Topic: Columns/Panels UI: display text file in a panel (Read 2884 times) previous topic - next topic
Iv Looked around and didnt find much about this.... I Have my own logs about my music saved in the album folder about that album... and i would like to open that in a panel so i can see it... kinda how lyrics panel works... is there a way to do this with lyrics panel with out having to edit all my txt docs by adding 00:01 and all that good stuff?  Or is there any other way of doing this?
The workaround I use is to open my "info" files in notepad using run services.
$replace(%path%,%filename_ext%,info.)txt
With the new beta, you can add a button to perform the function (or just use the context menu)
For Some Reason that dont work... i know it should...
i dont know if this makes a diff but im useing
$replace(%path%,%filename_ext%,)folder.*
for my album art... i changed the folder.* to My Log.txt and that didnt work eather...
*scrachs head* someone wanna make me a simple panel plugin?
check the closing ")"
$replace(%path%,%filename_ext%,My Log.)txt
Thats what im useing..
Tryed $replace(%path%,%filename_ext%,)My Log.txt
just cause thats how my album art dose it..
i can get the Open Dir to Open the correct Folder and everything l0l...
so i really dont know why its not working...
my foobar version is 9.4.4 and run is 3.4 maybe that has somtin to do with it?
I tried your string and it worked fine for me.
(I am using run v 3.2 - there was a change in the newest one that broke some of my strings and this could be one of them, sorry!)
ok cool Thanks for trying
i try in track down that version and give it a shot and see what happens...
if nothing ima give C++ a shot, =)) this should be fun l0l
WooT Woot.... Got It Working Thanks Alot nightfishing! it was just the version of foo_run..
im now useing foo_run.0.3.2.7 and its working just fine... keep a look out for a panel component
from me in a yr or 2... haha Thanks again
