Topic: folder\\file viewer (Read 2992 times) previous topic - next topic
folder\\file viewer
Is there a media viewer that displays the media library in a treeview based on the file path, like Windows explorer, for 9.6. I tried downloading fo_uie_explorer but it says it not compatible with 9.6.
The reason I'm asking is that my files are laid out in a directory structure Artist\Album\Title but some of the tags are messed up. It would be much easier to fix the tags if I could view them in the path layout.
folder\\file viewer
Album List (the one included in fb2k's installer) already does this.
You just need to change the View dropdown at the bottom of the window/element. Select "by folder structure"
elevatorladylevitateme
folder\\file viewer
Damn! I ask the stupidest questions!
I knew it had to be part of the default installation, I just didn't look hard enough.
folder\\file viewer
If you use columns UI, then foo_uie_explorer is a great panel plugin for browsing by directory structure.
folder\\file viewer
Just for completeness: the media library browser Facets is also capable of displaying your files based on folder structure. Just set the columns of several views to "Folder structure".
