Topic: Burning Compressed Cue Sheet (Read 15242 times) previous topic - next topic
Is there a way to burn a compressed cue sheet? I get an error when trying to load the cue sheet in EAC:
Error in CUE sheet !
File type is not supported in line 3
Line 3 reads:
FILE "Vertical Horizon - Everything You Want.mpc" WAVE
I also tried to load the cue in Daemon Tools and I get a similar error. I know that I could just covert the mpc to a wave, but I'd rather skip that step if possible. I'd like to store my Cds as compressed mpc cue sheets with accompanying mpc files. If I ever need to burn a copy, I'd like to be able to do so directly from the cue.
Never mind. I found that using Nero I was able to burn the cue. However, I believe you have to have the mpc decoder plugin installed for this to work correctly.
Back to my original question -- can EAC burn a CD from a cue sheet that references a compressed file? or do I have to first decompress to a wave and edit the cue sheet?
I know that (as I listed below) Nero can do this and I also have used Burrrn which works well.
I've done it with mpc cue sheets and it works.
Madman2003.
Madman2003.
[a href="index.php?act=findpost&pid=226293"][{POST_SNAPBACK}][/a]
How? As you can see from my first post, I also tried an mpc with cue and got that error. Are you decompressing to wave first? I'm referring to a compressed image (not individual files). I most recently tried with flac and it wouldn't work. What am I doing wrong here?
Are the decoders in your EAC folder?
"You can fight without ever winning, but never win without a fight."  Neil Peart  'Resist'
Sorry i must have read over that little word "EAC" in your second post.  (feels stupid now)
I really haven't a clue, so i tested and only mp3 and wav according to EAC. Sorry for the mixup.(thought you were still talking about nero)
Madman2003.
(I use burrrn for my cue sheets, as you said yourself it works, why not use that?)
Madman2003.
[a href="index.php?act=findpost&pid=226462"][{POST_SNAPBACK}][/a]
Ok. Whew! Glad to know I'm not going crazy. Burrrn does work well and I've used it a few times. The reason I wanted to use EAC was for the write offset. It's not a huge deal but I just wanted to try it out.
[a href="index.php?act=findpost&pid=226340"][{POST_SNAPBACK}][/a]
Ok, I made sure I had mppdec.exe and flac.exe in my EAC folder. When I try to load the flac, EAC still gives me this error:
Error in CUE sheet!
Line 3 says:
FILE "CDImage.flac" WAVE
So, I'm guessing EAC doesn't know how to decode a flac and burn.
However, when I load the cue for an MPC image, it seems to do some processing on the file. Execept then I get this error:
Error in CUE sheet!
INDEX position is behind end of FILE in line 7
Here is the CUE sheet where line 7 reads "INDEX 01 00:00:00":
PERFORMER "The White Stripes"
TITLE "Elephant"
FILE "CDImageMPC.mpc" WAVE
 TRACK 01 AUDIO
   TITLE "Seven Nation Army"
   INDEX 01 00:00:00
 TRACK 02 AUDIO
   TITLE "Black Math"
   INDEX 01 03:51:60
 TRACK 03 AUDIO
   TITLE "There's No Home For You Here"
   INDEX 01 06:55:52
 TRACK 04 AUDIO
   TITLE "I Just Don't Know What To Do With Myself"
   INDEX 01 10:39:25
 TRACK 05 AUDIO
   TITLE "In The Cold, Cold, Night"
   INDEX 01 13:25:62
 TRACK 06 AUDIO
   TITLE "I Want To Be The Boy To Warm Your Mother's Heart"
   INDEX 01 16:24:20
 TRACK 07 AUDIO
   TITLE "You've Got Her In Your Pocket"
   INDEX 01 19:44:60
 TRACK 08 AUDIO
   TITLE "Ball And Biscuit"
   INDEX 01 23:24:42
 TRACK 09 AUDIO
   TITLE "The Hardest Button To Button"
   INDEX 01 30:43:42
 TRACK 10 AUDIO
   TITLE "Little Acorns"
   INDEX 01 34:15:62
 TRACK 11 AUDIO
   TITLE "Hypnotize"
   INDEX 01 38:25:05
 TRACK 12 AUDIO
   TITLE "The Air Near My Fingers"
   INDEX 01 40:13:40
 TRACK 13 AUDIO
   TITLE "Girl, You Have No Faith In Medicine"
   INDEX 01 43:53:65
 TRACK 14 AUDIO
   TITLE "Well It's True That We Love One Another"
   INDEX 01 47:11:45
Anybody know what is going on here?
/bump
I am having the same problem.. When I (with EAC) trying to write the CD, and trying to open a CUE I get the following error:
"Error in CUE sheet !"
"INDEX position is behind end of FILE in line 16"
I can understand if the ripper did something which he was not supposed to do if he'd still want to be able to burn it in EAC, but is there a way Now to see the gap settings on the existing files? (so I might be able to edit this CUE to the proper numbers myself)
REM GENRE Soundtrack
REM DATE 1989
REM DISCID AD0C060D
REM COMMENT "ExactAudioCopy v0.95b3"
PERFORMER "Maurice Jarre"
TITLE "Lawrence Of Arabia"
FILE "Maurice Jarre - Lawrence Of Arabia\01 01 Overture.wav" WAVE
  TRACK 01 AUDIO
    TITLE "Overture"
    INDEX 01 00:00:00
  TRACK 02 AUDIO
    TITLE "Main Titles"
    INDEX 00 04:23:70
    [color=red]INDEX 01 04:25:55[/color]
  TRACK 03 AUDIO
    TITLE "First Entrance To The Desert/Night And Stars/Lawrence And Tafas"
    INDEX 00 06:38:45
    INDEX 01 06:41:30
  TRACK 04 AUDIO
    TITLE "Miracle"
    INDEX 00 16:18:27
    INDEX 01 16:21:12
  TRACK 05 AUDIO
    TITLE "That Is The Desert"
    INDEX 00 18:48:60
    INDEX 01 18:51:27
  TRACK 06 AUDIO
    TITLE "Nefud Mirage/The Sun's Anvil"
    INDEX 00 21:43:02
    INDEX 01 21:43:57
  TRACK 07 AUDIO
    TITLE "The Rescue Of Gasim/Bringing Gasim Into Camp"
    INDEX 00 27:07:22
    INDEX 01 27:10:00
  TRACK 08 AUDIO
    TITLE "Arrival At Auda's Camp"
    INDEX 00 31:17:27
    INDEX 01 31:19:62
  TRACK 09 AUDIO
    TITLE "On To Akaba/The Beach At Night"
    INDEX 00 33:29:52
    INDEX 01 33:32:22
  TRACK 10 AUDIO
    TITLE "Sinai Desert"
    INDEX 00 38:12:60
    INDEX 01 38:15:47
  TRACK 11 AUDIO
    TITLE "The Voice Of The Guns"
    INDEX 00 39:21:50
    INDEX 01 39:24:30
  TRACK 12 AUDIO
    TITLE "Horse Stampede/Ali Rescues Lawrence/Lawrence And His Bodyguard"
    INDEX 00 41:26:02
    INDEX 01 41:26:50
  TRACK 13 AUDIO
    TITLE "The End/Playoff Music"
    INDEX 00 46:41:57
    INDEX 01 46:44:00
Insert the CD and tell EAC to create the proper CUE sheet to go with the tracks as you ripped them.
http://wiki.hydrogenaudio.org/index.php?ti...AC_Gap_Settings
http://wiki.hydrogenaudio.org/index.php?ti..._and_Cue_Sheets
If you don't own the CD then go buy it, rather than ask us to assist you in stealing it.
Discussion closed.
