Topic: CUETools.. Couple Questions (Read 5355 times) previous topic - next topic
I recently discovered CUETools and decided to use it to verify a bunch of my old flac rips with AccurateRip. Seems to work great! So here is my first question..
The flac file names in most of these rips have been changed. They no longer match what is in the log and cue files. CUETools doesn't seem to mind at all. Works just fine... How is this possible? lol . Not that im complaining. Im just really curious.
Question number two is...
I decided to try verifying a rip that already says ''Accurately ripped (confidence 9)  [00D29D78]  (AR v2)'' in the EAC log. However, when i run it though CUETools it says
[AccurateRip ID: 0011f546-008f3ae0-950aa30a] disk not present in database
The second disc of the same album gets ..
[AccurateRip ID: 0012977b-008905ae-7c0cae09] found.
Track   [  CRC   |   V2   ] Status
01     [c891f0fe|8a93a5cc] (13+09/22) Accurately ripped
02     [e45513dc|724fb581] (13+09/22) Accurately ripped
03     [0fcc2d63|8bdfdc70] (12+09/21) Accurately ripped
04     [0af943ec|9e9bcfb8] (12+09/21) Accurately ripped
05     [8bb8e016|0ccec669] (12+09/21) Accurately ripped
06     [437724b8|aab180eb] (12+09/21) Accurately ripped
07     [7dcf3c26|ae215ef7] (12+09/21) Accurately ripped
08     [ddba29dc|ca322744] (12+09/21) Accurately ripped
09     [544cda94|1e81f404] (12+09/21) Accurately ripped
Whats happening here?
Thanks for any help you can provide
Both questions.
korth
Thanks for the reply! Still a bit confused though
For the first question.. is it that the log file names match the ones in the cue? If so, how does it then match them with the flac files that have barely anything in common with them.
Anyone want to explain the 2nd like they where trying to explain it to their parents? lol
IMHO Cuetools cannot use such CUE sheet, so it determines track lengths using your FLAC files. So the information about pregaps etc. is lost and it cannot verify your disc.
[a href='index.php?showtopic=66233']development thread[/a].
Q1.
CUETools behaves differently depending on input.
  • IF you selected the CUE file for input, CUETools would have attempted to use the 'correct filenames' feature internally to find the files then used the CUE+EAC LOG1+file lengths to check AccurateRip. If unable to use the CUE, CUETools would have thrown an 'unable to locate audio files' error message.
  • IF you selected the audio files for input, CUETools would have ignored the CUE and EAC LOG files and just used the file lengths to check AccurateRip.
  • IF you selected the folder2 for input, CUETools would have attempted to use the CUE and EAC LOG files first, then use only the file lengths to check AccurateRip.
1 If present. If the EAC LOG file was misnamed or there was more than one, a popup window would appear to let you select the correct EAC LOG file.
2 Selecting the whole folder for input is a 'batch' mode (as is any Multiselect or Drag'n'drop). For best results in 'batch' modes, all file names should be correct in the CUE file and the EAC LOG file should have the same name as the CUE (CDImage.CUE, CDImage.LOG). Popup windows are disabled. CUETools will first attempt to process the CUE and EAC LOG files. IF unsucessful, it will move on to using just the file lengths to check AccurateRip.
Q2.
CDs in the AccurateRip database are identified by disc structure information located in TOC of the CD. If your LOG file contains a TOC section, this shows the original CD structure. If the first track doesn't start at zero, this indicates a disc PREGAP. If there are more tracks shown than audio tracks on the disc, this indicates the presence of a DATA track. Depending on what Input was used above and how CUETools reacted to that Input, information gathered was used to create a TOC structure of that Input. That TOC structure was then used to contact AccurateRip. If it differs from the original TOC structure, the disc isn't found.
korth
Thanks again for responding.
[a href=\'index.php?showtopic=66233\']development thread[/a].
Q1.
So for my old rips which have the original log/cues but have the file names changed... It's basically using the CUE+EAC LOG+file lengths to check AccurateRip. It makes sense but i still don't get how it knows which tracks to check for length hehe. Is there something in the flac container its looking at?
Q2.
The disc in question has all these things, the first track starts at zero, and there are not more tracks shown than audio tracks on the disc.. I think.. lol
Here's the log..
Exact Audio Copy V1.0 beta 3 from 29. August 2011
EAC extraction logfile from 24. March 2012, 21:33
Johann Sebastian Bach / Les Six Concertos Brandebourgeois - Savall (Disc 1)
Used drive  : TSSTcorpDVD+-RW TS-L633J  Adapter: 0  ID: 0
Read mode              : Secure
Utilize accurate stream : Yes
Defeat audio cache      : Yes
Make use of C2 pointers : No
Read offset correction                      : 6
Overread into Lead-In and Lead-Out          : No
Fill up missing offset samples with silence : Yes
Delete leading and trailing silent blocks  : No
Null samples used in CRC calculations      : Yes
Used interface                              : Native Win32 interface for Win NT & 2000
Gap handling                                : Appended to previous track
Used output format              : User Defined Encoder
Selected bitrate                : 128 kBit/s
Quality                        : High
Add ID3 tag                    : No
Command line compressor        : C:\Program Files (x86)\Exact Audio Copy\Flac\flac.exe
Additional command line options : took this out as it was making the post to wide
TOC of the extracted CD
    Track |  Start  |  Length  | Start sector | End sector
        1  |  0:00.00 |  4:00.42 |        0    |    18041
        2  |  4:00.42 |  4:10.50 |    18042    |    36841
        3  |  8:11.17 |  4:15.72 |    36842    |    56038
        4  | 12:27.14 |  8:44.60 |    56039    |    95398
        5  | 21:11.74 |  5:09.67 |    95399    |  118640
        6  | 26:21.66 |  4:23.62 |    118641    |  138427
        7  | 30:45.53 |  2:59.28 |    138428    |  151880
        8  | 33:45.06 |  5:41.57 |    151881    |  177512
        9  | 39:26.63 |  0:30.73 |    177513    |  179835
      10  | 39:57.61 |  5:25.70 |    179836    |  204280
Track  1
    Filename F:\J.S. Bach - 2010 - Brandenburg Concertos (Savall)\Disc 1\01 - (Concerto No. 1 en fa majeur BWV1046) (Allegro).wav
    Pre-gap length  0:00:02.00
    Peak level 87.0 %
    Extraction speed 3.0 X
    Track quality 100.0 %
    Test CRC 7CE492D0
    Copy CRC 7CE492D0
    Copy OK
Track  2
    Filename F:\J.S. Bach - 2010 - Brandenburg Concertos (Savall)\Disc 1\02 - Adagio.wav
    Pre-gap length  0:00:04.29
    Peak level 51.8 %
    Extraction speed 2.7 X
    Track quality 99.9 %
    Test CRC 831591A9
    Copy CRC 831591A9
    Accurately ripped (confidence 9)  [7BB1CFF1]  (AR v2)
    Copy OK
Track  3
    Filename F:\J.S. Bach - 2010 - Brandenburg Concertos (Savall)\Disc 1\03 - Allegro.wav
    Peak level 82.9 %
    Extraction speed 2.9 X
    Test CRC FF6728A5
    Copy CRC FF6728A5
    Accurately ripped (confidence 9)  [30CCEAA9]  (AR v2)
    Copy OK
Track  4
    Filename F:\J.S. Bach - 2010 - Brandenburg Concertos (Savall)\Disc 1\04 - took this out as it was making the post to wide
    Pre-gap length  0:00:02.45
    Peak level 81.5 %
    Extraction speed 4.1 X
    Test CRC E5E29E3D
    Copy CRC E5E29E3D
    Accurately ripped (confidence 9)  [1890C955]  (AR v2)
    Copy OK
Track  5
    Filename F:\J.S. Bach - 2010 - Brandenburg Concertos (Savall)\Disc 1\05 - (Concerto No. 2 en fa majeur BWV1047) (Allegro).wav
    Pre-gap length  0:00:09.10
    Peak level 74.3 %
    Extraction speed 4.2 X
    Test CRC DA1E7E04
    Copy CRC DA1E7E04
    Accurately ripped (confidence 9)  [A7E5BE5F]  (AR v2)
    Copy OK
Track  6
    Filename F:\J.S. Bach - 2010 - Brandenburg Concertos (Savall)\Disc 1\06 - Andante.wav
    Pre-gap length  0:00:02.54
    Peak level 59.9 %
    Extraction speed 4.4 X
    Test CRC D3A5A4B6
    Copy CRC D3A5A4B6
    Accurately ripped (confidence 9)  [5DF72B93]  (AR v2)
    Copy OK
Track  7
    Filename F:\J.S. Bach - 2010 - Brandenburg Concertos (Savall)\Disc 1\07 - Allegro assai.wav
    Peak level 71.3 %
    Extraction speed 4.3 X
    Test CRC C6EAD02E
    Copy CRC C6EAD02E
    Accurately ripped (confidence 9)  [43835F37]  (AR v2)
    Copy OK
Track  8
    Filename F:\J.S. Bach - 2010 - Brandenburg Concertos (Savall)\Disc 1\08 - (Concerto No. 3 en sol majeur BWV1048) (Allegro).wav
    Pre-gap length  0:00:11.74
    Peak level 89.2 %
    Extraction speed 4.8 X
    Test CRC E5D2FF23
    Copy CRC E5D2FF23
    Accurately ripped (confidence 9)  [94F97D60]  (AR v2)
    Copy OK
Track  9
    Filename F:\J.S. Bach - 2010 - Brandenburg Concertos (Savall)\Disc 1\09 - Adagio.wav
    Peak level 30.3 %
    Extraction speed 2.4 X
    Test CRC D2384E33
    Copy CRC D2384E33
    Accurately ripped (confidence 9)  [FB9E702E]  (AR v2)
    Copy OK
Track 10
    Filename F:\J.S. Bach - 2010 - Brandenburg Concertos (Savall)\Disc 1\10 - Allegro.wav
    Peak level 83.9 %
    Extraction speed 5.0 X
    Test CRC 1D63B113
    Copy CRC 1D63B113
    Accurately ripped (confidence 9)  [B28C2508]  (AR v2)
    Copy OK
All tracks accurately ripped
No errors occurred
End of status report
==== Log checksum 52E9E22FD0D4E34B9497E82F713A2F8D0E358AFF452A70CDE657E5783123D918 ====
And here is it's cue
REM GENRE Concerto
REM DATE 2010
REM DISCID 950AA30A
REM COMMENT "ExactAudioCopy v1.0b3"
PERFORMER "Johann Sebastian Bach"
TITLE "Les Six Concertos Brandebourgeois - Savall (Disc 1)"
FILE "01 - (Concerto No. 1 en fa majeur BWV1046) (Allegro).wav" WAVE
  TRACK 01 AUDIO
    TITLE "(Concerto No. 1 en fa majeur BWV1046) (Allegro)"
    INDEX 01 00:00:00
  TRACK 02 AUDIO
    TITLE "Adagio"
    INDEX 00 03:56:20
FILE "02 - Adagio.wav" WAVE
    INDEX 01 00:00:00
FILE "03 - Allegro.wav" WAVE
  TRACK 03 AUDIO
    TITLE "Allegro"
    INDEX 01 00:00:00
  TRACK 04 AUDIO
    TITLE "Menuet - Trio I - Menuet da capo - Polacca - Menuet da capo - Trio II - Menue..."
    INDEX 00 04:13:38
FILE "04 - Menuet - Trio I - Menuet da capo - Polacca - Menuet da capo - Trio II - Menuet da capo.wav" WAVE
    INDEX 01 00:00:00
  TRACK 05 AUDIO
    TITLE "(Concerto No. 2 en fa majeur BWV1047) (Allegro)"
    INDEX 00 08:35:52
FILE "05 - (Concerto No. 2 en fa majeur BWV1047) (Allegro).wav" WAVE
    INDEX 01 00:00:00
  TRACK 06 AUDIO
    TITLE "Andante"
    INDEX 00 05:07:26
FILE "06 - Andante.wav" WAVE
    INDEX 01 00:00:00
FILE "07 - Allegro assai.wav" WAVE
  TRACK 07 AUDIO
    TITLE "Allegro assai"
    INDEX 01 00:00:00
  TRACK 08 AUDIO
    TITLE "(Concerto No. 3 en sol majeur BWV1048) (Allegro)"
    INDEX 00 02:47:47
FILE "08 - (Concerto No. 3 en sol majeur BWV1048) (Allegro).wav" WAVE
    INDEX 01 00:00:00
FILE "09 - Adagio.wav" WAVE
  TRACK 09 AUDIO
    TITLE "Adagio"
    INDEX 01 00:00:00
FILE "10 - Allegro.wav" WAVE
  TRACK 10 AUDIO
    TITLE "Allegro"
    INDEX 01 00:00:00
Does the fact that its a rip of the redbook layer of an SACD matter? I Still think its weird that it's "Accurately ripped (confidence 9)" according to the log but not CUETools *shrugs*
I know you're new to the forum. Please avoid unnecessary full quoting.
CUETools can read the metatags (if any).
I imagine it's possible the AccuratRip record was somehow lost. If I did my math correctly, the TOC in the EAC LOG you provided calculates out to the same AccurateRip ID: 0011f546-008f3ae0-950aa30a. You can verify that the TOC calculated by CUETools matches the one in the log by setting 'Create TOC files = True'. If you verify the files again, a .TOC file will be created (readable in notepad). The location of the file depends on your settings. If 'In source folder' is checked, the file will be written to the source folder. If not checked, it will be written to the Output location.
korth
Generated .toc file seems to match eac log *shrugs* lol
Id try ripping it again but i cant seem to find the disc  *sigh*
