Topic: Skins for foo_title plugin (Read 365110 times) previous topic - next topic
Reply #150
Packed Player [ UPDATE ]
This is the same skin from the previous post with some added extra features I forgot to include.
Still hoping it can be helpful to someone!
Updated List of Features:
Main Box
- Album cover; maximize (top left); previous, play and next buttons (down middle); volume control bars (down right); open and close controls box (top right); open and close information box (down left).
Controls box
- Small demonstrative animation; media library search; tagbox; now playing properties; time elapsed and length; codec and play counter; sample rate and channels; bitrate and codec profile; back by 5, 10 and 60 seconds; ahead by 5, 10 and 60 seconds; progress bar; volume up and volume down buttons; play random order; play default order; preferences box; open containing folder; exit button.
Information box
- Artist name; song title; album name; track number; date; genre.
Note: In the previous version I forgot to take in consideration the mp3 tags can be empty. Now, whenever the tag is empty, it will read N/A (not available) as you can see in the skin preview I carefully chosen.
[attachment=6841:Packed_Player_2.rar]
Reply #152
Packed Player (V0.3)
The same skin from the previous posts with a different information box style.
P.S.: You can set the volume you want either by clicking in the volume control bars (main box) or by clicking in the volume up and down buttons (controls box).
[attachment=6854:Packed_Player_3.rar]
Reply #154
So, this time I decided to get creative with the animation feature!
Here is the 2 “best” results…
Packed Player (V0.4)
Purple Bird
(The idea was to make the bird simulate the clicking of the clock beneath it…)
[attachment=6860:Packed_Player_4.rar]
Packed Player (V0.5)
Dancing Girl
(A girl dancing in the background but everything works the same…)
[attachment=6861:Packed_Player_5.rar]
P.S.: You can “fine-tune” the animation speed by “shifting” the Update Interval in the foo_title preferences window.
Reply #157
Does the latest version of this component work with foobar v1.1?
Reply #158
Yes, the latest version of this component works perfectly with the latest version of foobar.
Here is the proof ...
Reply #160
Hello. I have created myself a foo_title skin and after much tweaking I believe it's a good time to share it with the public.
WebM Video Preview Mirror
Features:
  • High and low transparency modes (low is default; high is less distracting)
  • Rating display: If a file is rated 1 star or higher, a star will show on top of the transparency toggle button. Note: This depends on the %RATING_CD% tag which is associated with foo_customdb, change this to %RATING% if you do not have it.
  • Has the same volume/progress bar as the Firsh skin.
  • The timecode can be toggled between time elapsed and time remaining by clicking on it.
  • Click anywhere under the volume bar to play or pause the track.
Notes:
  • Two fonts are included which are required to display the rating and timecode: Guifx v2 Transports, PF Tempesta Seven.
  • This skin contains source code from Firsh, an existing foo_title skin, which was the inspiration for Flourish.
  • I liked the minimalism of the Firsh skin but wanted extra functionality and a theme complementary to Win7 Aero (flour·ish - v. to grow, thrive, prosper.)
Reply #162
Hi, in this I share my design inspired on the obsidian skin of DFK audio enhacer. Welcome any comments.
Re: Skins for foo_title plugin
Reply #163
I've updated the flourish skin for foo_title 1.0.5 and foobar 1.5. As always, remember to install the included fonts to your system.
  • Changed the volume selectors to step more naturally into mute.
  • Changed the default title text to Roman letters.
  • Slightly tweaked some graphic icons and fixed text display being clipped.
Screenshot:
Mirrors:
Mediafire - Drive
Reply #164
Very sorry but I missed a strange issue in my flourish skin that appeared when I updated but I didn't notice until I already posted v2. Apparently foo_title no longer allows layers whose padding contains a negative value to clip out of its boundaries, nor into a previous layers' padding. Any such geometry will become transparent. Strange, but I fixed it by rearranging the order it's loaded and giving it a positive padding value. It affected only the RATING_CD display.
			<layer name="rating" type="text">
<geometry type="full">
<padding left="16" top="2" right="0" bottom="0"/>
</geometry>
<contents spacing="0" font="Guifx v2 Transports" size="10">
<label position="left" color="88FFFFFF">$ifgreater(%rating_cd%,0,b, )</label>
</contents>
</layer>
I'll explain again the function of this layer. It shows a star if the RATING_CD tag is present. If you do not have foo_customdb component, change this to RATING. If you do not have the font installed and listen to a rated song, you'll only see the character 'b'. If you don't want an entire font as a dependency for a single character, you could change it to a unicode ★  and take font="..." out, or if you don't want rating display at all, modify or take this entire code cluster right out of the file. All up to you.
