Topic: foo_run (Read 595033 times) previous topic - next topic
foo_run 0.3.7
It works here as well. The issue that the assigned shortcuts list only displays "Run Service" will be fixed in 0.9.2 beta 5.
Well, It's good to know that, thanks foosion.
foo_run 0.3.7
This is one of the few plugins I've been impatiently waiting since I switched to 0.9. Really makes things a lot smoother, thanks!
foo_run 0.3.7
I love this. Was missing Messer's foo_web with 0.9 I can't get it to search for anything but the first word on Amazon. This is the string I was using for foo_web:
http://www.amazon.com/exec/obidos/external-search/026-3231160-0094028?mode=music&keyword=%artist%+%album%&tag
foo_run 0.3.7
Try this instead:
http://www.amazon.com/exec/obidos/external-search/026-3231160-0094028?mode=music&keyword=$replace(%artist% %album%,' ','+')&tag
Unless I messed up, that should replace all the spaces in the artist and album names with plus signs.
foo_run 0.3.7
Thanks, it works
foo_run 0.3.7
Reply #30
This is an awesome port, so many things you can do with it
foo_run 0.3.7
I have a request concerning the context-menu-entries of foo_run.
Could every command be implemented as for example "Run:Cover", so that you don't only have the "Run"-entry which then extends to all you commands?
foo_run 0.3.7
somehow a little more nifty string for 'Open Directory'
explorer /select, "$substr(%_path%,0,$strrchr(%_path%,'\'))%filename_ext%"
foo_run 0.3.7
Reply #34
well I was wondering that too...
These were the default codes  and I remember that I've tried something like 'totalcmd.exe %_path%' and didn't work
Anyway it works now ... both ways
foo_run 0.3.7
Reply #35
I've just released foo_run 0.3.1. Changelog and download links are at the first post of this topic.
Edit: Thanks to all for the nice feedback
foo_run 0.3.7
Reply #36
Here's my generous contribution:
Mr QuestionMan
"C:\Program Files\Mr QuestionMan.exe" "$substr(%_path%,0,$strrchr(%_path%,'\'))"
Thanks Florian.
I'm on a horse.
foo_run 0.3.7
Reply #37
Florian, thank you for working on this component. Have you seen my post?
foo_run 0.3.7
Reply #38
Sure, but I have no idea how to achieve this with the foobar2000 SDK (except for putting all entries in the root menu, which would be very ugly).
foo_run 0.3.7
Reply #39
Would it really be ugly? Since you don't have to add the root entries by default. Rather add them, if the user wishes so.
Ideal situation:
- have the run-menuitem, as it's now (added as standard, if the component is installed)
- have the run:"Item"-menuitems available in the commands list (however not added to the context-menu by standard)
What do you think of this idea?
foo_run 0.3.7
Reply #40
thanks for this great plugin mate
"Allmusic Artist" etc. is absolutely suuuuuper!
foo_run 0.3.7
Reply #41
Also a thank you from me
2 suggestions
- add a move up/down option
- I guess it's in principle the same, user 'm-z' asked on the first page; in 0.8.3 I used foo_openwith to send files to mp3gain, now only the first of the checked items is send to this program
foo_run 0.3.7
Reply #42
That's what the slider simultaneous runs is for...
foo_run 0.3.7
Reply #43
Hi!
I want to run a programme. The command must contain the path of the 2 files which i have selected in the playlist.
C:\WINDIFF.EXE path_1 path_2
is this possible?
Thank you!
foo_run 0.3.7
Reply #44
I don't think so. 'Simultaneous runs' opens x instances of the program, so when the slider is at 10 and I mark 10 songs, 10 instances of mp3gain open, each with one song, but I would like those 10 songs in 1 instance
foo_run 0.3.7
Reply #45
Just out of curiosity, why would you need mp3gain if foobar2000 can do exactly the same for quite some time now?
foo_run 0.3.7
Reply #46
What if I want to play my music on a DVD player, in my car, my hardware mp3 player....in these cases foobar does not do "exactly the same" thing as mp3gain, or did I miss something?
foo_run 0.3.7
Reply #47
I think you did
Right click>Replaygain>Apply to MP3 data
foo_run 0.3.7
Reply #48
Indeed...thanks for the enlightenment
So now I'm wishless and happy
foo_run 0.3.7
Reply #49
Hello,
I like foobar2000 and foorun. But many of my files have ac3 which sounds better in Winamp than in foobar due to the plugin "Valex's AC3 decoder forWinamp". Is there a possibility with "foorun" to play ac3-files directly in Winamp. I have added "Open with Winamp" and the path "F:\Programme\Audio_Tools\Winamp\winamp.exe".
But this opens Winamp without playing the file.
Regards
Robbi
