Topic: Exact Audio Copy V0.99 prebeta 3 (Read 115525 times) previous topic - next topic
Reply #75
If the option “Remove leading and trailing silence” is disabled, most probably not the full track is extracted and can not be checked against the AccurateRip database
I find this statement quite contradictory, isn't it?
Reply #76
I totally agree, I have always had it disabled, but after seeing the same problem you mention I turned it on and I did not see any AccurateRip errors. I have not tried this with too many discs, and based on this thread, I'm not too sure it it's a good idea or not to keep it on.
Below is an interesting thread on the setting:
http://www.hydrogenaudio.org/forums/index....c=54667&hl=
Bryan
Reply #77
Well if it makes you feel better now that I am ripping a lot of discs myself with Accuraterip for the first time (other than testing drives) I am finding quite a bit of discs similarly flagged as inaccurate.  Though these are mostly pristine only played a few times and I verify the rip by doing it again in secure mode.  I just think for whatever reason I tend to get the 'other' pressings that nobody else has.
"Have you ever been with a woman? It's like death. You moan, you scream and then you start to beg for mercy, for salvation"
Reply #78
I was seeing similar behavior and when reading the AccurateRip page on the EAC site, one of the bullets says:
  • If the option “Remove leading and trailing silence” is disabled, most probably not the full track is extracted and can not be checked against the AccurateRip database
I see where you have it disabled in your config. I originally had it disabled too and after turning it back on, my results have been better.
Bryan
O.K. now I feel like a total idiot....
I should have looked a little closer at my log files. When selecting the option "Delete leading and trailing silent blocks" the log file does not even show AccurateRip results. That would explain why when turning it on, I did not see any errors. When unchecking the option, the log file shows the AccurateRip results once again.
So please disregard my previous post.
Bryan
Reply #79
I am starting to get tired of this "accuraterip" thingie
AccurateRip 101:  AccurateRip can never prove that a rip is not accurate.
Anyhow this is already being addressed...
http://www.hydrogenaudio.org/forums/index....showtopic=55914
Reply #80
I'd say that the more people notice and complain (SPAM!) about this the more apparent it becomes that this is a real design flaw in the application interacting with the user.
Reply #81
No need.  I can assure you that this is being taken care of.  Maybe you'd like to help; if so, send me a PM.
Just to tie up a loose end...
Track 1 accurately ripped (confidence 1) [945F87DF]
While the rip obviously went wrong, correct data was actually extracted at some point... wasn't it? Or did you manage to change your computer ID for AR somehow?
This was in response to Keykey's first post.
I think the problem AndersHu brought up in another thread answers the question:
Test & Copy Image & Create CUE Sheet Uncompressed uses the Test extraction, not the Copy extraction for AccurateRip.
Keykey,
If you're there, can you try to reproduce the problem again by selecting "Eject CD after extraction finished", but this time have EAC use "Native Win32 interface for Win NT/2000/XP"?
You'll need to run EAC with administrative rights in order to do this.
Reply #82
Has anyone else noticed that when you use test and copy image the percent complete in the status bar button only goes to 50% and not 100%.  I'm using REACT so it may be an issue with that.
Reply #83
When I run a Test & Copy Image on an enhanced CD I get the following result:
Exact Audio Copy V0.99 prebeta 1 from 25. May 2007
EAC extraction logfile from 8. August 2007, 10:36
Billy Joel / Piano Man (1998 Re-Release)
Used drive  : Optiarc DVD RW AD-5540A  Adapter: 1  ID: 0
Read mode              : Secure
Utilize accurate stream : Yes
Defeat audio cache      : No
Make use of C2 pointers : No
Read offset correction                      : 48
Overread into Lead-In and Lead-Out          : No
Fill up missing offset samples with silence : Yes
Delete leading and trailing silent blocks  : No
Used interface                              : Native Win32 interface for Win NT & 2000
Used output format              : User Defined Encoder
Selected bitrate                : 128 kBit/s
Quality                        : High
Add ID3 tag                    : No
Command line compressor        : C:\Program Files\REACT2\REACT.exe
Additional command line options : REACT %o %s %d "%a" "%g" "%t" "%n" "%x" "%y" "%m" "%e" "%f" "%b" %r
TOC of the extracted CD
    Track |  Start  |  Length  | Start sector | End sector
        1  |  0:00.00 |  4:16.24 |        0    |    19223
        2  |  4:16.24 |  5:38.59 |    19224    |    44632
        3  |  9:55.08 |  3:18.71 |    44633    |    59553
        4  | 13:14.04 |  3:13.40 |    59554    |    74068
        5  | 16:27.44 |  5:42.24 |    74069    |    99742
        6  | 22:09.68 |  3:15.41 |    99743    |  114408
        7  | 25:25.34 |  3:55.30 |    114409    |  132063
        8  | 29:20.64 |  3:34.15 |    132064    |  148128
        9  | 32:55.04 |  3:20.08 |    148129    |  163136
      10  | 36:15.12 |  7:17.12 |    163137    |  195923
      11  | 46:04.24 |  7:22.39 |    207324    |  240512
Range status and errors
Selected range
    Filename C:\My Documents\My Music\CD Images\Billy Joel - Piano Man (1998 Re-Release) [1973].wav
    Peak level 99.8 %
    Range quality 100.0 %
    Test CRC 2AEAB7B6
    Copy CRC 2AEAB7B6
    Copy OK
AccurateRip summary
Track  1  accurately ripped (confidence 5)  [79DE2726]
Track  2  accurately ripped (confidence 5)  [D58625FD]
Track  3  accurately ripped (confidence 5)  [A01AC1C4]
Track  4  accurately ripped (confidence 5)  [78FE15F0]
Track  5  accurately ripped (confidence 5)  [A44277E1]
Track  6  accurately ripped (confidence 5)  [9BF7CF3B]
Track  7  accurately ripped (confidence 5)  [9D24C251]
Track  8  accurately ripped (confidence 5)  [D3DC56FF]
Track  9  accurately ripped (confidence 5)  [671A1933]
Track 10  not ripped completely
Track 11  not ripped completely
No errors occurred
End of status report
The last two tracks (one audio, one data) report as "not ripped completely" even though the rip occurred with no errors.  Do I have something set incorrectly or is this just due to the way AccurateRip for images works via the TOC to determine where the tracks begin and end?
Reply #85
This has been addressed already and should be fixed in the next version.
Thanks.  Any idea about the 50% thing?  Also, why does the log file not automatically save for Test & Copy Image until after you hit the OK button?  This doesn't seem to be a problem with Copy Image.
Reply #86
From www.exactaudiocopy.de
As the 0.99 prebeta 1 had some severe bugs and the accurate rip log output was not as clear as it could have been, so some wordings are now changed. I hope this version will be much more stable… Enjoy!
Reply #87
Merged prebeta2 news submission into existing EAC news thread.
Edit: Download link is still this:
http://www.exactaudiocopy.de/en/index.php/...tive-servers-2/
I have no idea why André isn't updating the front page.
Reply #88
I think he can't...  someone else is maintaining the website for him.
Btw, anyone got a changelog? Would be nice to know what bugs were fixed.
Reply #89
I can tell you all the bugs that I tested that were fixed, but will have to do this a little later, ok?
Caveat:
Some changes were made to the last sub-version that I used to test before pb2 was released and I'm not sure what they are.  I was also not part of the group involved the last round of testing after the AR reporting and bug fixes (as shown in my next post) were ironed-out.
Reply #90
I just went to the link mentioned to upgrade and apparently prebeta 3 is already out. No idea what's changed.
Edit: Apparently the main page has also been updated now with some changes:
Bad luck, it is not possible to load the 0.99pb1 profiles anymore, this should be fixed now, please use 0.99 prebeta 3
August 16, 2007
Reply #91
Great work Andre
Reply #92
pb3 was released because people were unable to use profiles created in pb1, but now it appears pb3 can't read profiles from pb2 (I haven't verified this and probably won't bother trying).  Hopefully no one is reverting back to pb1 because of this!
At the risk of repeating myself in this thread, Andre hosts a forum in both German and English over at
http://www.digital-inn.de/forum271
As for the bug fixes, and these are off the top of my head (I will come back and revise this post later if need be):
  • When using test & copy (tracks or images), the copy pass is now used to generate AR results.
  • The "Eject CD after extraction finished" bug was fixed.
  • AR lookup of the last track on an enhanced disc now works correctly.
  • AR lookup of tracks with pregaps prepended (test or copy passes) now works correctly.
  • AR lookup of individual indices now works correctly.
  • AR lookup of ranges now works correctly.
  • AR lookup of short tracks now works correctly.
  • Range rips (F7) immediately following a test pass operation (F8) are no longer done in test mode.
  • Information from a previous rip is no longer included in the log for a rip that gets cancelled.
The very first bugfix listed is (IMO) major, and for this reason I don't think anyone should be using V0.99pb1.
Reply #93
Anyone else having problems with pb3 crashing?  I've been able to rip a few cds, but about half the time it crashes when I load a disc.
Reply #94
From the looks of the other thread you started, pb3 isn't the only version that is crashing.
On another note, Andre has elaborated more on the change from pb2 to pb3:
http://www.digital-inn.de/exact-audio-copy...3-released.html
Reply #95
Hope unicode is supported soon.
Reply #96
Can someone do the following test. Submit your accuraterip results to clear any stored.
Then rip 5 common cds as single tracks, then another 5 different cds as image. After this do the submission by email, and give the email a title:
EAC .99 pb1 ar test
Then post here to stop 100's of submissions , that way I can check this new version is working correctly.
spoon,
It doesn't appear that anyone has responded to your request yet. As you requested, here are the log files from 5 CDs ripped as tracks, and another 5 CDs ripped as images. I skipped EAC 0.99 prebeta 1 because of the reported problems, so everything here is from EAC 0.99 prebeta 3.
And I sent you an e-mail as requested.
5 CDs ripped as tracks:
Exact Audio Copy V0.99 prebeta 3 from 28. July 2007
EAC extraction logfile from 30. August 2007, 10:00
The Beatles / Abbey Road
Used drive  : SONY    DVD RW DRU-810A  Adapter: 3  ID: 0
Read mode              : Secure
Defeat audio cache      : Yes
Read offset correction                      : 618
Null samples used in CRC calculations      : Yes
Used interface                              : Installed external ASPI interface
Gap handling                                : Not detected, thus appended to previous track
Used output format : Internal WAV Routines
Sample format      : 44.100 Hz; 16 Bit; Stereo
        1  |  0:00.33 |  4:20.47 |        33    |    19579
        2  |  4:21.05 |  3:03.00 |    19580    |    33304
        3  |  7:24.05 |  3:27.20 |    33305    |    48849
        4  | 10:51.25 |  3:26.53 |    48850    |    64352
        5  | 14:18.03 |  2:51.12 |    64353    |    77189
        6  | 17:09.15 |  7:47.13 |    77190    |  112227
        7  | 24:56.28 |  3:05.42 |    112228    |  126144
        8  | 28:01.70 |  2:45.40 |    126145    |  138559
        9  | 30:47.35 |  4:02.30 |    138560    |  156739
      10  | 34:49.65 |  2:26.23 |    156740    |  167712
      11  | 37:16.13 |  1:06.22 |    167713    |  172684
      12  | 38:22.35 |  1:12.55 |    172685    |  178139
      13  | 39:35.15 |  1:57.55 |    178140    |  186969
      14  | 41:32.70 |  1:31.43 |    186970    |  193837
      15  | 43:04.38 |  1:36.65 |    193838    |  201102
      16  | 44:41.28 |  2:19.62 |    201103    |  211589
      17  | 47:01.15 |  0:23.20 |    211590    |  213334
Track  1
    Filename C:\Temp\The Beatles\Abbey Road\01 - Come Together.wav
    Peak level 63.3 %
    Track quality 100.0 %
    Copy CRC B1A081D5
    Accurately ripped (confidence 134)  [C4962893]
    Copy OK
Track  2
    Filename C:\Temp\The Beatles\Abbey Road\02 - Something.wav
    Peak level 63.8 %
    Copy CRC 25B3CA39
    Accurately ripped (confidence 134)  [0EDD3279]
    Copy OK
Track  3
    Filename C:\Temp\The Beatles\Abbey Road\03 - Maxwell's Silver Hammer.wav
    Peak level 61.0 %
    Copy CRC AB9CF5F8
    Accurately ripped (confidence 132)  [CA819ECA]
    Copy OK
Track  4
    Filename C:\Temp\The Beatles\Abbey Road\04 - Oh! Darling.wav
    Peak level 64.5 %
    Copy CRC 4D46094A
    Accurately ripped (confidence 134)  [7E0A8C68]
    Copy OK
Track  5
    Filename C:\Temp\The Beatles\Abbey Road\05 - Octopus's Garden.wav
    Peak level 63.8 %
    Copy CRC D6F3BFF1
    Accurately ripped (confidence 133)  [23A0758B]
    Copy OK
Track  6
    Filename C:\Temp\The Beatles\Abbey Road\06 - I Want You (She's So Heavy).wav
    Peak level 66.8 %
    Copy CRC 66230CD2
    Accurately ripped (confidence 132)  [7B0D72D8]
    Copy OK
Track  7
    Filename C:\Temp\The Beatles\Abbey Road\07 - Here Comes the Sun.wav
    Peak level 72.4 %
    Copy CRC 3AC77312
    Accurately ripped (confidence 133)  [442DD3D1]
    Copy OK
Track  8
    Filename C:\Temp\The Beatles\Abbey Road\08 - Because.wav
    Peak level 65.2 %
    Copy CRC D2041A67
    Accurately ripped (confidence 131)  [E34884B2]
    Copy OK
Track  9
    Filename C:\Temp\The Beatles\Abbey Road\09 - You Never Give Me Your Money.wav
    Peak level 77.2 %
    Track quality 99.9 %
    Copy CRC C9130B8E
    Accurately ripped (confidence 132)  [6D372AD6]
    Copy OK
Track 10
    Filename C:\Temp\The Beatles\Abbey Road\10 - Sun King.wav
    Peak level 61.1 %
    Copy CRC F34302C8
    Accurately ripped (confidence 130)  [0340DAE2]
    Copy OK
Track 11
    Filename C:\Temp\The Beatles\Abbey Road\11 - Mean Mr. Mustard.wav
    Peak level 89.4 %
    Copy CRC 42708A22
    Accurately ripped (confidence 132)  [77DC0635]
    Copy OK
Track 12
    Filename C:\Temp\The Beatles\Abbey Road\12 - Polythene Pam.wav
    Peak level 79.9 %
    Track quality 99.8 %
    Copy CRC 5ABA5D21
    Accurately ripped (confidence 131)  [BCE3FBB7]
    Copy OK
Track 13
    Filename C:\Temp\The Beatles\Abbey Road\13 - She Came in Through the Bathroom Window.wav
    Peak level 75.8 %
    Copy CRC 316BE04F
    Accurately ripped (confidence 132)  [6E912649]
    Copy OK
Track 14
    Filename C:\Temp\The Beatles\Abbey Road\14 - Golden Slumbers.wav
    Peak level 77.2 %
    Copy CRC 8DA82C25
    Accurately ripped (confidence 127)  [8F8283D0]
    Copy OK
Track 15
    Filename C:\Temp\The Beatles\Abbey Road\15 - Carry That Weight.wav
    Peak level 77.0 %
    Copy CRC 0410F19C
    Accurately ripped (confidence 127)  [4984B8C6]
    Copy OK
Track 16
    Filename C:\Temp\The Beatles\Abbey Road\16 - The End.wav
    Peak level 88.3 %
    Copy CRC 4B71A94C
    Accurately ripped (confidence 129)  [E6D37BC5]
    Copy OK
Track 17
    Filename C:\Temp\The Beatles\Abbey Road\17 - Her Majesty.wav
    Peak level 54.2 %
    Track quality 99.5 %
    Copy CRC B04FA230
    Accurately ripped (confidence 131)  [2A53610A]
    Copy OK
All tracks accurately ripped
No errors occurred
EAC extraction logfile from 30. August 2007, 9:28
Evanescence / Fallen
Read mode              : Secure
        1  |  0:00.00 |  3:35.00 |        0    |    16124
        2  |  3:35.00 |  3:57.13 |    16125    |    33912
        3  |  7:32.13 |  3:16.00 |    33913    |    48612
        4  | 10:48.13 |  4:24.07 |    48613    |    68419
        5  | 15:12.20 |  3:06.58 |    68420    |    82427
        6  | 18:19.03 |  4:38.05 |    82428    |  103282
        7  | 22:57.08 |  4:17.40 |    103283    |  122597
        8  | 27:14.48 |  3:49.62 |    122598    |  139834
        9  | 31:04.35 |  3:40.38 |    139835    |  156372
      10  | 34:44.73 |  4:07.27 |    156373    |  174924
      11  | 38:52.25 |  5:27.43 |    174925    |  199492
Track  1
    Filename C:\Temp\Evanescence\Fallen\01 - Going Under.wav
    Peak level 99.8 %
    Copy CRC 0A5D7FD7
    Accurately ripped (confidence 25)  [8F535557]
    Copy OK
Track  2
    Filename C:\Temp\Evanescence\Fallen\02 - Bring Me to Life.wav
    Peak level 98.8 %
    Copy CRC 7BD5686D
    Accurately ripped (confidence 23)  [1750257E]
    Copy OK
Track  3
    Filename C:\Temp\Evanescence\Fallen\03 - Everybody's Fool.wav
    Peak level 99.8 %
    Copy CRC 3C47E62C
    Accurately ripped (confidence 22)  [E6CD1A8E]
    Copy OK
Track  4
    Filename C:\Temp\Evanescence\Fallen\04 - My Immortal.wav
    Peak level 96.5 %
    Copy CRC 5E440F68
    Accurately ripped (confidence 21)  [97FCA5B3]
    Copy OK
Track  5
    Filename C:\Temp\Evanescence\Fallen\05 - Haunted.wav
    Peak level 99.8 %
    Copy CRC FC5D40F2
    Accurately ripped (confidence 21)  [CFC95545]
    Copy OK
Track  6
    Filename C:\Temp\Evanescence\Fallen\06 - Tourniquet.wav
    Peak level 99.8 %
    Copy CRC 7F01C505
    Accurately ripped (confidence 22)  [955CFF00]
    Copy OK
Track  7
    Filename C:\Temp\Evanescence\Fallen\07 - Imaginary.wav
    Peak level 99.8 %
    Copy CRC 5560BECB
    Accurately ripped (confidence 22)  [ACB018DA]
    Copy OK
Track  8
    Filename C:\Temp\Evanescence\Fallen\08 - Taking Over Me.wav
    Peak level 99.8 %
    Copy CRC 1A882020
    Accurately ripped (confidence 22)  [775017CA]
    Copy OK
Track  9
    Filename C:\Temp\Evanescence\Fallen\09 - Hello.wav
    Peak level 98.1 %
    Copy CRC 31D8A32D
    Accurately ripped (confidence 21)  [E29E8A6B]
    Copy OK
Track 10
    Filename C:\Temp\Evanescence\Fallen\10 - My Last Breath.wav
    Peak level 99.8 %
    Copy CRC 258CA6F1
    Accurately ripped (confidence 21)  [FD64AEE0]
    Copy OK
Track 11
    Filename C:\Temp\Evanescence\Fallen\11 - Whisper.wav
    Peak level 99.8 %
    Copy CRC 6695FA1E
    Accurately ripped (confidence 18)  [CECBB17F]
    Copy OK
No errors occurred
EAC extraction logfile from 29. August 2007, 19:29
Seal / Best - 1991-2004 - CD 1, Original Version of the Hits
Read mode              : Secure
        1  |  0:00.00 |  5:56.62 |        0    |    26761
        2  |  5:56.62 |  4:48.50 |    26762    |    48411
        3  | 10:45.37 |  6:23.03 |    48412    |    77139
        4  | 17:08.40 |  5:30.55 |    77140    |  101944
        5  | 22:39.20 |  3:43.37 |    101945    |  118706
        6  | 26:22.57 |  6:19.38 |    118707    |  147169
        7  | 32:42.20 |  3:44.20 |    147170    |  163989
        8  | 36:26.40 |  4:38.00 |    163990    |  184839
        9  | 41:04.40 |  3:18.27 |    184840    |  199716
      10  | 44:22.67 |  3:58.25 |    199717    |  217591
      11  | 48:21.17 |  4:14.15 |    217592    |  236656
      12  | 52:35.32 |  5:02.05 |    236657    |  259311
      13  | 57:37.37 |  4:35.48 |    259312    |  279984
      14  | 62:13.10 |  4:19.32 |    279985    |  299441
Track  1
    Filename C:\Temp\Seal\Best - 1991-2004 - CD 1, Original Version of the Hits\01 - Crazy.wav
    Peak level 98.8 %
    Copy CRC 9A09DC9D
    Accurately ripped (confidence 24)  [FCF54520]
    Copy OK
Track  2
    Filename C:\Temp\Seal\Best - 1991-2004 - CD 1, Original Version of the Hits\02 - Kiss from a Rose.wav
    Peak level 98.1 %
    Copy CRC A8E0D10E
    Accurately ripped (confidence 24)  [748E7E47]
    Copy OK
Track  3
    Filename C:\Temp\Seal\Best - 1991-2004 - CD 1, Original Version of the Hits\03 - Killer.wav
    Peak level 98.8 %
    Copy CRC D7501DE9
    Accurately ripped (confidence 24)  [8BADC9FF]
    Copy OK
Track  4
    Filename C:\Temp\Seal\Best - 1991-2004 - CD 1, Original Version of the Hits\04 - Prayer for the Dying.wav
    Peak level 98.8 %
    Copy CRC 696C3EBA
    Accurately ripped (confidence 25)  [8D9BCE26]
    Copy OK
Track  5
    Filename C:\Temp\Seal\Best - 1991-2004 - CD 1, Original Version of the Hits\05 - Waiting for You.wav
    Peak level 98.7 %
    Copy CRC A4A355E1
    Accurately ripped (confidence 25)  [C81370ED]
    Copy OK
Track  6
    Filename C:\Temp\Seal\Best - 1991-2004 - CD 1, Original Version of the Hits\06 - Don't Cry.wav
    Peak level 98.8 %
    Copy CRC 9B6F4E02
    Accurately ripped (confidence 25)  [66DD7112]
    Copy OK
Track  7
    Filename C:\Temp\Seal\Best - 1991-2004 - CD 1, Original Version of the Hits\07 - My Vision (feat. Jakatta).wav
    Peak level 98.8 %
    Copy CRC CB363440
    Accurately ripped (confidence 25)  [8ED72E78]
    Copy OK
Track  8
    Filename C:\Temp\Seal\Best - 1991-2004 - CD 1, Original Version of the Hits\08 - Love's Divine.wav
    Peak level 96.0 %
    Copy CRC 6C99AAC8
    Accurately ripped (confidence 25)  [47957393]
    Copy OK
Track  9
    Filename C:\Temp\Seal\Best - 1991-2004 - CD 1, Original Version of the Hits\09 - Walk On By.wav
    Peak level 98.8 %
    Copy CRC 2151D9B2
    Accurately ripped (confidence 25)  [F053DDBB]
    Copy OK
Track 10
    Filename C:\Temp\Seal\Best - 1991-2004 - CD 1, Original Version of the Hits\10 - Get It Together.wav
    Peak level 100.0 %
    Copy CRC 6DE7AF7C
    Accurately ripped (confidence 25)  [EBC5B6E4]
    Copy OK
Track 11
    Filename C:\Temp\Seal\Best - 1991-2004 - CD 1, Original Version of the Hits\11 - Fly Like an Eagle.wav
    Peak level 98.8 %
    Copy CRC 50E97707
    Accurately ripped (confidence 25)  [0F8CBA14]
    Copy OK
Track 12
    Filename C:\Temp\Seal\Best - 1991-2004 - CD 1, Original Version of the Hits\12 - Lips Like Sugar (feat. Mikey Dread).wav
    Peak level 97.3 %
    Copy CRC 30200E7F
    Accurately ripped (confidence 25)  [5891D004]
    Copy OK
Track 13
    Filename C:\Temp\Seal\Best - 1991-2004 - CD 1, Original Version of the Hits\13 - Human Beings.wav
    Peak level 98.8 %
    Copy CRC 12F4E777
    Accurately ripped (confidence 25)  [4EDCF3C9]
    Copy OK
Track 14
    Filename C:\Temp\Seal\Best - 1991-2004 - CD 1, Original Version of the Hits\14 - Future Love Paradise.wav
    Peak level 98.8 %
    Copy CRC D02965FA
    Accurately ripped (confidence 24)  [6E9DF9EF]
    Copy OK
No errors occurred
EAC extraction logfile from 29. August 2007, 19:59
Seal / Best - 1991-2004 - CD 2, Acoustic Album
Read mode              : Secure
        1  |  0:00.00 |  4:46.20 |        0    |    21469
        2  |  4:46.20 |  5:39.35 |    21470    |    46929
        3  | 10:25.55 |  4:04.65 |    46930    |    65294
        4  | 14:30.45 |  5:34.57 |    65295    |    90401
        5  | 20:05.27 |  5:25.23 |    90402    |  114799
        6  | 25:30.50 |  5:19.32 |    114800    |  138756
        7  | 30:50.07 |  4:45.65 |    138757    |  160196
        8  | 35:35.72 |  4:36.25 |    160197    |  180921
        9  | 40:12.22 |  5:13.58 |    180922    |  204454
      10  | 45:26.05 |  6:03.45 |    204455    |  231724
      11  | 51:29.50 |  3:51.62 |    231725    |  249111
      12  | 55:21.37 |  6:27.30 |    249112    |  278166
      13  | 61:48.67 |  3:05.13 |    278167    |  292054
Track  1
    Filename C:\Temp\Seal\Best - 1991-2004 - CD 2, Acoustic Album\01 - Bring It On.wav
    Peak level 98.8 %
    Copy CRC E24D3231
    Accurately ripped (confidence 11)  [A410DFE3]
    Copy OK
Track  2
    Filename C:\Temp\Seal\Best - 1991-2004 - CD 2, Acoustic Album\02 - Killer.wav
    Peak level 98.8 %
    Copy CRC 6EA5982A
    Accurately ripped (confidence 11)  [ED7F8907]
    Copy OK
Track  3
    Filename C:\Temp\Seal\Best - 1991-2004 - CD 2, Acoustic Album\03 - Crazy.wav
    Peak level 98.8 %
    Copy CRC D92F6397
    Accurately ripped (confidence 11)  [3BE4135A]
    Copy OK
Track  4
    Filename C:\Temp\Seal\Best - 1991-2004 - CD 2, Acoustic Album\04 - Colour.wav
    Peak level 98.8 %
    Copy CRC CA74F0E1
    Accurately ripped (confidence 11)  [025581D7]
    Copy OK
Track  5
    Filename C:\Temp\Seal\Best - 1991-2004 - CD 2, Acoustic Album\05 - Kiss from a Rose.wav
    Peak level 98.8 %
    Copy CRC 6DB8FE8C
    Accurately ripped (confidence 11)  [7757AD41]
    Copy OK
Track  6
    Filename C:\Temp\Seal\Best - 1991-2004 - CD 2, Acoustic Album\06 - Prayer for the Dying.wav
    Peak level 98.8 %
    Copy CRC E48963E4
    Accurately ripped (confidence 11)  [5FB78ADB]
    Copy OK
Track  7
    Filename C:\Temp\Seal\Best - 1991-2004 - CD 2, Acoustic Album\07 - Love's Divine.wav
    Peak level 98.8 %
    Copy CRC 4A085372
    Accurately ripped (confidence 11)  [2AE56A39]
    Copy OK
Track  8
    Filename C:\Temp\Seal\Best - 1991-2004 - CD 2, Acoustic Album\08 - Get It Together.wav
    Peak level 98.8 %
    Copy CRC 640A24E6
    Accurately ripped (confidence 11)  [ACC9C76F]
    Copy OK
Track  9
    Filename C:\Temp\Seal\Best - 1991-2004 - CD 2, Acoustic Album\09 - Just Like You Said.wav
    Peak level 98.8 %
    Copy CRC 463F2672
    Accurately ripped (confidence 11)  [23B36E72]
    Copy OK
Track 10
    Filename C:\Temp\Seal\Best - 1991-2004 - CD 2, Acoustic Album\10 - Touch.wav
    Peak level 98.8 %
    Copy CRC E56EAEDE
    Accurately ripped (confidence 11)  [4F31BF05]
    Copy OK
Track 11
    Filename C:\Temp\Seal\Best - 1991-2004 - CD 2, Acoustic Album\11 - Waiting for You.wav
    Peak level 98.8 %
    Copy CRC 3CDE76FB
    Accurately ripped (confidence 11)  [2BBE3C77]
    Copy OK
Track 12
    Filename C:\Temp\Seal\Best - 1991-2004 - CD 2, Acoustic Album\12 - Don't Cry.wav
    Peak level 98.8 %
    Copy CRC 2E10D4A6
    Accurately ripped (confidence 11)  [3C78739A]
    Copy OK
Track 13
    Filename C:\Temp\Seal\Best - 1991-2004 - CD 2, Acoustic Album\13 - Walk On By.wav
    Peak level 99.8 %
    Copy CRC 19020FE4
    Accurately ripped (confidence 10)  [0483DEC4]
    Copy OK
No errors occurred
EAC extraction logfile from 30. August 2007, 11:12
Supertramp / Crime of the Century
Read mode              : Secure
        1  |  0:00.00 |  5:33.72 |        0    |    25046
        2  |  5:33.72 |  4:31.48 |    25047    |    45419
        3  | 10:05.45 |  6:48.37 |    45420    |    76056
        4  | 16:54.07 |  6:45.23 |    76057    |  106454
        5  | 23:39.30 |  3:24.65 |    106455    |  121819
        6  | 27:04.20 |  7:26.50 |    121820    |  155319
        7  | 34:30.70 |  4:05.00 |    155320    |  173694
        8  | 38:35.70 |  5:39.35 |    173695    |  199154
Track  1
    Filename C:\Temp\Supertramp\Crime of the Century\01 - School.wav
    Peak level 79.3 %
    Copy CRC 94C78791
    Accurately ripped (confidence 6)  [F0F4FDCD]
    Copy OK
Track  2
    Filename C:\Temp\Supertramp\Crime of the Century\02 - Bloody Well Right.wav
    Peak level 85.1 %
    Copy CRC C3F9D6A2
    Accurately ripped (confidence 6)  [F9309F5B]
    Copy OK
Track  3
    Filename C:\Temp\Supertramp\Crime of the Century\03 - Hide in Your Shell.wav
    Peak level 66.3 %
    Copy CRC 8E388D50
    Accurately ripped (confidence 6)  [CD6D2E05]
    Copy OK
Track  4
    Filename C:\Temp\Supertramp\Crime of the Century\04 - Asylum.wav
    Peak level 64.6 %
    Copy CRC 70AF4ED9
    Accurately ripped (confidence 6)  [0E93E8B9]
    Copy OK
Track  5
    Filename C:\Temp\Supertramp\Crime of the Century\05 - Dreamer.wav
    Peak level 67.5 %
    Copy CRC 542D005F
    Accurately ripped (confidence 6)  [6E59606C]
    Copy OK
Track  6
    Filename C:\Temp\Supertramp\Crime of the Century\06 - Rudy.wav
    Peak level 86.2 %
    Copy CRC B1FE182F
    Accurately ripped (confidence 6)  [80969677]
    Copy OK
Track  7
    Filename C:\Temp\Supertramp\Crime of the Century\07 - If Everyone Was Listening.wav
    Peak level 94.3 %
    Copy CRC 8CA4E091
    Accurately ripped (confidence 6)  [02FF2059]
    Copy OK
Track  8
    Filename C:\Temp\Supertramp\Crime of the Century\08 - Crime of the Century.wav
    Peak level 70.6 %
    Copy CRC AD5BC3A3
    Accurately ripped (confidence 3)  [DAB93468]
    Copy OK
No errors occurred
And here are the 5 CD images:
EAC extraction logfile from 24. August 2007, 20:33
Rolling Stones / Forty Licks (CD 1)
Read mode              : Secure
        1  |  0:00.00 |  3:16.32 |        0    |    14731
        2  |  3:16.32 |  4:32.63 |    14732    |    35194
        3  |  7:49.20 |  3:44.00 |    35195    |    51994
        4  | 11:33.20 |  3:42.10 |    51995    |    68654
        5  | 15:15.30 |  3:43.05 |    68655    |    85384
        6  | 18:58.35 |  7:29.60 |    85385    |  119119
        7  | 26:28.20 |  3:57.65 |    119120    |  136959
        8  | 30:26.10 |  3:42.20 |    136960    |  153629
        9  | 34:08.30 |  1:49.10 |    153630    |  161814
      10  | 35:57.40 |  2:36.57 |    161815    |  173571
      11  | 38:34.22 |  6:18.38 |    173572    |  201959
      12  | 44:52.60 |  2:47.72 |    201960    |  214556
      13  | 47:40.57 |  4:13.08 |    214557    |  233539
      14  | 51:53.65 |  2:56.52 |    233540    |  246791
      15  | 54:50.42 |  5:45.00 |    246792    |  272666
      16  | 60:35.42 |  3:15.30 |    272667    |  287321
      17  | 63:50.72 |  3:45.73 |    287322    |  304269
      18  | 67:36.70 |  3:01.25 |    304270    |  317869
      19  | 70:38.20 |  3:28.00 |    317870    |  333469
      20  | 74:06.20 |  3:27.60 |    333470    |  349054
Selected range
    Filename G:\CD Images\Rolling Stones - Forty Licks (CD 1) - 2002.wav
    Peak level 99.8 %
    Copy CRC 22471B44
    Copy OK
No errors occurred
AccurateRip summary
Track  1  accurately ripped (confidence 30)  [EA2F04F9]
Track  2  accurately ripped (confidence 28)  [AC03CE73]
Track  3  accurately ripped (confidence 28)  [D4733314]
Track  4  accurately ripped (confidence 29)  [D38D5CB0]
Track  5  accurately ripped (confidence 29)  [1F517501]
Track  6  accurately ripped (confidence 28)  [CE8645DE]
Track  7  accurately ripped (confidence 29)  [C5CFD06C]
Track  8  accurately ripped (confidence 29)  [5BC37E18]
Track  9  accurately ripped (confidence 29)  [8803DE9D]
Track 10  accurately ripped (confidence 28)  [9ABA04B9]
Track 11  accurately ripped (confidence 29)  [60A212EA]
Track 12  accurately ripped (confidence 29)  [998DD647]
Track 13  accurately ripped (confidence 29)  [EA005CBA]
Track 14  accurately ripped (confidence 29)  [5E4BCC21]
Track 15  accurately ripped (confidence 28)  [F2DC797D]
Track 16  accurately ripped (confidence 28)  [4F7915C1]
Track 17  accurately ripped (confidence 29)  [168C81B8]
Track 18  accurately ripped (confidence 28)  [A80F2005]
Track 19  accurately ripped (confidence 28)  [B4622446]
Track 20  accurately ripped (confidence 28)  [1B2FDC9F]
EAC extraction logfile from 24. August 2007, 20:55
Rolling Stones / Forty Licks (CD 2)
Read mode              : Secure
        1  |  0:00.00 |  3:33.10 |        0    |    15984
        2  |  3:33.10 |  3:49.50 |    15985    |    33209
        3  |  7:22.60 |  3:35.20 |    33210    |    49354
        4  | 10:58.05 |  3:27.70 |    49355    |    64949
        5  | 14:26.00 |  3:58.60 |    64950    |    82859
        6  | 18:24.60 |  3:05.10 |    82860    |    96744
        7  | 21:29.70 |  4:31.70 |    96745    |  117139
        8  | 26:01.65 |  3:33.70 |    117140    |  133184
        9  | 29:35.60 |  3:46.37 |    133185    |  150171
      10  | 33:22.22 |  4:07.60 |    150172    |  168756
      11  | 37:30.07 |  3:48.30 |    168757    |  185886
      12  | 41:18.37 |  4:01.25 |    185887    |  203986
      13  | 45:19.62 |  4:12.08 |    203987    |  222894
      14  | 49:31.70 |  4:07.52 |    222895    |  241471
      15  | 53:39.47 |  3:42.23 |    241472    |  258144
      16  | 57:21.70 |  3:46.60 |    258145    |  275154
      17  | 61:08.55 |  4:13.22 |    275155    |  294151
      18  | 65:22.02 |  3:42.05 |    294152    |  310806
      19  | 69:04.07 |  4:10.08 |    310807    |  329564
      20  | 73:14.15 |  5:06.00 |    329565    |  352514
Selected range
    Filename G:\CD Images\Rolling Stones - Forty Licks (CD 2) - 2002.wav
    Peak level 99.8 %
    Copy CRC FFE947C8
    Copy OK
No errors occurred
AccurateRip summary
Track  1  accurately ripped (confidence 79)  [CB54D835]
Track  2  accurately ripped (confidence 82)  [6C72D636]
Track  3  accurately ripped (confidence 82)  [BD79229D]
Track  4  accurately ripped (confidence 81)  [F2FD602C]
Track  5  accurately ripped (confidence 80)  [829D3B7B]
Track  6  accurately ripped (confidence 82)  [7C7E0A7C]
Track  7  accurately ripped (confidence 82)  [D4400E1E]
Track  8  accurately ripped (confidence 81)  [CE680CCA]
Track  9  accurately ripped (confidence 81)  [4E51D780]
Track 10  accurately ripped (confidence 80)  [9878A8AF]
Track 11  accurately ripped (confidence 82)  [CD0EF4B0]
Track 12  accurately ripped (confidence 81)  [B9954114]
Track 13  accurately ripped (confidence 79)  [3DEE0F67]
Track 14  accurately ripped (confidence 78)  [E21BE270]
Track 15  accurately ripped (confidence 79)  [EDD88C51]
Track 16  accurately ripped (confidence 81)  [6B9B50F5]
Track 17  accurately ripped (confidence 78)  [13E02DC4]
Track 18  accurately ripped (confidence 78)  [5FC3AF4F]
Track 19  accurately ripped (confidence 78)  [CE0845CC]
Track 20  accurately ripped (confidence 70)  [24EE51D8]
EAC extraction logfile from 27. August 2007, 18:43
Foo Fighters / In Your Honor (CD 1)
Read mode              : Secure
        1  |  0:00.00 |  3:50.07 |        0    |    17256
        2  |  3:50.07 |  3:16.43 |    17257    |    31999
        3  |  7:06.50 |  4:15.47 |    32000    |    51171
        4  | 11:22.22 |  4:12.08 |    51172    |    70079
        5  | 15:34.30 |  1:57.00 |    70080    |    78854
        6  | 17:31.30 |  3:19.32 |    78855    |    93811
        7  | 20:50.62 |  4:38.45 |    93812    |  114706
        8  | 25:29.32 |  4:48.48 |    114707    |  136354
        9  | 30:18.05 |  3:58.25 |    136355    |  154229
      10  | 34:16.30 |  5:52.00 |    154230    |  180629
      11  | 42:40.30 |  4:42.67 |    192030    |  213246
Selected range
    Filename G:\CD Images\Foo Fighters - In Your Honor (CD 1) - 2005.wav
    Peak level 98.9 %
    Copy CRC FF709279
    Copy OK
No errors occurred
AccurateRip summary
Track  1  accurately ripped (confidence 56)  [EFD2E9DA]
Track  2  accurately ripped (confidence 56)  [9A38D132]
Track  3  accurately ripped (confidence 47)  [E12DF514]
Track  4  accurately ripped (confidence 56)  [E817586C]
Track  5  accurately ripped (confidence 56)  [DAFB06C2]
Track  6  accurately ripped (confidence 56)  [8031E267]
Track  7  accurately ripped (confidence 56)  [7BE1C10B]
Track  8  accurately ripped (confidence 56)  [51781BFE]
Track  9  accurately ripped (confidence 56)  [05D4E6A4]
Track 10  accurately ripped (confidence 55)  [ADA89339]
EAC extraction logfile from 27. August 2007, 19:13
Foo Fighters / In Your Honor (CD 2)
Read mode              : Secure
        1  |  0:00.00 |  5:13.07 |        0    |    23481
        2  |  5:13.07 |  5:02.68 |    23482    |    46199
        3  | 10:16.00 |  3:29.45 |    46200    |    61919
        4  | 13:45.45 |  4:25.57 |    61920    |    81851
        5  | 18:11.27 |  3:13.15 |    81852    |    96341
        6  | 21:24.42 |  5:16.13 |    96342    |  120054
        7  | 26:40.55 |  4:31.62 |    120055    |  140441
        8  | 31:12.42 |  3:49.08 |    140442    |  157624
        9  | 35:01.50 |  3:20.47 |    157625    |  172671
      10  | 38:22.22 |  4:53.13 |    172672    |  194659
      11  | 45:47.35 |  5:02.70 |    206060    |  228779
Selected range
    Filename G:\CD Images\Foo Fighters - In Your Honor (CD 2) - 2005.wav
    Peak level 98.8 %
    Copy CRC C27806D2
    Copy OK
No errors occurred
AccurateRip summary
Track  1  accurately ripped (confidence 52)  [8097A5D4]
Track  2  accurately ripped (confidence 52)  [09373D80]
Track  3  accurately ripped (confidence 51)  [18AF886F]
Track  4  accurately ripped (confidence 52)  [7861C3FF]
Track  5  accurately ripped (confidence 52)  [B779C2E6]
Track  6  accurately ripped (confidence 52)  [0027CD4B]
Track  7  accurately ripped (confidence 52)  [5E8F58E1]
Track  8  accurately ripped (confidence 51)  [45AE4EB9]
Track  9  accurately ripped (confidence 52)  [8FEB7FDD]
Track 10  accurately ripped (confidence 51)  [927B9874]
EAC extraction logfile from 28. August 2007, 21:00
Dire Straits & Mark Knopfler / The Best Of (Private Investigations)
Read mode              : Secure
        1  |  0:00.00 |  5:48.64 |        0    |    26163
        2  |  5:48.64 |  6:18.43 |    26164    |    54556
        3  | 12:07.32 |  6:00.43 |    54557    |    81599
        4  | 18:08.00 |  8:10.43 |    81600    |  118392
        5  | 26:18.43 |  5:59.14 |    118393    |  145331
        6  | 32:17.57 |  4:07.25 |    145332    |  163881
        7  | 36:25.07 |  6:59.32 |    163882    |  195338
        8  | 43:24.39 |  4:08.48 |    195339    |  213986
        9  | 47:33.12 |  5:04.51 |    213987    |  236837
      10  | 52:37.63 |  5:02.21 |    236838    |  259508
      11  | 57:40.09 |  4:09.23 |    259509    |  278206
      12  | 61:49.32 |  5:49.06 |    278207    |  304387
      13  | 67:38.38 |  4:56.54 |    304388    |  326641
      14  | 72:35.17 |  4:49.30 |    326642    |  348346
Selected range
    Filename G:\CD Images\Dire Straits & Mark Knopfler - The Best Of (Private Investigations) - 2005.wav
    Peak level 100.0 %
    Range quality 99.9 %
    Copy CRC C0AC98AE
    Copy OK
No errors occurred
AccurateRip summary
Track  1  accurately ripped (confidence 5)  [7EBA8B43]
Track  2  accurately ripped (confidence 5)  [2575AFDB]
Track  3  accurately ripped (confidence 5)  [B838FE5F]
Track  4  accurately ripped (confidence 5)  [61D45074]
Track  5  accurately ripped (confidence 5)  [6DFECCC0]
Track  6  accurately ripped (confidence 5)  [2C820276]
Track  7  accurately ripped (confidence 5)  [68C9FDF7]
Track  8  accurately ripped (confidence 5)  [F8A76665]
Track  9  accurately ripped (confidence 5)  [3CDB2B40]
Track 10  accurately ripped (confidence 4)  [CD952C81]
Track 11  accurately ripped (confidence 4)  [8A5A503F]
Track 12  accurately ripped (confidence 4)  [EB0D668B]
Track 13  accurately ripped (confidence 4)  [315D57FF]
Track 14  accurately ripped (confidence 4)  [788C1EBF]
George
EDIT: spoon, my e-mail to you just bounced. I'll try again using the e-mail address provided at http://www.dbpoweramp.com/email.htm.
Reply #97
I have the test results needed now, thanks
