Topic: lossyWAV 1.3.0 Development Thread (Read 199593 times) previous topic - next topic
Reply #175
After some bug-hunting (with a bit of brain-failure mixed in), I have concluded that any difference in added noise per channel Chris encountered processing stereo signals with similar energy / spectral shape in each channel can be put down to the clipping prevention kicking in and reducing the bits-to-remove for enough codec-blocks to make an observable difference.
[edit] Clarity [/edit]
Chris,
I would suggest that you repeat your test with "--maxclips 16" in your command line.
Nick.
lossyWAV -q X -a 4 -s h -A --feedback 2 --limit 15848 --scale 0.5 | FLAC -5 -e -p -b 512 -P=4096 -S- (having set foobar to output 24-bit PCM; scaling by 0.5 gives the ANS headroom to work)
Reply #176
On another note:
Lossy WV is considered not efficient compared to flac. I am pleased to find that its more competitive (in some cases a lot) when using the -x switch. The sweetspot between size / speed seems to be the normal mode using -x levels 1-3.  The fast mode also benefits a lot. For some reason the high modes don't bring any gain except making encoding / decoding slower.
Reply #177
Tonight, I completed a transcode of my music collection using beta v1.2.2s "-q -2 -A 96 -t" which resulted in 302kbps.
Reply #178
Thanks, Nick, for the long explanation! So it is "slightly" more complicated than I thought
Did that, the result is bit-identical to not using the switch. The test item, SQAM #2, is far from clipping, anyway (peak level -34 dB).
Chris
Reply #179
Right then, time to don the pest control gear and go bug-hunting again....
Reply #180
Took a look at SQAM 2 again, the channels actually have slightly different levels of DC offset/LF rumble. Could that be the reason? Which window function are you using in your FFTs?
Chris
Reply #181
The Hanning window is used.
Reply #182
Though the actual discussion might show up a problem with lossyWav, at least there is no obvious different treatment of the left and right channel for SQAM sample #2 within lossyWAV:
The error (the correction) file is bit-identical for 02.flac and the channel-swapped error-file of the channel-swapped 02.flac. I used sox for channel-swapping.
lame3995o -Q1.7 --lowpass 17
Reply #183
Interesting. Thanks, halb27! So it must be related to either the LF or HF differences in the signal. Nick, what happens when you let the masking analysis start at, say, 40 Hz instead of 20 Hz?
Edit: That should fix it. I manually removed the (minimal) DC offset from the right channel, and now it looks better. 20 Hz is probably too close to DC when you use a Hann window.
Chris
Reply #184
I agree that removing the -h from the example command-line and replacing it with a -x (or even -x3) would be a better trade-off for WavPack. Thanks for pointing this out!
BTW, the reason that the higher modes do not provide additional compression is because the block headers are significantly larger for the higher modes. With only 1 or 2 blocks per second this is insignificant, but with the extremely short blocks associated with LossyWAV these larger headers are no longer offset by the better compression of the data itself.
Reply #185
In the lossyWAV wiki, there's a paragraph mentioned that lossyWAV may work with MLP via "Bit-Shifting". Has anybody ever tested it?
As I know, MLP (Dolby TrueHD) is designed for multi-channel lossless compression, which indicate that it might not work well with 2-ch music from CDs. I'm very curious to know if lossyWAV can work well with multi-channel audio streams together with FLAC and MLP.
Can anybody in this forum has the opportunity to do the corresponding tests?
Reply #186
Looking to the next release:
Is anyone using -X, --sortspread? If not, I will remove it as it complicates the code and slows things down a little.
Reply #187
If nobody uses it I welcome removing it.
Reply #188
Sounds good to me - it's history....
Reply #189
lossyWAV beta 1.2.2t attached to post #1 in this thread.
Reply #190
Hi Nick,
i am working on a dedicated LossyWav codec for the next TAK release (quite a lot of work illustrating my appreciation for your and 2Bdecided's work  ). If it will be released depends on the advantage over TAK's standard codec i can achieve. Currently i am getting about 1.5 percent better compression and i am aiming for 2 percent (relative to the original file size). IMHO this would be worth a release.
Among other things this codec can process small frames more efficiently. This raises the question, how small LossyWav's block sizes can get, if a codec can process them without a significant penalty. Currently the new codec supports a minimum block size of 256 samples. Do you think, even less could be advantegous?
Reply #191
A 2% reduction over TAK sounds like quite a challenge! Thank you for taking the time to implement lossyWAV specific algorithms in TAK.
Although smaller blocks may reduce specific output size (due to more bits being removed on average), the size of any block header should be taken into account. At present the codec-block-size for lossyWAV is 512 samples for 44.1/48kHz audio with a maximum of 4096 samples for 352.8/384kHz. I worry that you may get into a situation where the smaller block size is less efficient due to block related information rather than the compressed audio itself.
Reply #192
Of course, but the new codec can cope a lot better with small block sizes. If it requires only the modification of a constant, could you please send me a V1.2.0 with a block size of 256 samples for 44.1 KHz audio?
Reply #193
I'll have a look and get something to you, hopefully this evening.
[edit] eig file attached, codec-block-size=256 samples. [/edit]
[edit2] file removed - not required. [/edit2]
Reply #194
Thank you Nick. And sorry. I wasn't clear enough.
What i really need is a modified version of LossyWav V1.2.0 working with a block size of 256. I have to perform a lot of tests on my test corpus to be sure, if such a small blocksize is advantegous for the new codec.
It's not urgent.
Thank you
  Thomas
BTW: About 2 percent better compression is definitely possible, even with the default block size of 512. Currently i am close to 1.8 percent for my primary test corpus.
Reply #195
I'll work on something not quite so agricultural as the version I created the test version of eig with. Please PM me your e-mail address so that I can e-mail you the test executable.
Reply #196
lossyWAV beta 1.2.2w attached to post #1 in this thread.
Reply #197
Thank you, Nick, for the new version.
Though I decided to use mp3 (because of family/friend related compatibility issues) I'm still very excited about lossyWAV development.
I didn't have much time recently for lossyWAV (I was in hospital, and after that was busy with other things), but I hope I can do some more listening tests in the near future, especially as the new version is a good reason to do so.
Reply #198
Again, many thanks for all of the testing that you have carried out over the period of development so far!
Reply #199
I don't understand much of what LossyWav does, however one thing bothers me.  What is the purpose of --limit? Does it mean LossyWav ignores everything above 16kHz?
