Topic: How can I burn my 24/96 files to a DVD for listening? (Read 8863 times) previous topic - next topic
Hi all,
It might have been said but FooBar2000 plays my 24/96 flac files great. I'm just glad I found it. I do have 1 question if I burn those files on DVD and keep the 24/96 flac will they play on a home DVD player? Hope so.
Thanks Jack
If the said DVD player can play FLAC, yes.
If it can't what would be a good format to use and be able to keep 24/96 these files has been convert from LP records each album is 900mb and larger? I know FooBar2000 won't work with Ubuntu what would be a good player and the format of the files?
Thanks Jack
Moved out of the Recycle Bin/free bump. No doubt someone can suggest a simple way to get these files onto a DVD.
It would help if you could check the specifications of your player to determine whether it supports DVD-Audio. If not, you will have to burn the files as video files with a still image or similar on a DVD-Video disc. Having said that, to be honest, it will probably be easier to choose the latter option. But there are probably programs that support both, and in any case, providing any info you can about the player(s) with which you will want to use the resulting discs might help others to help you.
Thanks I will give it a try and little everyone know if it works. Do you know if it will work with Windows 7?
Jack
If you're asking about Audio DVD Creator, the developer stopped working on it in 2005. Reviews here are not good for x64 versions of Vista or Windows 7.
korth
A more recent and still developed Audio-DVD program. But it's a bit tech but following the guide would be no problems I think.
http://dvd-audio.sourceforge.net/
lplex http://audioplex.sourceforge.net/ is a console app but looks promising as well.
korth
I got it to install on Windows 7 32bit but I didn't want to hear that it won't work. When I find where to get the DVD A disk I will try it. I could try reg DVD. I all ready downloaded Audio DVD Creator version 1.9.1.0 plus I downloaded MadFLAC version 1.10 and Matrix mixer version 0.30b. I found out if you get Matrix mixer you can convert 2ch audio input to AC3 5.1ch output. So I hope now it works in Windows 7 32bit.
if it don't work I will try the other 2 links.
I let everyone know what I learn from this.
Thanks everyone for the help
Jack
Hi all update,
I did a test on Audio DVD Creator v1.9.1.0 plus the other 2 files I downloaded. I loaded Beatles Pastmaster 1 from my master record album I  made a few years ago and it was 1.39 gb then I click next to play and it played but when I click next to record it and I  got an error cause I had no DVD in the DVD recorder so it might work I hope. What do you think?
Jack
Erm, well, it sounds promising, but to be sure, you should just try it.
If it works as claimed in the link provided by Apesbrain, it should be fine and widely compatible. My concern was that any given program might write a DVD-Audio disc, which are less commonly supported, but the linked guide states that the result is a normal DVD-Video disc.
Just to say that the program worked 100% in Windows 8 Pro 64 bit with Windows XP SP2 compatibility settings I was able to create a DVD disc. I did not burned a disc i simply chose the build files to disk option and the files created are DVD-Video files, so it's compatible with any DVD player.
The thing is it only saves 5 audio files to each disk unless the program is registered. But anyway the program works and it's super easy to make DVD Audio compatible disks.
