Topic: M-Audio Delta 10/10LT (Read 3209 times) previous topic - next topic
Hi there I'm setting up a home studio and my Pc is to be there at the centre. I would like a high quality sound card with multiple i/o's.
I have seen the M-Audio 10/10LT which sound pretty cool does anyone have one of these and if so is it any good? I presume it is.
I would go for the 24/99 audiophile but it only has 2 analog inputs
What other cards would you suggest?
Spence
I would like between 6 and 10 inputs to record my band setup.
My buget is about £300.
Do you know anything about the 10/10?
Spence
Oh and thanks for the info on the other cards.
I've had a look, not heard of either previously. They both could do the job.
Don't know too much about the 10/10, but was going to buy a 10/10LT. In the end got a 410 since I didn't need all the inputs.
One thing to be aware of is that the 10/10LT is closer to the 410 in terms of spec (SNR etc) than it is to a full 10/10. I don't think the 10/10LT has balanced inputs/outputs which could be of concern depending on what you are connecting it to.
I've seen the 10/10LT for about £300 in the UK, but can't remember where. A google search should come up with something.
From a quality perspective, I think the RME is better (purely subjective comment based on the spec) but it will end up costing more by the time you add on the I/O board for more inputs. You may still be able to pick up one of the older RME cards and I/O board for your budget.
- Audio Spyder
