Topic: LossyWav: The '--limit' parameter is always on? (Read 3228 times) previous topic - next topic
Hi, I've worked with LossyWav and FlaCuda and I got great results around 400 kbps.
My question is simple: the -l option is ON by default or only when it is invoked in command line?
Thank you.
loquor mee menti: factus de materia, cinis elementi...
The default upper limit is 16kHz - --limit can change that in the range 10kHz to 20kHz.
Thank you Nick.C! You've made a great work! We are waiting the 1.3 version.
