Topic: How to enable Autoplalyist? (Read 1460 times) previous topic - next topic
Hello,
i want do use autoplaylist. But in my Foobar Installation i cant enable it.
Under [Library] there should [Autoplaylist]: http://eolindel.free.fr/foobar0.9/img/media3.gif
But this is how it looks on my pc:
What can I do to became Autoplalylist? is there a Component which disables it?
hopefully
Amerlander
I guess it was removed from there some time ago (according to the URL that is a picture of version 0.9).
Why would you need it anyway? You can create autoplylists directly out of the Album List.
Making an autoplaylist is typically done from a library viewing component (such as foo_uie_albumlist) or a Search component (such as Media Library Search [main menu > library > search] ). These components will have options to send a selection of files to a new autoplaylist.
In the CUI Album List panel, right-click a selection of files and you should see the option "Create Autoplaylist".
In the Media Library Search window, the same option is available when clicking on the button in the top-right corner [...].
I want to add a autoplaylist for my top rated titles (i added a Tag "Rating" with the values 1 to 5).
And a history of played songs would be great, becouse with "Random" playing order it isn´t posible to skipp a song backwards.
And at least an autoplaylist for most played songst.
The last two points are described here (www.eolindel.free.fr/foobar0.9/autoplaylist.php) under "Tips" on the bottom of the page.
But I havent a clue how to do this on my Foobar version.
Inserting "Last_played IS *" or "Play_counter GREATER 0" in the search gives no result. So i cant create a autoplaylist from the search.
Any Tips or ideas?
Edit: inserting "%rating% IS 5 OR %rating% IS 4" or "%rating% GREATER 3" in the search worked fine. Now i have actual a n autoplaylist for top rated songs. But whats to do for a history an most played?
Edit2: ok, I just need this Component: Playback Statistics v3.x (foo playcount).
Amerlander
ps.
sorry for my English, I´m not a native.
