MAREO 6: With CUE Sheet Support
Reply #23 – 2007-12-17 21:44:42
Hi there I'm very new to Mareo and not a great expert at any of this stuff, but really want to be able to rip my CDs to both FLAC and MP3 so this looks like a great way to do it. I've spent most of today trying to get Mareo to work and read countless forums but hope I'll be able to get some help by posting. Initially, I'm just trying to get the LAME MP3 encoder to work but for some reason the encoding itself isn't happening. I just end up with the wav files in my Music\Albums directory. I'm sure I'm missing something simple here, and if anyone could help I'd be really grateful. Thanks very much, Peter.My EAC settings are as follows: Parameter passing scheme: User defined encoder Use file extension: .mareo Program path: C:\Program Files\EAC\Mareo\mareo.exe Additional command line options: mareo.ini %s %d "%a" "%g" "%t" "%n" "%y" "%m" Bit rate: 192kbps Delete Wav after compression: Unchecked Use CRC check: Checked Add ID3 tag: Unchecked Check for external programs return code: UncheckedMy mareo.ini file includes the following code: ; --------------------------------------------------------------------------------------------------------------------------- ; MP3 LAME: best MP3 encoder: http://www.rarewares.org/mp3.html ; --------------------------------------------------------------------------------------------------------------------------- EXECUTEIF = TRUE FINALPATH = F:\Music\Albums\[ARTIST]\[ALBUM]\ FINALNAME = [TRACKPADDED]-[TITLE] VAFINALPATH = F:\Music\Albums\"Various Artists"\[ALBUM]\ VAFINALNAME = [TRACKPADDED]-[TITLE]-[ARTIST] EXTENSION = mp3 ENCODEREXE = c:\Program Files\EAC\lame397\lame.exe PARAMETERS = -V2 --vbr-new --ignore-tag-errors --ta "[ARTIST]" --tl "[ALBUM]" --tt "[TITLE]" --tn "[TRACK]" --ty "[YEAR]" --tg "[GENRE]" "[SOURCE]" "[DESTTMP]" RENAME = TRUEMy mareo.log file shows the following: *********************************************************** * MAREO - Multiple Applications Runner for EAC and Others * * Copyright 2003-2007 by Kwanbis -- Under the GPL License * * Version 6.0b2 - Home Page at http://www.webearce.com.ar * * Developed with Borland Delphi http://borland.com/delphi * *********************************************************** *** Received Command Line *** "C:\Program Files\EAC\Mareo\mareo.exe" mareo.ini "F:\Music\Albums\\Son Of Dork\Ticket Outta Loserville\0tmp77268.wav" "F:\Music\Albums\\Son Of Dork\Ticket Outta Loserville\0tmp77268.mareo" "Son Of Dork" "Ticket Outta Loserville" "Boyband" "05" "" "" *** Parsed Parameters *** INIFILE (%1) = C:\Program Files\EAC\Mareo\mareo.ini [SOURCE] (%2) = F:\Music\Albums\\Son Of Dork\Ticket Outta Loserville\0tmp77268.wav [DESTTMP] (%3) = F:\Music\Albums\\Son Of Dork\Ticket Outta Loserville\0tmp77268.mareo [ARTIST] (%4) = Son Of Dork [ALBUM] (%5) = Ticket Outta Loserville [TITLE] (%6) = Boyband [TRACK] (%7) = 5 [YEAR] (%8) = 1900 [GENRE] (%9) = Unknown *** INI Parameters *** Padding Zeros = 2 DeleteWavFile = FALSE CorrectionChar = _ *** Encoder Orders Ends *** DeleteWaveFile is FALSE. *** DONE *** NO errors ocurred. you need to add the two new CUE lines, I had the same issue. seeya rodo from monterrey
