Topic: .ac3 and .dts (Read 8350 times) previous topic - next topic
.ac3 and .dts
How will be the structure of files with extention .ac3 , .dts , .dtshd?
How is the Metadata (artist , trach, album) stored in these formats?
are there any special container formats for .ac3 and .dts?
I found information telling about dolby digital .....
I need overview on these audio formats Pls
Regards
.ac3 and .dts
I think they're just raw compressed audio streams.  I don't think either is widely tagged, although its possible something out there can stick ID3 tags on them.
.ac3 and .dts
if they're just raw compressed audio streams , i have doubt as following
there are different dolby digital or dts audio techiniques like dolby digital plus, dts-es, dts-master audioHD ...
how will we know that the content in side the audio file.
How different are these audio formats?
.ac3 and .dts
May I suggest doing some simple web searches? For relatively non-technical comparisons of AC-3 and DTS, try searching for "ac-3 dts comparison".
For technical details about each of the formats, here is what I did:
1. I searched for "AC-3" in Google.
2. I clicked on one of the top results: the Wikipedia article on Dolby Digital.
3. I skimmed the article and noticed at the bottom there was a link to the standard. I clicked on it. I arrived at a site that had a PDF of the standard.
As for DTS, that standard is not available for free. However, with a search for "open-source DTS decoder", you can find open-source DTS (and AC-3!) decoder software which you could study and learn from. e.g. libdts, libdca, and AC3Filter.
.ac3 and .dts
I don't think you do until you decode it.  But no one uses raw streams so its not an issue.  They're always in some other container.
Rather different.  AC3 is a conventional if extremely primitive MDCT encoder like AAC or Vorbis.  DTS is a subband coder like MP2 or MPC.  DTS-AudioHD or whatever they call it is (IIRC) a hybrid lossy/lossless codec more like wavpack.
.ac3 and .dts
as bitstreams, according to the spec
it's not
there are other containers which often contain them, like AVI, MPEG-2 Transport Stream, MPEG-2 Program Stream, Matroska, MP4 (as private streams) and WAV/AIFF, amongst many many others.  These container formats can contain many other things, also.
.ac3 and .dts
A possible solution is to mux AC3 or DTS into Matroska. Good audio players should be able to handle MKV/MKA and read metadata from these files.
