Topic: converter error with multiple encoder instances (Read 4266 times) previous topic - next topic
usually, when telling the converter to overwrite a file it will work without problems, but if multiple encoding threads are running it may return a sharing violation error and quit the conversion (the progress window disappears, foobar runs fine) if the file it tries to overwrite is currently being encoded by another thread.
this problem occurs in foobar2000 0.9.5
ooops, the topic description field is too short.
You can set Preferences -> Advanced -> Tools -> Converter -> Thread Count to 1 so that foobar will only use one thread at a time. This will stop two instances of that encoder trying to write to the same file.
thanks, i know that, but i don't want to let my other 3 cores idle
I don't have a quad-core only a dual, but I haven't encountered this problem once. IIRC there're certain decoders (especially those that decode game music files) that are not thread-safe. So what do you transcode from and to?
i was using oggenc2 to transcode mp3s to q5 oggs for my flash player. the best way to simulate it would be to add the same track twice and then attempt to transcode it.
So the problem is that you try to convert the same file multiple times in the same batch set and that converter tries to generate the same output file multiple times?
you make it sound like i'm an idiot
i was converting multiple albums to the same directory with the following naming scheme %artist% - %title%, so if there were same tracks on different albums they would overlap. i used to do 'overwrite all' so i wouldn't have to skip 100 times on my single core pc, but now that i encode 4 songs at the same time sharing violation occurs.
(EDIT: Nevermind...)
Sounds like you're going to have to add a unique variable to your file name scheme.
Sorry for that, I was just trying to understand the problem. Never mind that doing idiotic things to software is a good way to reveal bugs, I have quite some experience with that.
Anyway, thanks for clearing up what triggers the problem.
glad i could help
