Topic: Is Replay Gain Info Burned? (Read 1974 times) previous topic - next topic
I converted a CD to FLAC and then Replay Gained the files. When I burn this CD again, will the Replay Gain information be included with the files on the CD?
[a href="index.php?act=findpost&pid=282868"][{POST_SNAPBACK}][/a]
By the files on the CD, do you mean you are going to burn FLAC files to a CD? Or are you going to convert FLAC to WAV and then burn a CD? If you are converting to WAV first, you need a program like foobar2000 that will adjust the gain on the files according to the replaygain tags.
Replaygain takes the form of tags so, it would be the same as a tag for artist or title. Those tags can be transported (via CD Text) however they usually are not.  You need the proper software first.
