Topic: [CUI]Artwork with Jewel Case? (Read 4274 times) previous topic - next topic
Is it possible to make the artwork have like, a jewel case look to it? Like add the spine and the reflection of the plastic cover? I've included a little mockup that i made, it just doesnt include the gloss (i couldn't figure it out in ps)
I think you can do it using Panel Stack Splitter, and exploiting the "forced layout" feature, to stack one panel (the jewel case png picture with transparency) on top of another (the actual cover).
edit: not sure whether PPS requires Columns UI to work, though
It's pretty easy to do in panelstack, the hardest part really is making the case in photoshop. you can use a semi transparent circle for the gloss.
spine_w is the width of the cd spine, disc.png is the cd case.
$puts(spine_w,20)
$imageabs($get(spine_w),0,$sub(%_width%$get(spine_w)),%_height%,%path%,artreader nokeepaspect)
$imageabs(0,0,%_width%,%_height%,path\to\disc.png,nokeepaspect)
huh. Thanks for the help!
How can I get this to work? I want to display the album art in a jewel case.
Where is the forced layout feature. Where do I put that code?
Thanks !
marc2003 already has a script that requires wsh panel mod and that will show albumart in a jewel case
http://dl.dropbox.com/u/22801321/samples.zip
There are some other excellent samples as well
PLEASE ENSURE THAT YOU FOLLOW VERY CARFEULLY THE INSTRUCTIONS IN THE SAMPLES README.PDF THAT COMES WITH THE DOWNLOAD
For more support see this thread
http://www.hydrogenaudio.org/forums/index....st&p=767799
Many thanks....got it to work. Just asking the author if the same can be done for the rear artwork
