Topic: foobar2000 v0.9.4 (Read 24092 times) previous topic - next topic
foobar2000 v0.9.4
foobar2000 v0.9.4 final is out
Properties dialog improvements
Startup/shutdown speed optimizations
Added LAME version and partial settings detection for MP3 files
Replaced old “Fix MP3 Header” command with a new set of MP3-related utility commands
“ID3v2 Writer Compatibility Mode” with workarounds for common bugs in other software’s ID3v2 implementations
“Copy” button in components list
freedb support now included with the installer
Rewritten embedded cuesheet metadata handling
Rewritten ReplayGain info editor dialog
ABX bugfixes
Added WMA tag editing support
Get it: http://www.foobar2000.org
foobar2000 v0.9.4
foobar2000 v0.9.4
<----dumb.
(ie: Figured it out.  )
foobar2000 + EAC + Burrrn = Happiness
foobar2000 v0.9.4
just DLed it, and sry if I missed it but it seems like I cant use the album list as a panel anymore.  do i have to DL something else or is it something I I missed?
foobar2000 v0.9.4
lextune:
My trackinfomod panels still appear to be functioning properly, can you be more specific about what you mean by broken
SwiftBass:
My albumlist panel also still appears to work. In fact I just recently started using it because foo_browser was having a devistating affect on my startup times.
foobar2000 v0.9.4
- r3mix recognition does not work (tested with Lame 3.91 & 3.92)
- on some live mp3s I have cut off the end applause; codec_profile is not available for those
- enc_delay and enc_padding in 0.9.1:
in 0.9.4:
foobar2000 v0.9.4
Is it just me...But v0.9.4 continues to run after exiting the program.  I am running winxp on P4.  Foobar shows up in the task manager list after quiting program. If you run foobar again, it seams to start a new instance.  So when you check task manager after exiting the second time, there are two listing for foobar.
v0.9.3.1 works OK.
foobar2000 v0.9.4
Does the installer upgrade from 0.9.3.1? or should I uninstall first? If I uninstall, do I lose all my configs?
foobar2000 v0.9.4
I didn't have any adverse problems installing over 0.9.3.1 so its probably ok. As always though make sure all your components are updated.
foobar2000 v0.9.4
I install over the current version that i had... 0.9.4 beta 3 and i didnt uninstall i just put the final 0.9.4 and installed that with no porblems lost nothing.
foobar2000 v0.9.4
My albumlist panel working fine here
Thanks for the new version
-foobar2000 + Burrrn + EAC
-HD 80Gb using High QualityVBR MP3s
foobar2000 v0.9.4
thanks for new version  everything works perfectly
foobar2000 v0.9.4
Just wanna say thanks works great here.
foobar2000 v0.9.4
@ jonpb, you can just install right over it, just make sure "enable per-user settings" is not checked, it'll save your settings then. But it's always good to just backup anyways, you can do that by copying the foobar2000 program file folder and putting it somewhere else. Install and updated working fine for me, thx.
foobar2000 v0.9.4
It semms some times foobar will crash when edit tags on Properties dialog
foobar2000 v0.9.4
You should post this in a new thread, with specifics, such as exactly what you did to cause the crash, and the crashlog.
foobar2000 v0.9.4
I've seen this exactly the same on a win2000 computer/ fb2k 0.94b3. But I didn't hunt it down (it's also possible this was caused by a plugin, as I added some new of them). After a restart everything was fine...
foobar2000 v0.9.4
v0.9.3.1 works OK.
Most probably "foo_dsp_atsurround.dll" is causing it.
foobar2000 v0.9.4
v0.9.3.1 works OK.
maybe foo_dsp_headphones.dll causes it
foobar2000 v0.9.4
I haven't both.
Core (2006-09-23 16:18:46)
    foobar2000 core v0.9.4
foo_abx.dll (2006-09-23 16:17:38)
    ABX Comparator 1.3.1
foo_autoplaylist.dll (2006-08-04 21:56:56)
    Autoplaylist Manager 1.0
foo_cdda.dll (2006-09-23 16:17:20)
    CD Audio Decoder 2.1.1
foo_cmd_playlist.dll (2006-08-05 13:17:08)
    Playlist Commandline Tools 0.0.1
foo_common.dll (2006-03-11 19:23:54)
    Common services 0.1
foo_converter.dll (2006-09-23 16:17:02)
    Converter 1.0.1
foo_cwb_hooks.dll (2006-09-22 17:02:26)
    cwbowron's title format hooks 1.0.11 [Sep 22 2006 - 17:01:48]
foo_dsp_continuator.dll (2006-04-14 19:18:20)
    Continuator 0.4.0
foo_dsp_delta.dll (2006-03-21 18:16:22)
    LPCM <--> delta-PCM converter 0.1.1
foo_dsp_std.dll (2006-09-23 16:17:30)
    Standard DSP array 1.0
foo_dsp_vlevel.dll (2006-04-25 11:17:44)
    VLevel 20060324.0
foo_freedb2.dll (2006-08-29 20:43:04)
    freedb Tagger 0.5.2a
foo_fullscreen.dll (2006-04-01 23:10:14)
    Fullscreen 0.3.1
foo_input_monkey.dll (2006-08-04 21:57:00)
    Monkey's Audio decoder 2.1.1
foo_input_std.dll (2006-09-23 16:17:02)
    FLAC decoder 1.1.0
    Standard Input Array 1.0
    WMA Decoder 1.1
foo_masstag.dll (2006-09-23 16:16:28)
    Masstagger 1.6
foo_menu_addons.dll (2006-09-23 07:52:00)
    Menu Addons 0.3.4
foo_playlist_bind.dll (2006-04-06 15:52:24)
    Playlist Bind 2.2
foo_playlist_manager.dll (2006-03-13 00:25:14)
    Playlist Manager 1.0
foo_pqview.dll (2006-03-13 00:23:28)
foo_random.dll (2006-03-13 11:35:02)
    Randomized playlist entry 1.2.3
foo_rgscan.dll (2006-09-23 16:16:14)
    ReplayGain Scanner 2.0.2
foo_runcmd.dll (2006-07-25 11:38:00)
    Run Command 1.0 beta 1
foo_sic.dll (2006-08-22 12:55:00)
    foosic music database 1.0 beta 11
foo_ui_columns.dll (2006-09-08 13:14:31)
    Columns UI 0.1.3 beta 1v6 TEST
foo_ui_std.dll (2006-09-23 16:16:08)
    Default User Interface 0.9acc
foo_uie_bookmarks.dll (2006-09-15 00:26:00)
    Bookmarks 0.0.5.2
foo_uie_explorer.dll (2006-07-06 22:43:30)
    Explorer Tree 1.04.6b
foo_uie_queuemanager.dll (2006-08-26 09:16:58)
    Queue manager panel 0.2.1
foo_uie_quicksearch.dll (2006-08-27 15:13:00)
    Quick Search Toolbar 2.8h
foo_uie_tabs.dll (2006-07-08 04:18:32)
    Tabbed panel modifyed 0.2.1
foo_uie_trackinfo.dll (2006-07-25 04:30:16)
    Track info panel 0.82
foo_uie_trackinfo_mod.dll (2006-08-30 16:36:18)
    Track info panel mod 0.5 beta [Aug 30 2006 - 16:35:44]
foo_unpack.dll (2006-09-23 16:17:50)
    RAR reader 1.1
    ZIP/GZIP reader 1.0
foo_utils.dll (2006-04-27 12:37:32)
    Playlist tools 0.5.7
foobar2000 v0.9.4
I do have foo_dsp_atsurround installed but not foo_dsp_headphones.  I'll try it again later without and post back.  Thanks.
foobar2000 v0.9.4
silly me.  all of my uodates have left my components intact so i guess that albumlist.dll was not a default.  it was the first dll i downloaded and i guess i forgot to DL one.  sry bout that
foobar2000 v0.9.4
I lost everything. No I have to redo hours of work. :(
EDIT
WOOHO!!
SYSTEM RESTORE + deleting user_profiles_enabled.
foobar2000 v0.9.4
works like a charm here - great work peter as usual - any idea whats installed for 0.9.5?
