Topic: Report on Creek OBH-11 headphone amp (Read 2815 times) previous topic - next topic
I received the Creek OBH-11 (standard, non-SE) headphone amp yesterday, and just did a few tests with nothing connected to it, and the headphone out going to the analog line inputs on my Audiophile 24/96 card.
Lowest volume on the pot (volume knob):
   Left   Right
Min Sample Value:   -13.73   -13.61
Max Sample Value:   17.24   16.63
Peak Amplitude:   -65.57 dB   -65.88 dB
Possibly Clipped:   0   0
DC Offset:   0    0
Minimum RMS Power:   -95.38 dB   -94.9 dB
Maximum RMS Power:   -67.02 dB   -67.14 dB
Average RMS Power:   -77.86 dB   -77.92 dB
Total RMS Power:   -76.31 dB   -76.37 dB
Using RMS Window of 50 ms
Highest volume on the pot:
   Left   Right
Min Sample Value:   -14.24   -13.68
Max Sample Value:   17.79   17.8
Peak Amplitude:   -65.36 dB   -65.35 dB
DC Offset:   0    0
Minimum RMS Power:   -89.14 dB   -88.66 dB
Maximum RMS Power:   -67.5 dB   -67.73 dB
Average RMS Power:   -78.04 dB   -78.04 dB
Total RMS Power:   -76.87 dB   -76.88 dB
Pretty good!  There seems to be no significant noise added when increasing volume to maximum (or anywhere in between) with no source connected.  I'm guessing that using a linear regulated wall wart [AC adapter] would diminish those low level amplitude fluctuations, unless it's from RFI -- perhaps a choke on the wall wart cable could help with that.
Adding a low-level source, the volume increases smoothly and gradually as it should.
P.S. the amp sounds pretty good, too.
A more realistic measurement would have some low impedance source (the AP outputs or a 200 ohm resistor) connected to the amp inputs. "Free" inputs may be noiser that the real thing.
What seems interesting is that Creek gives a S/N ratio of 65dB in their literature, which corresponds almost exactly to my measurement (if you figure -65dB peaks).  It seems Creek was being conservative and/or accurate in reported measurements, which is refreshing in a "high end" audio company  .
