Topic: [Not my release] foo_uie_panel_splitter (Read 405676 times) previous topic - next topic
Reply #825
@mire777
Please see the following for some insight:
http://www.hydrogenaudio.org/forums/index....st&p=796698
http://br3tt.deviantart.com/art/Xch4nge-21...fset=0#comments (post by Jny9 Feb 6 2012)
Thank you so much 'WilB', I installed wsh panel mod for xp from this site: https://sites.google.com/site/jk7800/foobar2000
works perfectly,now I don't have problem with letters transparency, also foobar still can be transparent if I select this in columns ui preference
Reply #826
Hello,
I add an image button to my config but it doesn't work at all. It should active one of the DSP settings. Can anyone tell me what's wrong? (When I add a keyborad shortcut for it, the keyboard shortcut works) Here's the code:
$imagebutton(0,0,34,9,$get(skin_path)/stereo.png,$get(skin_path)/stereo_hov.png,COMMAND: 'Playback / DSP Settings / stereo';REFRESH,,)
$imagebutton(38,0,45,9,$get(skin_path)/binaural.png,$get(skin_path)/binaural_hov.png,COMMAND: 'Playback / DSP Settings / binaural';REFRESH,,)
Reply #827
you don't need the spaces or quotes there. try it like this...
COMMAND:Playback/DSP Settings/stereo
Reply #829
Such a command doesn't appear to exist. To see available commands see the PSS menu and context command list or keyboard shortcuts list - its not listed on my set up but may be you have another component that provides it. There is just Playback/DSP settings on my set up.
Reply #831
Hey guys,
sry for the newbe question, but is there a command for changing the active playlist?
what i wanna do is to separate my library from my playing playlists. however i want to use the esPlaylist for the library, i need to have it following the active playlist, which should be 'filtered results' in order to get the CIU filter panels to work with the esPlaylist.
so when pushing a button to go to the library the active playlist should be switched to the 'filtered results' playlist the CUI filter is working on. when going back to the now playing view, the script should switch to the one playing a song or to the last one viewed before entering the library!!!
now: is this possible?!
thanks a lot!!!
Reply #832
Is it possible to specify a background image location using a variable like %APPDATA%? This would allow me to distribute my theme without expecting users to manually change the location of this file.
Reply #833
foo_uie_panel_splitter_mod.7z    modified by equinox.
to anyone wondering what exactly this is, I checked on the russian forums.
Its a small modification of the settings dialog. Everthing else stays the same.
From what I got, the size is changed and there i a different font in the script tab.
Thanks! Makes working with PPS a bit less a pain in the ass
Didn't try it, but you probably did that yourself... if it didn't work, there is your answer
I suggest you just draw the background image with imageabs(0,0,%_width%,%_height%,%themepath%background.jpg).
You can either set the path manually with $set_ps_global(themepath,'[your path]'), or use %ps_foobar2000_path%(path of foobar2000.exe) or %ps_user_profile_path% (user profile path.)
Reply #834
I'm not sure if my question is just nonsense, but since nobody gave me some advice i'll just ask again:
Is there a way for me switching to a certain playlist (not just "View/Columns playlist/Activate now playing") when pushing a button? Can i somehow implement such a functionality?
Thank you
Reply #835
Thank you
no way in PSS, but you can do it with WSH Panel Mod (jscript). With PSS, just set your wsh panel where you want, the panel fit the button size and you can also add it in the CUI toolbar... you can ask help about a such panel in the WSH Panel Mod discussion thread in 3rd party components.
HTH
Reply #836
Ahhh ok i see!!! The PSS then defines the appearance of the button and refers to a command or function, which is specified in the WSH Panel, right?
Thank you so much for your answer!! :-)
Reply #837
no - you'd have to make the button in WSH panel mod as well. but because you can position the panel anywhere you like in PSS it can appear seemlessly with a bit of styling.
Reply #838
Ok, i guess i will have to dig into that stuff first...
Anyways, thank you so much for helping me so far ;-)
Reply #839
Is there a way to move the same panel using two buttons? I have two buttons, both move the same panel but to different positions. Or is there a way to make one button do three different things so it can be clicked three times?
$if($isvisible_c(Artist)
$imagebutton($sub($get(bar.width),72),$get(play.button2.top),30,18,$get_ps_global(image.path)'/bt/list_off.png',$get_ps_global(image.path)'/bt/list_on.png',PANELSHOW:Artist:0;REFRESH,,)
$movepanel_c(Artist,1,$add($get(button.top),46),$get(bar.width),$sub(%_height%,78))
$movepanel_c(Graphical Browser,0,0,0,0)
$imagebutton($sub($get(bar.width),72),$get(play.button2.top),30,18,$get_ps_global(image.path)'/bt/list_off.png',$get_ps_global(image.path)'/bt/list_on.png',PANELSHOW:Similar:0;PANELSHOW:List:0;PANELSHOW:Artist:1;REFRESH,,)
$movepanel_c(Artist,$get(playlist.left),$sub($add($get(playlist.top),$get(playlist.h)),$get(playtabs.h)),$get(playlist.w),$get(playtabs.h))
$imagebutton($sub($get(bar.width),36),$get(play.button2.top),30,18,$get_ps_global(image.path)'/bt/list_off.png',$get_ps_global(image.path)'/bt/list_on.png',PANELSHOW:Artist:0;REFRESH,,)
$drawrect(0,330,$add($get(bar.width),2),25,60-60-60,25-25-25,RESERVED)
$font(Myriad Web,10,bold)$drawtextex(%artist% | %genre%,0,334,$get(bar.width),,$get(track.color2),hcenter vtop end_ellipsis)
$movepanel_c(Artist,1,$add($get(button.top),46),$get(bar.width),280)
$movepanel_c(Graphical Browser,0,355,$add($get(bar.width),1),$sub(%_height%,383))
$imagebutton($sub($get(bar.width),36),$get(play.button2.top),30,18,$get_ps_global(image.path)'/bt/list_off.png',$get_ps_global(image.path)'/bt/list_on.png',PANELSHOW:Similar:0;PANELSHOW:List:0;PANELSHOW:Artist:1;REFRESH,,)
Using this code both buttons move the artist panel to the same place?
Reply #840
rather than use PANELSHOW, i'd use global variables to save 3 different "states". each button click would cycle through them.
//sets state to 1 on first run. after that, the stored setting will be used.
$init_ps_global(state,1)
//note you don't need $get_ps_global, you can just wrap the variables in %% to access them. make sure they don't conflict with any tags/special fields that are in use.
$select(%state%,
//code here to show/hide/move panels if value is 1
//code here for 2
//code here for 3 etc
then in your button use this
SETGLOBAL:$select(%state%,2,3,1);REFRESH;
if the value of state is current 1, set it to 2.
if value is 2, set it to 3
if value is 3, set it back to 1 again.
Reply #841
$select(%state%,
//code here for 2
That works as I expected, thanks again foowizard.
Reply #842
[!--sizeo:11--][span style=\"font-size:12pt;line-height:100%\"][!--/sizeo--]How to affect "sibling" (= parent's child) pss?[/size]
Hey there community!
I hope I post in the right thread since I am new to this forum (in fact I just registered because of my question)
I recently rediscovered Foobar and its vast amount of cusomization options, so I wanted to do my first own "theme" inspired by my needs as well as some skins seen around the internet.
It all went pretty well until now: I want to have a "Display-Switch", that means a button to change the whole appearance. So I created multiple "panel stack splitter" inside my main (empty) panel splitter. The buttons are coded in the main pss script, so I can swap appearance via $showpanel. Since the button is always located in the upper right corner it shouldn't be a big problem, BUT: I want it to be more included into the whole theme, not only to be "toolbar-like". E.g. one possible display should look like this: big album art on the left, and on the right in vertical order: buttons, pss ( wsh - track info ), pss ( virualization ; wsh - seekbar ). Not that much - and I got all to work, the display as well as the buttons - but I just can't combine them if I want the buttons to be in the display's parent pss' script, not in the display's script (that's easy  ).
I found two solutions/workarounds:
1. Move the Display Panels a bit down so I get free Space on top - makes the buttons appear
2. Create the buttons in the display's main pss' script and update ($showpanel) in the parent pss' per second section - the delay creates a bad feeling AND the buttons don't work when paused/stopped. A command to refresh the parent pss would be very helpfull, but I looked it up in the components documentation and couldn't find anything.
Picture, created by using method 1:
Related Code: (NOT using method 1)
MAIN PSS SCRIPT:
//---------GLOBAL VARIABLES---------
$init_ps_global(display.switch,1)
// ----- PANELS -----
$movepanel(0,0,0,%ps_width%%ps_height%)
$movepanel(1,0,0,%ps_width%,%ps_height%)
$movepanel(2,0,0,%ps_width%,%ps_height%)
// ----- SHOWPANEL -----
$showpanel(0,$ifequal(%display.switch%,1,1,0))
$showpanel(1,$ifequal(%display.switch%,2,1,0))
$showpanel(2,$ifequal(%display.switch%,3,1,0))
//------- APPEARANCE SWITCH BUTTONS ---------
$puts(bar.length,$mul($div($sub(%ps_width%,%ps_height%),4),1))
$puts(bar.x,$sub(%ps_width%,$get(bar.length)) )
$gradientrect($get(bar.x),0,$get(bar.length),14,237-237-237-255,26-26-26-255,horizontal aa,0)
$gradientrect($get(bar.x),1,$sub($get(bar.length),1),12,237-237-237-255,255-255-255-255,horizontal aa,0)
//-------- BUTTONS ------------
$puts(btn.w,26)
$font(Calibri,11,)
$puts(btn.x,$sub($sub(%ps_width%,25),$get(btn.w)) )
$drawrect($get(btn.x),1,$get(btn.w),12,46-46-46-255,46-46-46-255,aa)
$textbutton($get(btn.x),1,$get(btn.w),12,LIB,LIB,SETGLOBAL:display.switch:3;REFRESH,fontcolor:192-192-192,fontcolor:255-255-255)
$puts(btn.x,$sub($sub($get(btn.x),18),$get(btn.w)) )
$textbutton($get(btn.x),1,$get(btn.w),12,B/W,B/W,SETGLOBAL:display.switch:1;REFRESH,fontcolor:192-192-192,fontcolor:255-255-255)
I tried almost everything from moving the panels via script, forced layout, fake transparency and everything I could imagine to help, but nothing worked - perhaps I just combined the wrong settings?
Thanks in advance for your help!
Have a nice day
Reply #843
If I understand you correctly, you want a refreshall  command (the refresh command available only refreshes code in the containing panel). Unfortunately there isn't a refreshall command and so some sort of workaround is needed  that forces the code to run in the child panels when a button is clicked in the  parent panel.
One workaround is below.
Include $get(p.p) as a button command – this will refresh most child panels – and is documented earlier in the thread.
$puts(p.p,$if(%ps_ispause%,COMMAND:Playback/Play;COMMAND:Playback/Pause,$if(%ps_isplaying%,COMMAND:Playback/Pause;COMMAND:Playback/Play,COMMAND:Playback/Play;COMMAND:Playback/Pause)))
$textbutton(x,y,w,h,,,$get(p.p);REFRESH,,)
    I have never found this to interfere with playback and it also works with $imagebutton. The rapid change in playback state causes the code to run. It works best with the panels positioned with $movepanel and forced layout.
Another possibility is to force a small resize of the child  panels (e.g. 1 pixel height or width difference toggle when the button is  pressed – more difficult to code -  but  can trigger the code to run and help.
    I hope that helps and  that I understood your post correctly.
Reply #844
Marc I can't get your global variable code to work, I thought it was working but looks like I've messed it up or I'm doing it wrong. Could you please check this for me?
$init_ps_global(banner,1)
$select(%banner%,
$drawimage($sub(%_width%,1226),0,1226,27,$get_ps_global(image.path)'/texture.png',OPTIONS,n,180)
$drawimage($sub(%_width%,1226),0,1226,27,$get_ps_global(image.path)'/texture2.png',OPTIONS,n,180)
$drawimage($sub(%_width%,1226),0,1226,27,$get_ps_global(image.path)'/texture3.png',OPTIONS,n,180)
$imagebutton(0,450,30,18,$get_ps_global(image.path)'/bt/list_on.png',$get_ps_global(image.path)'/bt/list_off.png',SETGLOBAL:$select(%banner%,2,3,1);REFRESH;)
I've been trying to make it work for the last two days am I missing something?
Reply #845
This isn't setting the global:
Try:
SETGLOBAL:banner:$select(%banner%,2,3,1);
Reply #846
obviously i missed it out to check people are awake...
Reply #847
I'M GOING TO KILL YOU MARC!
I have been changing it for ages I nearly threw the keyboard out the window.
Thanks guys it's working now, I'm learning I'm learning.
*Does this work as a global variable, the button only works if it's in the same PSS as the code? I thought it would be like $set_ps_global.
Quick question also is it more efficient to use title formatting than using $get and $puts?
Reply #848
This is slower than my old method?? Now it lags when I click the button, the panel shows in three laggy pieces.
$init_ps_global(utils99,1)
$select(%utils99%,
$movepanel_c(Utils,$get(l.panel.left),$get(l.panel.top),$get_ps_global(l.panel.w),$add($get(l.panel.h),5))
$movepanel_c(Utils,0,0,0,0)
$imagebutton($add($get(l.panel.button.left),$mul($add($get(l.panel.button.x),$get(l.panel.button.sep)),4)),$get(l.panel.button.top),$get(l.panel.button.x),$get(l.panel.button.y),$get_ps_global(image.path)'/bt/blank_off.png',$get_ps_global(image.path)'/bt/blank_on.png',SETGLOBAL:utils99:$select(%utils99%,2,1);REFRESH;)
This method is instant:
$if($isvisible_c(Utils),
$imagebutton($add($get(l.panel.button.left),$mul($add($get(l.panel.button.x),$get(l.panel.button.sep)),4)),$get(l.panel.button.top),$get(l.panel.button.x),$get(l.panel.button.y),$get_ps_global(image.path)'/bt/blank_on.png',$get_ps_global(image.path)'/bt/blank_on.png',PANELSHOW:Cover:1;PANELSHOW:Filter:0;PANELSHOW:Artist:0;PANELSHOW:Lyrics:0;PANELSHOW:Bio:0;PANELSHOW:Info:0;PANELSHOW:Customize:0;PANELSHOW:Utils:0;REFRESH,,)
$movepanel_c(Utils,$get(l.panel.left),$get(l.panel.top),$sub($get_ps_global(l.panel.w),$get(l.panel.left),$get(l.panel.right)),$get(l.panel.h))
$movepanel_c(Cover,0,0,0,0)
$imagebutton($add($get(l.panel.button.left),$mul($add($get(l.panel.button.x),$get(l.panel.button.sep)),4)),$get(l.panel.button.top),$get(l.panel.button.x),$get(l.panel.button.y),$get_ps_global(image.path)'/bt/blank_off.png',$get_ps_global(image.path)'/bt/blank_on.png',PANELSHOW:Cover:0;PANELSHOW:Filter:0;PANELSHOW:Artist:0;PANELSHOW:Lyrics:0;PANELSHOW:Bio:0;PANELSHOW:Info:0;PANELSHOW:Customize:0;PANELSHOW:Utils:1;REFRESH,,)
$movepanel_c(Cover,$get(l.panel.left),$get(l.panel.top),$get_ps_global(l.panel.w),$add($get(l.panel.h),5))
Reply #849
Thanks for the quick reply!
I just tested it and it works perfectly!
Although I needed it the other way round (refresh the parents' code when a child panel's button is clicked) your code did exactly this and no delay is audible!
Thanks thanks thanks
Have a  nice day!
