Topic: Please help me interpreting this EAC-log (Read 3536 times) previous topic - next topic
Few days ago I've bougth a used Iron Maiden Cd, it was not in a very good state of conservation, with many scratches. After some cleaning I tried to rip it with EAC, the resulting log says:
Exact Audio Copy V1.0 beta 3 from 29. August 2011
EAC extraction logfile from 22. November 2012, 8:57
Iron Maiden / Killers
Used drive  : ATAPI  DVD A  DH16ABSH  Adapter: 0  ID: 1
Read mode : Burst
Read offset correction                      : 6
Overread into Lead-In and Lead-Out          : No
Fill up missing offset samples with silence : Yes
Delete leading and trailing silent blocks  : No
Null samples used in CRC calculations      : Yes
Used interface                              : Native Win32 interface for Win NT & 2000
Used output format              : User Defined Encoder
Selected bitrate                : 32 kBit/s
Quality                        : High
Add ID3 tag                    : No
Command line compressor        : C:\Program Files (x86)\foobar2000\flac.exe
Additional command line options : -5 %source%
TOC of the extracted CD
    Track |  Start  |  Length  | Start sector | End sector
        1  |  0:00.32 |  1:45.63 |        32    |    7969
        2  |  1:46.20 |  2:54.30 |      7970    |    21049
        3  |  4:40.50 |  4:18.22 |    21050    |    40421
        4  |  8:58.72 |  3:22.73 |    40422    |    55644
        5  | 12:21.70 |  3:07.05 |    55645    |    69674
        6  | 15:29.00 |  3:52.32 |    69675    |    87106
        7  | 19:21.32 |  5:00.65 |    87107    |  109671
        8  | 24:22.22 |  6:12.20 |    109672    |  137591
        9  | 30:34.42 |  3:20.05 |    137592    |  152596
      10  | 33:54.47 |  4:48.50 |    152597    |  174246
Range status and errors
Selected range
    Filename G:\Musik\Iron Maiden - 1981 - Killers\Iron Maiden - 1981 - Killers.wav
    Timing problem 0:00:07
    Timing problem 0:00:12 - 0:00:14
    Timing problem 0:00:16 - 0:00:17
    Timing problem 0:03:43
    Timing problem 0:04:36
    Timing problem 0:04:45 - 0:04:48
    Timing problem 0:04:57 - 0:05:00
    Timing problem 0:05:02 - 0:05:08
    Timing problem 0:05:51
    Timing problem 0:06:06
    Timing problem 0:06:16
    Timing problem 0:06:18
    Timing problem 0:06:21
    Timing problem 0:06:25 - 0:06:26
    Timing problem 0:06:36 - 0:06:37
    Timing problem 0:06:39
    Timing problem 0:06:41
    Timing problem 0:06:43
    Timing problem 0:06:45 - 0:06:49
    Timing problem 0:06:51
    Timing problem 0:06:58 - 0:06:59
    Timing problem 0:07:30
    Timing problem 0:08:54
    Timing problem 0:09:29 - 0:09:33
    Timing problem 0:09:39 - 0:09:55
    Timing problem 0:09:59
    Timing problem 0:10:03 - 0:10:13
    Timing problem 0:10:15
    Timing problem 0:10:21
    Timing problem 0:10:24
    Timing problem 0:10:30 - 0:10:31
    Timing problem 0:10:36
    Timing problem 0:11:57
    Timing problem 0:11:59 - 0:12:05
    Timing problem 0:12:07 - 0:12:08
    Timing problem 0:12:11
    Timing problem 0:12:13 - 0:12:21
    Timing problem 0:12:26 - 0:12:29
    Timing problem 0:13:11 - 0:13:32
    Timing problem 0:13:45 - 0:13:57
    Timing problem 0:14:01
    Timing problem 0:14:03 - 0:14:07
    Timing problem 0:14:09 - 0:14:12
    Timing problem 0:14:34
    Timing problem 0:15:18
    Timing problem 0:15:22 - 0:15:34
    Timing problem 0:15:36 - 0:15:44
    Timing problem 0:15:46 - 0:15:49
    Timing problem 0:15:55
    Timing problem 0:15:57 - 0:15:58
    Timing problem 0:16:00 - 0:16:01
    Timing problem 0:16:03 - 0:16:04
    Timing problem 0:16:07 - 0:16:10
    Timing problem 0:16:15 - 0:16:21
    Timing problem 0:16:24
    Timing problem 0:16:30
    Timing problem 0:16:32 - 0:16:42
    Timing problem 0:16:48 - 0:16:49
    Timing problem 0:16:51
    Timing problem 0:16:58
    Timing problem 0:17:36 - 0:17:46
    Timing problem 0:18:29
    Timing problem 0:18:31 - 0:18:32
    Timing problem 0:18:58 - 0:19:05
    Timing problem 0:19:11 - 0:19:12
    Timing problem 0:19:15
    Timing problem 0:19:20
    Timing problem 0:19:22
    Timing problem 0:19:42
    Timing problem 0:19:46
    Timing problem 0:19:56
    Timing problem 0:19:58 - 0:20:01
    Timing problem 0:20:43 - 0:20:48
    Timing problem 0:20:50 - 0:20:51
    Timing problem 0:20:53
    Timing problem 0:21:27
    Timing problem 0:22:38
    Timing problem 0:22:50 - 0:22:52
    Timing problem 0:22:54 - 0:22:55
    Timing problem 0:22:57
    Timing problem 0:23:08
    Timing problem 0:23:16 - 0:23:17
    Timing problem 0:23:19
    Timing problem 0:23:21 - 0:23:23
    Timing problem 0:23:27
    Timing problem 0:23:29
    Timing problem 0:23:31
    Timing problem 0:23:35 - 0:23:36
    Timing problem 0:23:39 - 0:23:41
    Timing problem 0:24:23
    Timing problem 0:24:27
    Timing problem 0:24:34
    Timing problem 0:24:39
    Timing problem 0:25:01
    Timing problem 0:25:04 - 0:25:06
    Timing problem 0:25:08
    Timing problem 0:26:21
    Timing problem 0:26:26
    Timing problem 0:26:30 - 0:26:31
    Timing problem 0:28:06
    Timing problem 0:28:21
    Timing problem 0:28:23
    Timing problem 0:28:27
    Timing problem 0:28:38 - 0:28:43
    Timing problem 0:29:26 - 0:29:31
    Timing problem 0:29:33
    Timing problem 0:29:35
    Timing problem 0:29:37 - 0:29:38
    Timing problem 0:29:41 - 0:29:43
    Timing problem 0:29:46 - 0:29:58
    Timing problem 0:30:00 - 0:30:05
    Timing problem 0:30:08 - 0:30:11
    Timing problem 0:30:13 - 0:30:15
    Timing problem 0:30:17 - 0:30:35
    Timing problem 0:31:18 - 0:31:19
    Timing problem 0:31:21 - 0:31:22
    Timing problem 0:31:26 - 0:31:27
    Timing problem 0:31:32 - 0:31:34
    Timing problem 0:31:36 - 0:31:37
    Timing problem 0:32:19
    Timing problem 0:32:24
    Timing problem 0:32:44
    Timing problem 0:33:42 - 0:38:42
    Peak level 99.7 %
    Extraction speed 2.8 X
    Test CRC E435686A
    Copy CRC 46EA545C
    Copy finished
No errors occurred
AccurateRip summary
Track  1  cannot be verified as accurate (confidence 70)  [45915099], AccurateRip returned [AB545ECE]  (AR v2)
Track  2  cannot be verified as accurate (confidence 70)  [43D94978], AccurateRip returned [03286E74]  (AR v2)
Track  3  cannot be verified as accurate (confidence 70)  [70407142], AccurateRip returned [C1BD2C64]  (AR v2)
Track  4  cannot be verified as accurate (confidence 69)  [C11EBAA2], AccurateRip returned [19C240DB]  (AR v2)
Track  5  cannot be verified as accurate (confidence 69)  [7B6D6652], AccurateRip returned [16F79A4F]  (AR v2)
Track  6  cannot be verified as accurate (confidence 69)  [FE39B5E1], AccurateRip returned [89378EE9]  (AR v2)
Track  7  cannot be verified as accurate (confidence 69)  [BC05E306], AccurateRip returned [BB29522F]  (AR v2)
Track  8  cannot be verified as accurate (confidence 69)  [576E524E], AccurateRip returned [49BBA1C1]  (AR v2)
Track  9  cannot be verified as accurate (confidence 69)  [B35D814D], AccurateRip returned [4F5DCCDB]  (AR v2)
Track 10  cannot be verified as accurate (confidence 68)  [87E2CEB4], AccurateRip returned [2F26BC22]  (AR v2)
No tracks could be verified as accurate
You may have a different pressing from the one(s) in the database
End of status report
---- CUETools DB Plugin V2.1.3
[CTDB TOCID: x0EG7SCcp_M0cPDj7jbwzYVQHns-] found, Submit result: discs with pregaps not supported in this protocol version
[fe1a93dc] (162/162) No match
Obviously there were problems in reading the data correctly (timing problems, mismatching crc, failed accuraterip verification), but how shall I interpret the information given by eac: "No errors occurred"?
Many thanks, if someone could help me!
Harald
From the EAC site:
Question: When using burst mode, EAC also shows up timing problems, are these really errors or what?
Answer: No, burst mode has no error detection nor error correction. If burst mode brings up a timing problem, the read command needed a lot of time, which could have several reasons, like loosing sync or trying to fix an read error. Of course this is a really poor “error detection” and should not be taken as serious indication.
Did you try using a 'secure' mode?
korth
From the EAC site:
2nd that.
ghostman
Clearly my fault, I had to think about that!
Tried to rip the CD in secure mode, it took more than three hours for ripping 10 minutes of the album, then I aborted the operation. I suppose the Cd is so damaged, that an accurate reading is impossible.
Thanks fpr your kind help!
Harald
... and you might want to use the latest CTDB Plugin with Exact Audio Copy ...
Regards, ...
