Topic: FB2K basic customization (Read 1899 times) previous topic - next topic
I'm new to FB2K and have some difficulties to get what I want.
To begin with, here's the layout I made. It's simple, efficient, quite exactly what I need and mostly inspired by my former winamp layout:
Now, here's where I'm blocked (I did intensive research, found almost outdated info)
1. how can I change titlebar/toolbars/elevators/borders/searchbar etc.... colors to match the vintage theme I made with CUI ? (please do not tell me to theme windows, that's irrelevant)
2. how can I add a text/an image to the empty artowrk panel (upper left) ?
3. how can I change toolbars buttons/volume/seekbar image and replace the playback dropdown list with a simple repeat/repeat-one/no-repeat button ? (sure there's neat scripting behind this)
4. how can I fix/prevent resizing of FB2K window ?
I know all of those points can be done, but I didn't find how they can.
Thanks for your help !
FAQs but since I've been wasting time with foobar recently including those:
1. Don't tell me? I won't then :-). Borders: panel stack splitter (PSS). Scrollbars - hide or partially hide with PSS, use different playlist: WSH panel mod or EPLaylist.
2. What do you mean by "empty artwork panel": empty panel full stop, custom text only when there's no image, custom cover and text? Stock answer: PSS or WSH panel mod scripts.
3. Buttons: CUI, PSS or WSH panel mod, Volume and seekbar - WSH panel mod (marc2000 has some scripts), playback dropdown list - I don't know, maybe PSS, if not WSH panel mod(?)
4. !Banned and not recommended! component that starts with h and rhymes with bucks, you can use it !at your own risk! also to remove title bar and replace it with PSS or WSH panel mod scripts. You lose the right to complain if something doesn't work.
I've read some FAQ, some with lots of 404 links, some without anything interesting.
Could you please point me to this FAQ ?
OK, thanks a lot for those trails. I'll dig on PSS and WSH
About artwork panel, I mean to display something (text or image) when there's nothing displayed in there.
Oops, let's forget this then. I'll try to fix certain panels ratios instead.
Thank you !
file>preferences>display>album art>front cover>stub image path
that lets you set an image to be displayed when there is no art for the current track.
Damn, that was so simple.
Thank you !
