Topic: Is this r3mix.net? (Read 25535 times) previous topic - next topic
Is this r3mix.net?
Originally posted by rjamorim
Sorry, Dors, but you won't find tolerance here. I gave up searching long ago.
I disagree. IMO it shows great tolerance that this site covers many different formats, different bitrates, people using many different software are adviced here, without bigger flamewars (except maybe very rarely). IMO what is not tolerated is false info, spamming, and unjustified claims.
Every opinion is tolerated here, but if it's a wild claim without proofs, that's a different thing.
Juha Laaksonheimo
Is this r3mix.net?
This from a newbie who has just completed 5 months of hard research into audio compression:
Originally posted by cmyden
I just wrote an e-mail to satcp begging him to update the info.
Here, Here.  SatCP's tutorial was invaluable to me, especially the links, but needs updating.
Originally posted by Dibrom
R3mix.net is not about quality.  It's not about objectivity.  And despite it's banners which say the opposite, it's not about the search for the truth.
These 'banners' retarded my search for a while.  As I posted somewhere yesterday, the reason I am a member here is because I trust the information to be accurate.  And quality really matters.
Originally posted by dors
I still recommend it to newbies, as I feel that HA is a bit too techie sometimes.
How could you do that, and not in the same breath send people here?  Had I been sent here sooner it would saved me at least a month and a half - and I would probably be 90 days ahead of where I am now.  It's dangerous to put people in a box.
So, you can go ahead and still point newbies to r3mix.net if you please.  I think you're doing them a disservice though, because it's starting them off on the wrong foot.   Additionally, they'll also not be exposed to any of the latest developments in the audio encoding community, or to any of the significantly better alternatives to mp3 (Ogg Vorbis, MPC, or AAC), even when using the --alt-presets.
Indeed.[/b]  Well said.
Is this r3mix.net?
Originally posted by Garf
That's the problem...a lot of newbies do exactly that.
??? I just don't get it. WHY is it a "problem"? If my neighbor thinks that Blade, Xing, or r3mix is CD quality, why should that be a problem? It's his music - not mine. Are we hinting around about getting inferior pirated encodes? :eek:
Is this r3mix.net?
I don't mean to start any flaming, just archiving every link I can find in order to answer more quickly and more accurately when the question is asked.
Is there already somewhere a test result showing that --alt-preset 160 or 170, something like that, is better than --r3mix ?
Is this r3mix.net?
It's a problem cuz a newbie like me reads it, it seems definitive and we start encoding away at r3mix, and then later found out we wasted our time cuz there's a better way.
I know it's my problem for not researching more, but purposely leaving up false or inaccurate info is not cool.
Is this r3mix.net?
Reply #30
Well, if you already think 128kbps is transparent, I see no sense in restarting encoding because someone else said there is a better way. If you always goes with what someone else says, you won't ever finish encoding your CD collection.
What I mean: If you have all your encodings in --r3mix and you are satisfied with that, why reencode with --aps? There will be no difference for you.
Is this r3mix.net?
It's that whole thing about learning how to hear artifacts. I used to encode all my mp3's using l3enc at 128kbps, and I was perfectly happy with them. Now, a good deal of 160kbps cbr mp3's have enough artifacts to irritate me.
There's no reason to tolerate screechy 128kbps MP3's when you can have >99% transparency without much more trouble. Even r3mix doesn't have to be "tolerated". I've only successfully ABX'ed a couple of my 100-or-so r3mix MP3's (perhaps a critical listening test could flush out some more, but frankly I don't care that much, and I'd rather not face the fact that I probably couldn't hear more of a difference anyway ). On one hand, the music mostly sounds perfect, so who cares if a couple are slightly flawed? On the other, I could have used the --alt-presets and gained a little more fidelity at about the same bitrate.
I'm not costing myself any more money by using --alt-preset instead of --r3mix, I'm not hurting the environment, and I'm not damning myself to hell. I'm just getting a better MP3. To promote a substandard preset as "the best" is to scam the public.
[span style='font-size:9'](Of course, there are benefits to --r3mix, such as a slightly lower bitrate and a faster encoding time. But r3mix.net should just admit that those are the only benefits!)[/span]
Is this r3mix.net?
OK. And when you learn to hear --aps artifacts? Then what?
[span style='font-size:9']1500 posts![/span]
Is this r3mix.net?
Reply #33
As a newbie who got here only after finding r3mix.net, I agree with IveyLeaguer:  I wish I'd found HA first and I'd be disappointed if someone who knew about HA sent me elsewhere because they didn't think this site was newbie-friendly(from a technical standpoint)
Roberto, I agree that trying to keep up with the Joneses is pointless if you've found a format and quality that works for you.  But this is another newbie specific situation....As we start learning what artifacts to listen for and actually being able to pick them out, very quickly some of those formerly "transparent" songs may not sound so great.  I'd hate to have several thousand newly created --r3mix files when that happened.
Yeah, when you call my name
I salivate like a Pavlov dog...
Is this r3mix.net?
Reply #34
Originally posted by pantheranddawg
What was OK yesterday may sound awful today
Going with that train of thought, the only solution is lossless.
Is this r3mix.net?
Reply #35
I disagree.  If I truly start hearing artifacts in more than a few aps files,  I wouldn't hesitate to go alt-preset extreme.  But going lossless isn't the natural extension of climbing the newbie learning curve and being dissatisfied with something you previously thought was transparent.  This doesn't fly in the face of what you said about not bothering with overkill if you're satisfied.  My comments are specific to those just learning to recognize artifacts in lossy compressed audio.
That said , I admit that everything I've got is lossless right now  cause 1)I've got the space and 2) I haven't decided on a lossless format and 3)I'm lazy sometimes....
Is this r3mix.net?
Reply #36
See?
You've already reached the final evolutional step.
Is this r3mix.net?
Reply #37
what is better, --ape or cbr 320?
"You can fight without ever winning, but never win without a fight."  Neil Peart  'Resist'
Is this r3mix.net?
Reply #38
--api, that is CBR 320 btw.
Is this r3mix.net?
Reply #39
[As we start learning what artifacts to listen for and actually being able to pick them out, very quickly some of those formerly "transparent" songs may not sound so great.  I'd hate to have several thousand newly created --r3mix files when that happened.
I've found a workaround: *Reencode* 10-20 of ur favourite songs (but of coz don't delete the originals) with vorbis -q-1 and hear those all nights before going to sleep for a week, at least. Voilaa! Your ears restored to the previous (and satisfactorial!) state of not caring atall about artifacts
Is this r3mix.net?
Reply #40
This has already been outlined well enough, but I'll reiterate it anyway.
HA is here to help people learn how to work with audio compression.  It's here to increase the knowledge base and to provide a place for relatively BS-free quality discussion.  It's a place for people to perform objective testing, and share information.
Spreading false truths and misinformation goes completely against the whole idea here.  It also goes against what most people want who are trying to learn about this stuff.  As mentioned by some previous posters, the fact that r3mix.net masquerades as being some sort of source of factual information is harmful to people trying to get valid information.  It wastes their time and gives them the wrong ideas.  It promotes poor testing methodology (did you see some of the comments on slashdot and arstechnica about ff123s test?) within the audio community, and eventually, it hampers progress.
Surely you can see this.  If you feel that none of the above points are worth anything, and I'm not saying that's what you are implying, but if you don't understand why these are good things and why what r3mix.net stands for is not, then I'm not quite sure what you see in this community as a whole.  I don't understand where the desire to participate would stem from.
Well again, that's not the problem.  The problem is when people put up information which is inaccurate and then play it off as being the absolute truth.  This does a disservice to everyone trying to learn about this stuff, especially people who don't know enough to be aware of the fact that the information is false.
Of course, a person can do whatever they want to on their website.  They can put up all the false information they like.  There's really nothing to stop them.  It's not in good spirit though, and so I don't think that fits in with this community, or with what most people learning about this are looking for.  It's not cool to deceive people for no reason at all, other than to feed your own ego.
And please don't start making accusations or implications linking this to piracy.  It's a flat out insult to do so, and it's completely unfounded.  This concern is made in the spirit of providing accurate information and providing a good knowledge base to others so that everyone can benefit.  It's kind of sad to think that people couldn't recognize that on it's on merit and must instead think that this notion is selfish and somehow related to the desire for higher quality pirated music
Is this r3mix.net?
Reply #41
Most of the people here have a desire to learn.  With that learning comes a higher degree of awareness of many of the issues involved with audio encoding.  And with that usually comes a greater ability to detect artifacts in compressed audio.  It's only natural, then, that people would also want to find a way to improve the quality of their encodings.  There's nothing wrong with this, just as their's nothing wrong with people learning about normal audio quality and eventually graduating to better sound systems, higher quality music, etc.  If we all took the "let's bury our head in the sand" approach, there would be no progress at all.  We'd all be using Blade.  And to provide an example closer to home, AAC wouldn't even exist.
This is really analogous to the whole "Igorance is Bliss thing".  Well, I don't buy into that.  I don't think most other people who have tasted knowledge do either.
There's always room for learning, and there's always room for improvement.  People who aren't interested in that can just kindly step out of the way, because I'm sure as hell not going to wait up for them in my own personal quest towards something better.
Is this r3mix.net?
Reply #42
Well first of all, --aps will have far fewer artifacts than --r3mix.  That alone should not be overlooked simply because it still may not be perfect.
--aps is better than --r3mix, and just because it's not perfect does not lessen this to any degree.
And if someone needs something better than --aps, then luckily there are solutions: MPC, AAC, and in some cases Ogg Vorbis.
Yes, it's possible to always want more, but it's this desire that also drives projects forward and creates progress.  If we all just sit idly by and become "satisfied", then nobody will ever provide something better.
Maybe some people could be happy with this, but I'm not one of them.  I suspect most of the people at HA are here because they aren't either.
Is this r3mix.net?
Reply #43
That would be the easy way out.
The other solution would be to improve the existing options, or to create something new and even better than before.
Is this r3mix.net?
Reply #45
r3mix WAS great!
I came there as a newbie and now I know enough to help others.
If it wasn't for the r3mix forum  I wouldn't be here and this community evolved with alot of the ppl that used to go there.
Roel did a lot of good; his mistake was not to see when others did better.
Is this r3mix.net?
Reply #46
rjamorim,
I understand that --api is cbr 320, but that applies the presets tunings, doesn't it?  Would just straight cbr 320 (ie, from the lame dll) offer any advantages or disadvantages?
Is this r3mix.net?
Reply #47
The problem is "simple"... Remove the --r3mix switch in the next version of Lame and print out a message that recommends --alt-preset standard in case someone tries to use "the old shit"...
Is this r3mix.net?
Reply #48
@dreamliner77
Yes, --api does use Dibrom's tuned preset and will provide far better quality than simply using CBR 320. Clearly, there will be no real difference in file size, but Dibrom's tunings will provide much better audio quality.
@Sachankara
It would probably be better to add a note when --r3mix is invoked saying that "The use of this preset is deprecated, the use of the --alt-presets is recommended.":D
Is this r3mix.net?
Reply #49
I tried accessing the r3mix.net forum today:
"This Account Has Been Suspended Until Further Notice
Please contact the Xnull billing/support department as soon as possible.
Possible reasons for suspension are usually failure to pay bills, failure to reply to contact attempts, and/or failure to comply to Xnull's Acceptable Use Policy."
