Topic: lossyWAV 1.3.0 Delphi to C++ Translation Thread (Read 168469 times) previous topic - next topic
Reply #125
Try setting like this:
/d /c lossywav - -q standard --stdout 2>%d.log | flac - -b 512 -5 -f  -o %d --ignore-chunk-sizes
You will get log file (hopefully with some useful error messages) in the destination directory for each song.
Reply #126
Thanks nu774. The error message I got is as follows:
%lossyWAV Error%: Input file: lossywav  - --quality standard --silent --stdout  does not exist
Can anyone make sense of it?
lossyWAV -q H | FLAC -5 ~= 480kbps
QAAC 320kbps
Reply #127
A bit stumped by this one....
Can you please confirm that flac.exe and lossyWAV.exe both exist in the "C:\Program Files\bin" directory?
Reply #128
I can confirm that both flac.exe and lossyWAV.exe are present in the "C:\Program Files\bin" directory. Interestingly, if I substitute 1.3.1f with the stable version (1.3.0.0), everything works without any problems. No error messages of any sort. For what it's worth, I'm using libFLAC 1.3.0.
QAAC 320kbps
Reply #129
Ok. Not sure that the libFLAC version is relevant as the foobar2000 command uses the executable rather than the DLL.
Which version is FLAC.exe?
Reply #130
FLAC.exe is the latest build - FLAC 1.3.0 (26 May 2013).
QAAC 320kbps
Reply #131
Can you please process a WAV file using lossyWAV on the command line?
Also, what CPU is in the PC?
Reply #132
Strangely, it works now. I tried switching things around, using the following parameters:
/d /c C:\foobar2000\lossywav.exe - -q H --silent --stdout|C:\foobar2000\flac.exe - -b 512 -5 -f -o%d --ignore-chunk-sizes
Hopefully, this will help anyone out there experiencing the same problem. By the way, thanks a lot Nick for responding so quickly!
QAAC 320kbps
Reply #133
Glad that you managed to sort it out.
Reply #134
Hi Nick,
Any chance for a new beta version of LossyWAV with a new drop dead date?
Alex
QAAC 320kbps
Reply #135
Hi Alex,
Many apologies - my wife had a significant birthday on Friday and this weekend has been particularly hectic.
Nick.
lossyWAV beta 1.3.1g attached to post #1 in this thread.
Reply #136
Hi Alex,
Nick.
Thanks for this, Nick. I think having a longer drop dead date like 1.3.1g does is brilliant.
By the way, congrats to you and your wife on the milestone birthday!
QAAC 320kbps
Reply #137
It's only two months… what's with those anyway? I'm afraid I didn't follow too closely.
Reply #138
The expiry date was introduced to limit the damage that an experimental function in a beta release would have, i.e. it would not be available indefinitely.
Reply #139
Hi
Since version 1.3.1a
I have a problem because of these parameters that I have set my foobar2000 does not work with newer versions higher than that which I have given is not unnecessarily replaced the executable file and you can not go back to the old version . I tried to make a difference in performance but still the same I jump out :
1 out of 1 tracks converted with major problems.
Source: "D:\muzyka\Flac\Radiohead - Discography 1993-2011 [FLAC]\1997 - OK Computer\04 - Exit Music (For a Film).flac"
  An error occurred while writing to file (The encoder has terminated prematurely with code 1 (0x00000001); please re-check parameters) : "D:\muzyka\ass\Radiohead\OK Computer (1997)\04. Exit Music (for a Film).flac"
  Additional information:
  Encoder stream format: 48000Hz / 2ch / 16bps
  Command line: "C:\Windows\System32\cmd.exe" /d /c  c:\"Program Files (x86)"\foobar2000\encoders\lossyWAV - --quality extraportable  --silent --stdout|c:\"Program Files (x86)"\foobar2000\encoders\flac --silent -b 512 -8 --ignore-chunk-sizes - -o "04. Exit Music (for a Film).flac"
  Working folder: D:\muzyka\ass\Radiohead\OK Computer (1997)\
  Conversion failed: The encoder has terminated prematurely with code 1 (0x00000001); please re-check parameters
What could be the problem?
Reply #140
Have you downloaded the latest beta version? There is now a "drop dead" date whereby beta versions expire after a certain date. Please download the latest beta and retry.
Reply #141
Now I use the last version 1.3.1g and the problem persists I do not know what it was?
What could be wrong?
Maybe showcase me some examples of that work? Sam I do not know where it can be a problem. Once, as was set for the first time paramatry include it did not work with one - with two persons - and written with names only worked therefore I have in this example, which I handed but here it does not help I have no idea on this.
Source: "D:\muzyka\Flac\Franz Ferdinand Album Discography 2004-2013 [FLAC]\Franz Ferdinand - Tonight [2009] [LIMITED] [FLAC]\CD1\05 - Twilight Omens.flac"
  An error occurred while writing to file (The encoder has terminated prematurely with code 1 (0x00000001); please re-check parameters) : "D:\muzyka\ass\05 - Twilight Omens.flac"
  Encoder stream format: 44100Hz / 2ch / 16bps
  Command line: "C:\Windows\System32\cmd.exe" /d /c  c:\"Program Files (x86)"\foobar2000\encoders\lossyWAV  - -q X --silent --stdout|c:\"Program Files (x86)"\foobar2000\encoders\flac --silent -b 512 -8 --ignore-chunk-sizes - -o "05 - Twilight Omens.flac"
Edit:
Look at my parameters:
/d /c  c:\"Program Files (x86)"\foobar2000\encoders\lossyWAV  - -q X --silent --stdout|c:\"Program Files (x86)"\foobar2000\encoders\flac --silent -b 512 -8 --ignore-chunk-sizes - -o %d
Reply #142
The FLAC element of the command line is missing a " - " to tell the encoder to take input from STDIN.
Try moving the " - " to just after FLAC in your command line.
Reply #143
Nothing helps ... encoders copied to the folder foobar2000 I just change my syntax and I still have the same error ... Now the syntax looks like this:
/d /c lossyWAV - -q X --silent --stdout|flac - -b 512 -8 - -o %d --ignore-chunk-sizes
before:
/d /c lossyWAV - -q X --silent --stdout|flac -b 512 -8 --ignore-chunk-sizes -o %d
/d /c lossyWAV - -q X --silent --stdout|flac - -b 512 -8 -o %d --ignore-chunk-sizes
/d /c C:\"Program Files (x86)"\foobar2000\encoders\lossywav - -q P --silent --stdout|C:\"Program Files (x86)"\foobar2000\encoders\flac - -b 512 -5 -f -o%d --ignore-chunk-sizes
Reply #144
before:
3 dashes, is that really your command line?
Reply #145
Should work if both lossyWAV and FLAC are on in "C:\Program Files (x86)\foobar2000\encoders\".
Try opening a CMD window and enter the command:
"C:\Program Files (x86)\foobar2000\encoders\lossywav"
and post a copy of the output, please. (To copy output in a command window, right click in the window, select mark and click and drag to select the area of text you want to copy).
Reply #146
There should only be one single dash in the FLAC element of the command line, not two. For piped processing in foobar2000 a single dash is required in the lossyWAV element of the command line.
Reply #147
before:
I had similar problems not too long ago. Try using the following parameters:
/d /c C:\foobar2000\lossywav.exe - -q X --silent --stdout|C:\foobar2000\flac.exe - -b 512 -8 -f -o%d --ignore-chunk-sizes
QAAC 320kbps
Reply #148
In the End I managed to issue here was current path access. Although the performance of these commands through the command line with the current path "Program Files (x86)" \ foobar2000 \ encoders \ where I have other encoders. To perform but do not know why there was doing this using foobar2000. Now, I created a folder "foobar2000" on the C drive threw there encoder ect and everything works
Thanks for Your help!!!
Reply #149
Great to hear you've sorted this out. Nick: I think the Wiki needs to be updated to reflect the need for a separate foobar2000 folder on the C drive. That's the missing ingredient for making LossyWAV work - via foobar2000 at least.
QAAC 320kbps
