Topic: Uppercase to Lowercase tagging? (Read 1328 times) previous topic - next topic
Is there a plugin for foobar2k that will fix things like this?
Vital Remains - Hammer Down The Nails - Icons Of Evil
I want it to be tagged properly, as such:
Vital Remains-  Hammer Down the Nails - Icons of Evil
Can anyone help with this? I've tried mass tagger, musicbrainz (which 100% of the time says no results) and quick tag and none are fixing it.
Properties, Format from other fields...
try $replace(%tag%, Of , of , The , the )
The checker included in the Tagbox component is usually pretty spot on, in my experience. The Correct Capitalization function is found via the dropdown menu arrow next to each item.
So you don't want uppercase or lowercase, you want Titlecase
Truth be told, there's 14 billion ways to do "proper" titlecase.
Fortunately, you can create masstagger scripts to handle this sort of thing for your entire library. Unfortunately, while you might find some examples around here on the forum, what you'll likely discover is that they're not going to 100% conform to your standards of what "proper" titlecase is, nor is a simple masstaggger script going to work on 100% of all the titles of your library all the time because titlecase is, *ahem*, rather arbitrary and will often have as many exceptions as there are rules.
Best of luck.
elevatorladylevitateme
