Topic: When using media server to stream to PS3, I get drop-outs every 6 sec (Read 4261 times) previous topic - next topic
When streaming(wireless) music to my ps3 i have audiodropouts every 6seconds.I also have dropouts when i use Ps3 media server but it's much worse with foobar.I have a hardline between my pc and my router(dsl-2740B)and wireless to my ps3 and i have xp professional on my pc.
That is probably because the PS3 client profile dictates that all files will be sent over the network as raw PCM, which requires a lot of bandwidth, but nothing that a wired or even possibly wireless network shouldn't be able to handle. For instance, CD quality (44100Hz 16 bit stereo) would eat up almost 1.5Mbps of bandwidth.
I've noticed the same problem when i was streaming music wirelessly from FB2k to our PS3. Our router was less than 1m away and it would dropout every 30 seconds or so. I have hard wired the PS3 now and no more drop outs.
i tried with a wire and it didn't help.i am trying to locate the log file but i can't find it.
http://www.thesycon.de/deu/latency_check.shtml  i did a latency check and it looked good so thats not the problem and i did ping tests for the computer and router and it looked good also
here is the log
foo_upnp: 34.219: FbMediaServer::ProcessHttpRequest(330)/4576: INFO: received LAN request: [url=http://192.168.1.2:56923/ContentDirectory/22e9c3ad-f779-13e9-e184-76f6f691b26b/control.xml]http://192.168.1.2:56923/ContentDirectory/...26b/control.xml[/url] (User-Agent: UPnP/1.0 DLNADOC/1.50)
foo_upnp: 34.219: FbMediaServer::OnAction(261)/4576: INFO: received action 'GetSystemUpdateID', args = {  }
foo_upnp: 34.219: FbMediaServer::OnAction(284)/4576: INFO: action 'GetSystemUpdateID' response: args = { Id=0 }
foo_upnp: 34.641: FbMediaServer::ProcessHttpRequest(330)/3180: INFO: received LAN request: [url=http://192.168.1.2:56923/ContentDirectory/22e9c3ad-f779-13e9-e184-76f6f691b26b/control.xml]http://192.168.1.2:56923/ContentDirectory/...26b/control.xml[/url] (User-Agent: UPnP/1.0 DLNADOC/1.50)
foo_upnp: 34.641: FbMediaServer::OnAction(261)/3180: INFO: received action 'Browse', args = { ObjectID=0/0, BrowseFlag=BrowseMetadata, Filter=@id,upnp:class,res,res@protocolInfo,res@av:authenticationUri,res@size,dc:title,upnp:albumArtU
RI,res@dlna:ifoFileURI,res@protection,res@bitrate,res@duration,res@sampleFrequency,res@bitsPerSample
res@nrAudioChannels,res@resolution,res@colorDepth,dc:date,av:dateTime,upnp:artist,upnp:album,upnp:ge
n
re,dc:contributer,upnp:storageFree,upnp:storageUsed,upnp:originalTrackNumber,dc:publisher,dc:languag
e
,dc:region,dc:description,upnp:toc,@childCount,upnp:albumArtURI@dlna:profileID,res@dlna:cleartextSiz
e
, StartingIndex=0, RequestedCount=1, SortCriteria= }
foo_upnp: 34.641: PLT_MediaServer::OnBrowse(380)/3180: INFO: Received BrowseMetadata from 192.168.1.3 for id = 0/0 with filter = @id,upnp:class,res,res@protocolInfo,res@av:authenticationUri,res@size,dc:title,upnp:albumArtURI,res@
dlna:ifoFileURI,res@protection,res@bitrate,res@duration,res@sampleFrequency,res@bitsPerSample,res@nr
A
udioChannels,res@resolution,res@colorDepth,dc:date,av:dateTime,upnp:artist,upnp:album,upnp:genre,dc:
c
ontributer,upnp:storageFree,upnp:storageUsed,upnp:originalTrackNumber,dc:publisher,dc:language,dc:re
g
ion,dc:description,upnp:toc,@childCount,upnp:albumArtURI@dlna:profileID,res@dlna:cleartextSize, start = 0, count = 1
foo_upnp: 34.641: FbMediaServer::OnAction(284)/3180: INFO: action 'Browse' response: args = { ObjectID=0/0, BrowseFlag=BrowseMetadata, Filter=@id,upnp:class,res,res@protocolInfo,res@av:authenticationUri,res@size,dc:title,upnp:albumArtU
n
e
e
, StartingIndex=0, RequestedCount=1, SortCriteria=, NumberReturned=1, TotalMatches=1, UpdateID=0 }
foo_upnp: 34.844: FbMediaServer::ProcessHttpRequest(330)/4840: INFO: received LAN request: [url=http://192.168.1.2:56923/ContentDirectory/22e9c3ad-f779-13e9-e184-76f6f691b26b/control.xml]http://192.168.1.2:56923/ContentDirectory/...26b/control.xml[/url] (User-Agent: UPnP/1.0 DLNADOC/1.50)
foo_upnp: 34.844: FbMediaServer::OnAction(261)/4840: INFO: received action 'GetSystemUpdateID', args = {  }
foo_upnp: 34.844: FbMediaServer::OnAction(284)/4840: INFO: action 'GetSystemUpdateID' response: args = { Id=0 }
foo_upnp: 35.235: FbMediaServer::ProcessHttpRequest(330)/3608: INFO: received LAN request: [url=http://192.168.1.2:56923/ContentDirectory/22e9c3ad-f779-13e9-e184-76f6f691b26b/control.xml]http://192.168.1.2:56923/ContentDirectory/...26b/control.xml[/url] (User-Agent: UPnP/1.0 DLNADOC/1.50)
foo_upnp: 35.235: FbMediaServer::OnAction(261)/3608: INFO: received action 'Browse', args = { ObjectID=0/0/0, BrowseFlag=BrowseMetadata, Filter=@id,upnp:class,res,res@protocolInfo,res@av:authenticationUri,res@size,dc:title,upnp:albumArtU
n
e
e
foo_upnp: 35.235: PLT_MediaServer::OnBrowse(380)/3608: INFO: Received BrowseMetadata from 192.168.1.3 for id = 0/0/0 with filter = @id,upnp:class,res,res@protocolInfo,res@av:authenticationUri,res@size,dc:title,upnp:albumArtURI,res@
A
c
g
foo_upnp: 35.235: FbMediaServer::OnAction(284)/3608: INFO: action 'Browse' response: args = { ObjectID=0/0/0, BrowseFlag=BrowseMetadata, Filter=@id,upnp:class,res,res@protocolInfo,res@av:authenticationUri,res@size,dc:title,upnp:albumArtU
n
e
e
foo_upnp: 35.641: FbMediaServer::ProcessHttpRequest(330)/5580: INFO: received LAN request: [url=http://192.168.1.2:56923/ContentDirectory/22e9c3ad-f779-13e9-e184-76f6f691b26b/control.xml]http://192.168.1.2:56923/ContentDirectory/...26b/control.xml[/url] (User-Agent: UPnP/1.0 DLNADOC/1.50)
foo_upnp: 35.641: FbMediaServer::OnAction(261)/5580: INFO: received action 'GetSystemUpdateID', args = {  }
foo_upnp: 35.641: FbMediaServer::OnAction(284)/5580: INFO: action 'GetSystemUpdateID' response: args = { Id=0 }
foo_upnp: 36.032: FbMediaServer::ProcessHttpRequest(330)/2044: INFO: received LAN request: [url=http://192.168.1.2:56923/ContentDirectory/22e9c3ad-f779-13e9-e184-76f6f691b26b/control.xml]http://192.168.1.2:56923/ContentDirectory/...26b/control.xml[/url] (User-Agent: UPnP/1.0 DLNADOC/1.50)
foo_upnp: 36.032: FbMediaServer::OnAction(261)/2044: INFO: received action 'Browse', args = { ObjectID=0/0, BrowseFlag=BrowseMetadata, Filter=@id,upnp:class,res,res@protocolInfo,res@av:authenticationUri,res@size,dc:title,upnp:albumArtU
n
e
e
foo_upnp: 36.032: PLT_MediaServer::OnBrowse(380)/2044: INFO: Received BrowseMetadata from 192.168.1.3 for id = 0/0 with filter = @id,upnp:class,res,res@protocolInfo,res@av:authenticationUri,res@size,dc:title,upnp:albumArtURI,res@
A
c
g
foo_upnp: 36.032: FbMediaServer::OnAction(284)/2044: INFO: action 'Browse' response: args = { ObjectID=0/0, BrowseFlag=BrowseMetadata, Filter=@id,upnp:class,res,res@protocolInfo,res@av:authenticationUri,res@size,dc:title,upnp:albumArtU
n
e
e
foo_upnp: 36.438: FbMediaServer::ProcessHttpRequest(330)/5480: INFO: received LAN request: [url=http://192.168.1.2:56923/ContentDirectory/22e9c3ad-f779-13e9-e184-76f6f691b26b/control.xml]http://192.168.1.2:56923/ContentDirectory/...26b/control.xml[/url] (User-Agent: UPnP/1.0 DLNADOC/1.50)
foo_upnp: 36.438: FbMediaServer::OnAction(261)/5480: INFO: received action 'GetSystemUpdateID', args = {  }
foo_upnp: 36.438: FbMediaServer::OnAction(284)/5480: INFO: action 'GetSystemUpdateID' response: args = { Id=0 }
foo_upnp: 36.547: FbMediaServer::ProcessHttpRequest(330)/2136: INFO: received LAN request: [url=http://192.168.1.2:56923/content/eedcf0da828d51e6676fba6d5ad778cf.l16?profile_id=4&convert=lpcm]http://192.168.1.2:56923/content/eedcf0da8...mp;convert=lpcm[/url] (User-Agent: PLAYSTATION 3)
foo_upnp: 36.547: PLT_HttpHelper::ToLog(441)/2136: INFO:
GET /content/eedcf0da828d51e6676fba6d5ad778cf.l16?profile_id=4&convert=lpcm HTTP/1.1
Host: 192.168.1.2:56923
Connection: Keep-Alive
Accept-Encoding: identity
transferMode.dlna.org: Streaming
X-AV-Client-Info: av=5.0; cn="Sony Computer Entertainment"; mn="PLAYSTATION 3"; mv="1.0";
Range: bytes=0-
foo_upnp: 36.547: upnp_server_conf::get_profile(740)/2136: INFO: using profile 'PlayStation 3', matching header (User-Agent:PLAYSTATION 3)
foo_upnp: opened 'file://E:\musik\Bruce Springsteen\Wrecking Ball\Bruce Springsteen - 01. We Take Care Of Our Own.flac' for streaming, profile: PlayStation 3, LPCM / 44100 Hz / 16 bits / 2 channels, replaygain: on, DSP chain: off
foo_upnp: 36.844: FbMediaServer::ProcessHttpRequest(330)/1064: INFO: received LAN request: [url=http://192.168.1.2:56923/ContentDirectory/22e9c3ad-f779-13e9-e184-76f6f691b26b/control.xml]http://192.168.1.2:56923/ContentDirectory/...26b/control.xml[/url] (User-Agent: UPnP/1.0 DLNADOC/1.50)
foo_upnp: 36.844: FbMediaServer::OnAction(261)/1064: INFO: received action 'Browse', args = { ObjectID=0/0/0, BrowseFlag=BrowseMetadata, Filter=@id,upnp:class,res,res@protocolInfo,res@av:authenticationUri,res@size,dc:title,upnp:albumArtU
n
e
e
foo_upnp: 36.844: PLT_MediaServer::OnBrowse(380)/1064: INFO: Received BrowseMetadata from 192.168.1.3 for id = 0/0/0 with filter = @id,upnp:class,res,res@protocolInfo,res@av:authenticationUri,res@size,dc:title,upnp:albumArtURI,res@
A
c
g
foo_upnp: 36.844: FbMediaServer::OnAction(284)/1064: INFO: action 'Browse' response: args = { ObjectID=0/0/0, BrowseFlag=BrowseMetadata, Filter=@id,upnp:class,res,res@protocolInfo,res@av:authenticationUri,res@size,dc:title,upnp:albumArtU
n
e
e
foo_upnp: 37.250: FbMediaServer::ProcessHttpRequest(330)/1932: INFO: received LAN request: [url=http://192.168.1.2:56923/ContentDirectory/22e9c3ad-f779-13e9-e184-76f6f691b26b/control.xml]http://192.168.1.2:56923/ContentDirectory/...26b/control.xml[/url] (User-Agent: UPnP/1.0 DLNADOC/1.50)
foo_upnp: 37.250: FbMediaServer::OnAction(261)/1932: INFO: received action 'GetSystemUpdateID', args = {  }
foo_upnp: 37.250: FbMediaServer::OnAction(284)/1932: INFO: action 'GetSystemUpdateID' response: args = { Id=0 }
foo_upnp: 37.641: FbMediaServer::ProcessHttpRequest(330)/6044: INFO: received LAN request: [url=http://192.168.1.2:56923/ContentDirectory/22e9c3ad-f779-13e9-e184-76f6f691b26b/control.xml]http://192.168.1.2:56923/ContentDirectory/...26b/control.xml[/url] (User-Agent: UPnP/1.0 DLNADOC/1.50)
foo_upnp: 37.641: FbMediaServer::OnAction(261)/6044: INFO: received action 'Browse', args = { ObjectID=0/0/0, BrowseFlag=BrowseMetadata, Filter=@id,upnp:class,res,res@protocolInfo,res@av:authenticationUri,res@size,dc:title,upnp:albumArtU
n
e
e
foo_upnp: 37.641: PLT_MediaServer::OnBrowse(380)/6044: INFO: Received BrowseMetadata from 192.168.1.3 for id = 0/0/0 with filter = @id,upnp:class,res,res@protocolInfo,res@av:authenticationUri,res@size,dc:title,upnp:albumArtURI,res@
A
c
g
foo_upnp: 37.641: FbMediaServer::OnAction(284)/6044: INFO: action 'Browse' response: args = { ObjectID=0/0/0, BrowseFlag=BrowseMetadata, Filter=@id,upnp:class,res,res@protocolInfo,res@av:authenticationUri,res@size,dc:title,upnp:albumArtU
n
e
e
foo_upnp: 37.828: PLT_HttpServerSocketTask::Write(348)/2136: WARNING: NPT_CHECK failed, result=-20401 (NPT_ERROR_CONNECTION_ABORTED) [(NPT_StreamToStreamCopy( *body_stream.AsPointer(), *output_stream.AsPointer(), 0, entity->GetContentLength(), 0, abort))]
foo_upnp: 37.828: FbMediaServer::ProcessHttpRequest(330)/1328: INFO: received LAN request: [url=http://192.168.1.2:56923/content/eedcf0da828d51e6676fba6d5ad778cf.l16?profile_id=4&convert=lpcm]http://192.168.1.2:56923/content/eedcf0da8...mp;convert=lpcm[/url] (User-Agent: PLAYSTATION 3)
foo_upnp: 37.828: PLT_HttpHelper::ToLog(441)/1328: INFO:
Range: bytes=0-
foo_upnp: 37.828: upnp_server_conf::get_profile(740)/1328: INFO: using profile 'PlayStation 3', matching header (User-Agent:PLAYSTATION 3)
foo_upnp: 78.485: PLT_HttpServerSocketTask::Write(348)/1328: WARNING: NPT_CHECK failed, result=-20401 (NPT_ERROR_CONNECTION_ABORTED) [(NPT_StreamToStreamCopy( *body_stream.AsPointer(), *output_stream.AsPointer(), 0, entity->GetContentLength(), 0, abort))]
