Topic: Nero AAC & EAC Why Isn't This Working? (Read 28235 times) previous topic - next topic
ok i got the solution %s must be replaced by %source%, %d by %dest%
I really do not understand why you guys do this to yourselves. I just create the directory C:\bin and add it to the path. I put all of my console apps there. One place to look and when something needs to be updated I don't have to look for it.
It also turns this
"C:\Program Files\NeroDigitalAudio\neroAacEnc.exe"
in to this
C:\bin\neroAacEnc.exe
No quotes required. Add with that directory in the system path I can call the encoder manually by using just its name.
neroaacenc -q 4 -if test.wav -of test.m4a
edited formatting.
Eric
But that is not the problem. The placeholders were changed in EAC v 1.0b2, so the command-line must be altered accordingly, completely regardless of where the executable is.
This worked for me.
/c C:\"Program Files (x86)\#######\#######\encoder\m4a Nero (AAC)\neroAacEnc.exe" -q 1.00 -if %source% -of %dest% && C:\"Program Files (x86)\#######\#######\encoder\m4a Nero (AAC)\neroAacTag.exe" %dest% -meta:track="%numtracks%" -meta:artist="%artist%" -meta:album="%albumtitle%" -meta:title="%title%" -meta:year="%year%" -meta:composer="%albumcomposer%" -meta:genre="%genre%"
Exact Audio Copy V1.0 beta 3
EZ CD Audio Converter / FLAC or WavPack
Reply #30
@db1989
I understand that was not the problem in this case, but reading through the thread clearly shows conversation about spaces and quotes. Plus look at the command line just above this. Almost half of it is encoder path info. Cleaning up the easy stuff makes it easier to find problems when they arise.
Eric
Hi please help me, nothing work for me, I'm goin' crazy!!
