Topic: foo_clienc (Read 11243 times) previous topic - next topic
foo_clienc
after foo_mpcenc and foo_vorbisenc when foo_lamenc ???
Give foo_clienc a try, it can use any command line encoder as output.
foo_clienc
Nice.  Just what I was looking for.  But it doesn't work for me.  It just sits there and I'm forced to abort.
I'm running Win2K SP3, FB2K 0.6 b10.  Not using DSP or replaygain.
Encoder: mppenc.exe
Extension: mpc
Parameters: --quality 5 --xlevel --artist "%artist%" --album "%album%" --title "%title%" --track "%tracknumber%" --year "%date%" --genre "%genre%" %d
EDIT: Unchecked "Write APEv2 tags".
And a suggestion:  I would be great if the user could create encoder profiles.  This way, it would be easy to switch between your favorite Musepack and Lame settings.
foo_clienc
The calls you have in your parameters probably won't work, because they are used to call for values from EAC. For instance, you are telling mppenc to insert "%artist%" into the artist tag. Where is it grabbing "%artist%" from? The tag of the original file? I just encoded a FLAC into an MPC. It works great, but I wish that the tag could be copied to the new file.
Does the MPPENC plugin use the "--xlevel" switch?
As far as the profiles go, that's a good idea. But if you want to switch between LAME & MPC, you could set the CLI up for LAME, and switch between that and the mppenc plugin.
foo_clienc
Nope.  I'm using foobar2000 variables, like %artist%, which would be %a in EAC.
mppenc.exe uses --xlevel to prevent clipping during encoding.  Please RTFM (recommended settings in the MPC forum).
mppenc and lame use different parameters.  I don't want to retype these every time I switch formats.
foo_clienc
VLSI:
use only  --quality 5 --xlevel  and check "Write APEv2 tags".
work fine here!
thank you, CASE!
(I would be great if the user could create encoder profiles...)
Music is my first love.
foo_clienc
Perhaps you forgot about input file in cmdline ('-' because plugin will feed encoder's stdin)?
--standard --xlevel - %d
works fine.
foo_clienc
VLSI:
work fine here!
thank you, CASE!
That's the first thing I tried.  Doesn't work here.  The progress bar once moved up around 25% and then just stopped.  mppenc was running but wasn't using any CPU time.  I aborted after a minute of inactivity.  the command works properly from a shell prompt though.
EDIT:
@Messer:
I have the stdin flag '-', but mppenc stops encoding after a while and uses no CPU cycles.  Its as though the plugin stops feeding it audio samples.
foo_clienc
Nice CLI enc, Case.
Any chance of dropdown history listings on the encoder, type,and parameter fields? Would minimize typing stuff in over and over as some people use vorbis and mpc and other CLIs interchangebly  and at different bitrates, switches and such.
foo_clienc
I ran the following in a command prompt and it worked fine:
mppenc --quality 5 --xlevel - outfile.mpc < infile.wav
With foo_clienc, it stalls when it gets somewhere around 25%.  Has anyone else experienced this?
foo_clienc
yes, confirmed  sometime with mppenc.exe 1.15r
1.14 not work.
lame.exe work
foo_clienc
I got the same ~25% stall as well. Has anyone tried it with 0.586?
superdumprob
____________________________________________
"If we knew what it was we were doing, it would not be called research, would it?" - Albert Einstein
foo_clienc
I uploaded version 0.0.2, still alpha but includes preliminary preset support and allows conversion through temp file.
I don't know how some of you get stalling, does it happen randomly or with some specific files? Could you also try if that happens with foo_mpcenc.
foo_clienc
It stalls for me too and it doesn't seem to happen randomly.
  - foobar 0.6 b 10
-  win xp sp1
- MPC Encoder  1.15r
- plugin version 0.0.2
- cmdline --xlevel --standard - %d
- does not stall foo_mpcenc
PM me if you want the sample (it is 8.46 minutes long(*), but encoded to lowest quality speex file stalls the plugin as good as original wav and is only 500 kB)
(*) originally it was about 16 minutes long and encoding stopped working in second half of the track. I tried to split it into two halves and see if second one still stalls encoding - yes it did. But surprisingly when I repeated the operation none of the "quarters" stalled the encoding.
foo_clienc
I tried again with foo_clienc 0.0.2 and mppenc 1.14.  It still fails, but the stall position seems file-dependent.  It happens with all files I've tested.
I tested foo_mpcenc with a few wav files.  No problems there.  It might be worths checking that stdout is switched to binary mode.
foo_clienc
wav -> mpc = ok
mp3 -> mpc  = freeze at 25% (with  foo_mpcenc.dll :ERROR (FOO_MPCENC) : Only lossless source files allowed...)
ogg -> mpc = freeze at 80% (with  foo_mpcenc.dll :ERROR (FOO_MPCENC) : Only lossless source files allowed...)
wav -> mp3 = ok
mpc -> mp3 = ok
ogg -> mp3  = ok
mp3 -> mp3  = freeze  at 100%
wav -> ogg  = freeze at  10% (work with foo_vorbisenc)
mp3 -> ogg = freeze at  10%      ''
mpc -> ogg = freeze at  10%      ''
mppenc 1.14 lame 3.92 ogg 1.0 and OggEncGT3b1
win 98se 128 Mo ram duron 1.1 mhz foobar 0.6 b10
question for case: why it is not possile to add id1 tag to mp3 ?
foo_clienc
Case:
Fisrt of all, this is lovely.
Second, a few suggestions.....
- Merge the encoder and parameters into a single textbox so we can have multiple commands:
IE:
mppenc.exe --quality 5 --xlevel %d && replaygain --auto %d
- Let the CLIencoder retrieve the tags variables so we can have someting like:
mppenc.exe --quality 5 --xlevel - %d && replaygain --auto %d && tag.exe -t ARTIST=%artist% -t TITLE="%title% %d
this way you can kill the add APE2 tag and have support for every tag using your very own Tag.exe
and perhaps a little option for not launching the CLI window when using a temporary input file.
"You have the right to remain silent. Anything you say will be misquoted, then used against you."
foo_clienc
Great! Now foobar works for me as my primary audio player, masstagger AND file converter  Only ripping and burning CDs (and occasionally tagging) is now done by some other software
foo_clienc
foobar 0.6 b11:
ERROR (CORE) : Failed to load DLL: foo_clienc.dll, reason: Wrong version number; this component appears to have been built with outdated version of foobar2000 SDK and needs to be recompiled with newer version in order to load; please contact author of this component to obtain an updated version of this component.
ERROR (CORE) : Failed to load DLL: foo_vorbisenc.dll, reason: Wrong version number; this component appears to have been built with outdated version of foobar2000 SDK and needs to be recompiled with newer version in order to load; please contact author of this component to obtain an updated version of this component.
Redownload.
foo_clienc
Version 0.0.3 uploaded, this should solve hanging.
foo_clienc
Thanks Case.  This fixed it.
I also ran a test with temporary input files.  It didn't work for me.  The file decoded to wav without a hitch, but the console window flashed shortly and closed.  This is what I did:
--quality 5 --xlevel %s %d
It worked when I tried it from a dos box.
foo_clienc
Version 0.0.4 uploaded, includes several fixes and improvements.
Encoder presets are now stored in external text file,
new presets can be created and old ones deleted from config,
encoder's maximum supported bit depth can be set,
WAV header is now fixed for temp file to contain correct number of bytes,
fixed (possibly) incorrect size reporting in wav header when outputting to pipes,
when using temp wav console screen is opened in minimized mode and can be optionally hidden completely,
metadata fields can be passed on parameter list,
default presets improved.
foo_clienc
Temp file encoding works now.  Didn't find any other problems.  Good stuff.
foo_clienc
Sorry to raise this thread again but i have a request if it's not to hard and if im not being to cheeky    .
The CLIenc is working great on my computer but i was wondering if it would be possible to add a command that would "copy /b" all albums into one file for formats that support it such as vorbis. Would this be feasable to do or do you not think it a good idea or not in the scope of this plugin.
Cheers for your time,
Kristian
foo_clienc
Actually, if i extract to the same directory structure i keep my Flac's in, i can use sweep to run the "copy /b" command recursivly through the directories, does anyone know how to automatically remove the source ogg's though and how to give the final combined file a proper filename such as "artist -- album"?
Cheers Kristian
foo_clienc
Hi!
First, that's a really great Plug-in!
Thanks Case!
I'm using CLI encoder 0.1.2 for transcode from mpc -> mp3.
It works fine! Only one question.
Does the "Dithered float -> PCM conversion" option mean
that the output (in my case of the mpc) is dithered before
it goes to the encoder?
What is better for transcode? Dithered or undithered?
sorry, english is not my favourite language
