Topic: qtaacenc: a command-line QuickTime AAC encoder for Windows (Read 405006 times) previous topic - next topic
Reply #150
Ok, I tried it again on test sample:
1. Generating (bit depth - 32 bit IEEE float, samplerate - 44.1 kHz) set of 1 kHz tones - -12 dBFS, -6 dBFS, 0 dbFS - in Sony SoundForge
2. Encoding with qtaacenc --tvbr 127 --high  +6dB Gain in foobar2000
3. Decoding to 32-bit float (using foobar2000)
4. Analyzing peaks in SoundForge
Results:
What I've got for three tones is (+/- 0.1 dB):
-6 dBFS (-12+6, ok), 0 dBFS (-6+6, ok), 0 dB (?)
So, as we can see, the volume of third tone was reduced, and limiter in QuickTime is still enabled.
I must assure you that no clipping occurred, all encoding/decoding was performed using floating-point samples only And output audio file sounds like normal 1 kHz tones
🇺🇦 Glory to Ukraine!
Reply #151
Hello! QuickTime 7.6.6 is now released. I wonder what changes it contains, and how they can affect the using of qtaacenc?
I just tried qtaacenc with the new Quicktime and the files are substantially bigger/higher bitrate
Using this command line: --tvbr 50 --highest --samplerate keep - %d (which I use for mobile) in Foobar
7.6.5/7.6.6 Bitrate comparison (7 tracks from Gary Numan Telekon from flac source)
1. 121/131
2. 106/115
3. 120/128
4. 119/131
5. 110/114
6. 107/113
7. 120/130
etc (the remaining 9 tracks follow the same trend)
The bitrate difference is random, but there is quite a difference in bitrate. I wonder if the 'tvbr' ranges have changed in this version.
Reply #152
Maybe this bitrate variation is due to bug of lowpass.
Reply #153
You guys are confusing me. What exactly do you mean by lowpass? That the encoder downsamples to 32 kHz?
Chris
Reply #154
TWIMC: foo_dsp_lowpass
Reply #157
I have this problem, no one can help me?
This is the result in foobar2000:
1 out of 1 tracks converted with major problems.
Source: "F:\Audio - Video\Foobar\Ghost.wav"
  An error occurred while writing to file (The encoder has terminated prematurely with code 0 (0x00000000); please re-check parameters) : "F:\Audio - Video\Foobar\Ghost.m4a"
Additional information:
Encoder stream format: 44100Hz / 2ch / 16bps
Command line: "D:\Program Files (x86)\qtaacenc-20100307\qtaacenc.exe" --tvbr 100 --highest - "Ghost.m4a"
Working folder: F:\Audio - Video\Foobar\
  Conversion failed: The encoder has terminated prematurely with code 0 (0x00000000); please re-check parameters
Edit: now work
Reply #158
I browsed whole thread and it seems strange that no one got this problem:
I installed latest QT and tried foobar converter, which produced an error
Then going on command line qtaacenc throws error about missing "qtcf.dll"
File is located QTSystem folder and needs to be copied in system32 (at least in my case)
Thanks for --he switch
Reply #160
Oh wonderful, i'm trying it now with FB2K for ALAC encodings and works perfectly, so i can avoid using ffmpeg.
Reply #161
What parameters are you using in foobar with qaac to output ALAC?  I can't figure it out.
Reply #162
Parameters for ALAC encoding (for qaac.exe in foobar2000):
-A -s - -o %d
Reply #163
Reply #164
what about dbpoweramp setting? I tried this one but it didn't work,neither with - [outfile] at the end.
Reply #165
I was really surprised when I found this:
http://sites.google.com/site/qaacpage/home
qaac is a command line AAC/ALAC encoder using QuickTime API, strongly influenced by http://tmkk.hp.infoseek.co.jp/qtaacenc/
nao, is it your project too?
What's the difference between the 2 versions? Why should I use one over the other?
Reply #166
input file formats, output file formats, multiple input files... so if you use foobar and want AAC, this thread's encoder is for you
Reply #168
This is really a wonderful tool, nao.  Thank you for doing this.
But can someone give me a command line to use this with EAC?  I can't for the life of me seem to get it to work.  If I use the same command line I use in Foobar, the QT encoder opens in a window, but nothing happens.  If I try the command line that another poster in this thread asked about (--tvbr 256 --highest %s %d --artist "%a" --title "%t" --album "%g" --date "%y" --genre "%m" --track "%n"), it does create a file, but I can't play it.  It's like the file is corrupt or something.
Reply #169
Make sure that "Add ID3 tag" option is unchecked.
Reply #170
I've tried many things with dbpoweramp but i can't get qaac to work,with any command like which works under foobar. I also made sure to check the command settings:
Usage: qaac [options] infiles....
"-" as infile means stdin.
Main options:
-d <dirname>          Output directory, default is cwd
-a, --abr <bitrate>    AAC ABR mode / bitrate
-V, --tvbr <n>        AAC True VBR mode / quality [0-127]
-v, --cvbr <bitrate>  AAC Constrained VBR mode / bitrate
-c, --cbr <bitrate>    AAC CBR mode / bitrate
--he                  HE AAC mode (Can't use TVBR)
-A, --alac            ALAC encoding mode
-q, --quality <n>      AAC encoding Quality [0-2]
-r, --rate <option>    Sample rate option (AAC only)
                      Specify one of the followings:
                      keep: Try to preserve the original rate
                      auto: Let QuickTime choose the optimal one
                      <number>: Literal rate in Hz
-s, --silent          Don't be verbose
-R, --raw              Raw PCM input
-S, --stat            Save bitrate statistics into file
Options for single input mode only:
-o <filename>          Output filename
Options for Raw PCM input only:
--raw-channels <n>    Number of channels, default 2
--raw-rate    <n>    Sample rate, default 44100
--raw-format  <str>  Sample format, default S16L
                      Sample format spec:
                      1st char: S(igned) | U(nsigned) | F(loat)
                      2nd part: Bitwidth
                      Last part: L(ittle Endian) | B(ig Endian)
                      Cases are ignored. u8b is OK.
Tagging options(single input only):
--title <string>
--artist <string>
--band <string>
--album <string>
--grouping <string>
--composer <string>
--comment <string>
--genre <string>
--date <string>
--track <number[/total]>
--disk <number[/total]>
--compilation
also which is the setting for faster,fast normal high and highest? -q 0/2 what does actually do? sorry for all of these questions
Reply #171
Well, qaac is not my project. Please discuss it in the other thread...
Reply #173
@nau can you add aac (mpeg4 adts) output to stdout?
_
Reply #174
you're right sorry nao i didn't mean to put your project behind; i personally appreciate your job more as you gave us a lot of support.
(i know it's off topic but with lastest XLD version i encounter a bug or what? example "1-04 X.flac becomes when converted 04 X.m4a and so on,it skips the compilation from the title thus getting file names with multiple cds disorganized; before it kept the structure normally, maybe i'm getting wrong something. Sorry for going out of theme but I didn't know where to post this)
