Topic: foo_audioscrobbler 1.4.7 (Read 921697 times) previous topic - next topic
Reply #875
Hello.
I have a problem with wavepack files.
Wavepack files with correction files are not submitted (and not cached) while those without correction files are submitted correctly. In both case, files are in the media library and the option 'Only submit tracks from the Media Library' is checked.
I'm using foo_audioscrobbler 1.4.7 with foobar 1.0.3. Maybe it was also the case before but i found out this only today.
Is it a bad setting from me or a bug ? Is there something i can do ?
Reply #876
I seem to be having trouble with scrobbling. Every few days or so I seem to be getting connection errors when attempting to scrobble.
Below is what I get from foobars console:
Audioscrobbler: Handshake successful.
Audioscrobbler: Submitting 10 of 82 cached tracks...
Audioscrobbler: Connection error
Reply #877
Question about scrobbler - how much % of song must be played before song is send ?
Reply #878
50% or 4 minutes, whichever comes first.
And song need to be 30 seconds or longer.
Reply #879
Is there a way to tie/connect the plugin to the official app ?
I enjoy the official app, but it seems like they dropped foobar support a long time ago !
Reply #880
Official app works great for me, you have manually add the plug-in though.
From last.fm user  Jester-N
In your client:
Tools - Get Plug... (Setup Wizard opens)
Next - you most probably see no foobar, so click the "Add..."-button - In the dropdown menu of the 'Add player' dialog, select foobar2000 0.9.4 (the second option) - use the browse-button to select your foobar2000.exe - click OK - click Next (tell your UAC that you are aware what is happening) - click Finish.
That should do the trick.
Reply #881
Audioscrobbler: Submitting 2 cached tracks...
Audioscrobbler: Could not connect to host
I've been getting this error all day, is it last.fm or is it client? anybody know?
I've recently added foo_uie_lyrics2 0.4.6.15 and foo_uie_biography 0.4.2.2, but i've disabled those and it still doesn't work. I also upgraded from 1.0.3 to 1.1 but that was a few days ago. I only started getting this error 7 hours ago.
I'd also like to note that while i'm listening to a song it shows the song i'm listening to on last.fm, but once it finishes it doesn't scrobble. It adds to the cache fine, but won't scrobble.
edit:
Audioscrobbler: Submitting 5 cached tracks...
Audioscrobbler: Invalid data, received line length exceeds limit
I get this one every once and a while, when I submit to fast.
Reply #882
Yeah, I'm getting the same submission errors.  It's cached 130 tracks so far.  I have no idea which end the problem is on.  I'm going to assume it's last.fm for now.
Reply #883
Same here, since yesterday I haven't been able to scrobble.
Reply #884
Check [a href='index.php?showtopic=83238']this[/a] today's thread.
Reply #885
Ah HAH! TYVM good sir.  I should have known that discussion of a foo_audioscrobbler issue wouldn't be in the foo_audioscrobbler thread.
Reply #887
A sidenote: The error message "Invalid data, received line length exceeds limit" is mismatched in the current version of fb2k. It appears when the response was truncated, like when the remote server closed the connection before sending any data. And that would make more sense for some network problems on last.fm's side.
Reply #888
After some digging, I've worked out that I seem to get connection errors whenever I synchronise my ipod touch using foo_dop and then attempt to submit the cached tracks either manually or just by playing music in foobar.
It happens even when last.fm's status is fine.
Reply #890
same with me.
i started to get those connection errors with upgrade to latest version of foobar (downgrading doesn't help)
last.fm status is OK
Recently Listened Tracks shows that foobar is running and even shows song i'm listening now.
I'm able to scrobble tracks from my eten x600, played with Conduits Pocket Player
Once i was able to scrobble 100 tracks from foobar cache, but i have no idea how.
also foobar seems stop attempts to scrobble tracks while not playing.
Foobar version 1.1
foo_audioscrobbler version 1.4.7
WinXP SP3
Reply #891
I don't know, if it's something with foobar, or audioscorbbler... but scorbbler don't catch some tracks.
I have set option to read track only from media library. And when I add some new tracks to directory (N:\Music) and load new playlist, script don't catch tracks. Log says that track isn't in media library. What to do?
Reply #892
same with me.
Foobar version 1.1
WinXP SP3
i was able to scrobble all my cached tracks this way:
- i made a fresh install of foobar (named directory foobar20002)
- i was able to scrobble tracks played by this version
- i replaced configuration file from new version ( foobar directory\configuration\foo_audioscrobbler.dll.cfg) with one from my old install (it contained all my cached songs)
- voila! they got submitted!
Reply #893
I get the feeling that this shouldn't be necessary, but I'll give it a go to see if I have any luck.
Reply #894
Hi everyone, I was wondering if you could help me. When I try to submit the songs I have on the cache nothing happens and the console gives me this message:
Audioscrobbler: Handshake failed: The system time is far off. Please correct your system time.
Audioscrobbler: Handshake failed.
Audioscrobbler: Still awaiting handshake. Cache contains 175 tracks.
I'm afraid I don't know what this means, can someone help me out please?
Thanks in advance.
Reply #895
Thanks in advance.
Check (and fix) the clock in your system BIOS.  (system time does not necessarily mean Windows time.)  Keep tapping the setup key at boot until you get in.  It could be F1, F2, F8, F10, F12, Delete, or anything else - you'll need to know what your computer/laptop model is if you don't know the key and it isn't said on the screen.
Reply #896
The plugin worked a short time, but now i get this error:
Startup time : 0:02.041282
Audioscrobbler: Submitting 10 of 79 cached tracks...
And when i try to submit with the submit button it repeats the Submitting->connection error.
This has been happening to me for about 20 days now.  Anybody know what the deal is?
Reply #897
Can you reach http://post.audioscrobbler.com/ with your browser?
If you can then it's probably a problem with some firewall/security package blocking connections for foobar.
Otherwise you may have an issue with your gateway or ISP.
Reply #898
It opens up a page that says
Audioscrobbler submissions system.
http://www.audioscrobbler.net/
Is that all it is?
I completely reinstalled Foobar and it fixed the problem. I'm a little skeptical that my ISP could have been causing a problem that reinstalling the software would fix.  On the other hand, having to reinstall Foobar and get all my settings back to normal really really sucks, so it would be a lot nicer if there were a less painful fix to a problem that seems pretty prevalent.
Reply #899
Yes I was trying to see if it was likely a software or network problem, the fact you can reach the submission server means it's unlikely to be a network problem. Glad to hear to fixed it though.
You can back up your settings by copying %appdata%\foobar2000\ to another location, or the directories configuration, user-components and (possibly) index-data from the foobar directory when using a portable install. That should make a reinstall less painful.
