it similar to foobar2000 when it allows you to output converted files into one file?
Thanks again.
foobar2000, FLAC, and qAAC -V90
It just works people!
TAudioConverter
Reply #738
I feel sheepish for not having looked there!
Ran a test album, and I probably forgot to select certain things....no tags and no artwork in the merge mode.  Foobar at least gives you a starting point to re-tag.  Maybe this doesn't work in merge mode when you have a various artist album.  I have it set from "copy tags from source".
TAudioConverter
Reply #739
Yes, tags aren't written in that mode. But I'll add a way to do it.
TAudioConverter
Reply #740
Sounds like a good plan for a future update.  Your work has been most appreciated for those who want the cream-of-the-crop of converters.
TAudioConverter
Reply #741
TAC 0.9.5 build 3969 has some tagging bugs. It does not write external artwork to opus output (when not using TTagger), and it cuts names (when renaming output) even though the tags looks like they got preserved. Rename bug appears both with and without TTagger as tagger
Logs: https://mega.co.nz/#!L5YgxB4I!54I_V...g6lUisIYBOY2Tcs
TAudioConverter
Reply #742
Thanks o-l-a-v, I've noticed the same problem with some files too. I think the problem occurs when there is a dot right before the end of file name (in my case it is "...And Justice For All"). I haven't found a solution yet. Let me check artwork bug.
EDIT: I think I've found a solution to truncated file name problem. Thanks again.
TAudioConverter
Reply #743
I've also fixed opus artwork problem. I'll prepare a beta asap.
TAudioConverter
Reply #744
0.9.6 beta update changes:
-Added: Progress list now shows a new item for each step
-Added: Opus profiles
-Fixed: Skin enable/disable option wasn't saved
-Fixed: CD ripping would fail if no tag info was found or no internet connection existed
-Fixed: Writing artwork to OPUS files with opusenc failed (thx to o-l-a-v)
-Fixed: Writing artwork to files ripped from CD with encoders didn't work
-Fixed: "JPEG error #53" when refreshing cd track list
-Fixed: Empty file name problem if "Custom folder tree" was selected and a tag contained a dot (thx to o-l-a-v)
-Fixed: Updater showed an update while there wasn't one
-Fixed: File adding duration info was wrong
-Fixed: A few interface problems
You can download beta update here.
Please note that packages above only include portable TAudioConverter.exe, changelog.txt and some profiles. You'll need to have portable package of v0.9.5.
TAudioConverter
Reply #745
Thanks ozok!
Suggestion: To create and save custom presets would be awesome. I'm not really likely to use any of the presets, so would be very useful if one could save current configuration or something like that
TAudioConverter
Reply #746
New version 0.9.6 changes:
-Added: [General] Progress list now shows a new item for each step
-Added: [General] Opus profiles
-Added: [General] Tag editor for audio merging (thx to Meeko)
-Fixed: [General] Skin enable/disable option wasn't saved
-Fixed: [CDRipper] CD ripping would fail if no tag info was found or no internet connection existed
-Fixed: [General] Writing artwork to OPUS files with opusenc failed (thx to o-l-a-v)
-Fixed: [CDRipper] Writing artwork to files ripped from CD with encoders didn't work
-Fixed: [CDRipper] "JPEG error #53" when refreshing cd track list
-Fixed: [General] Empty file name problem if "Custom folder tree" was selected and a tag contained a dot (thx to o-l-a-v)
-Fixed: [General] Updater showed an update while there wasn't one
-Fixed: [General] File adding duration info was wrong
-Fixed: [General] A few interface problems
-Updated: opusenc to 0.1.9
-Updated: QAAC to 2.42
-Updated: RefAlac to 1.42
-Updated: FDKAAC to 0.6.0
Source
Download
TAudioConverter
Reply #748
Hi ozok! I don't follow this project much, sorry. I saw you have support for the flacCL encoder of CUEtools included already. What about adding the CUEtools flake and the ALAC encoder with its additional compression options?
I just added recent versions here: http://www.hydrogenaud.io/forums/index.php?showtopic=106446
I think Mr. Grigory Chudov, the CUEtools developer won't complain.
TAudioConverter
Reply #749
hi ozok
could be added trim silence at the beginning and the end decompressing audio to wave?
thanks!
