Topic: S/PDIF Cable and Jitter (Read 23042 times) previous topic - next topic
Jitter in the digital domain is nonsense.
Jitter in this case affects the timing of the DAC and has a theoretical effect on the sound. It is just very unlikely to have an actual audible effect.
In case someone is so worried about jitter, why not use line-out -> line-in?
So here is an analog connection example, the result is a joke since the $6xx Denon CD Player measured poorer than a motherboard audio interface.
http://www.hydrogenaud.io/forums/index.php...st&p=856574
Disclaimer: the SPDIF result is not used to test any kind of jitter. A synced SPDIF recording cannot reveal jitter.
That's my thoughts really. The DAC would be buffered and also have it's own clock so cable is unlikely to cause timing problems. A UHF TV aerial manages to handle far higher frequencies [than required of a SPDIF cable for even 384khz 24 bit audio]  at far lower signal levels and yet the timing is still sufficient for a stable colour picture can be achieved.
