Topic: Looking for command-line id3v2 tagger for Windows (Read 8406 times) previous topic - next topic
I've done a few searches here and have found mention of a command-line tagger called id3.exe, but haven't come across a download as yet.
Are there any others?
Edit: Not sure how I did that, but I intended to post this in MP3 General.  Mods, please move. Thanks.
http://home.wanadoo.nl/squell/id3.html
I would also look at Tycho's metamp3:
http://www.hydrogenaudio.org/forums/index....showtopic=49751
Thanks, I'll check out metamp3.
It appears that id3 has all the capabilities I need, but I'm running into a lot of problems when the tag data exceeds a certain length.  The program crashes if I attempt too many tags at once, or if just one tag (such as a comment) is over a certain length.
Hello
Is anyone here in possession of source code for id3 and could share it? Its site is offline. The filename should be id3-078s.zip
TIA
Never mind, I've found it using id3-078.tar.gz filename.
