Topic: EQ - Equalizer (Read 4152 times) previous topic - next topic
EQ - Equalizer
I was trying to find a panel EQ but i couldn`t  find it , i thought that at one point somebody made the plugin for it  , i guess the developer stoped making it . does anybody knows anything about this or anybody that can point me in the wright direction please . thank you ...
EQ - Equalizer
It's a panel in the default UI. Maybe you have to activate the DSP equalizer first before you can use it. In create scratchbox or enable layout editing mode you can choose the equalizer to view it inside a panel of choice.
EQ - Equalizer
It's a panel an element in the default UI. Maybe you have to activate the DSP equalizer first before you can use it. In create scratchbox or enable layout editing mode you can choose the equalizer to view it inside a panel of choice.
EQ - Equalizer
 I work at a helpdesk. Am used to call things people call them, otherwise it's uhh what?
The panel equalizer, when enabled as DSP, is also available in the View-menu.
EQ - Equalizer
thanks mar2zz but you know what i dont  know how to do that. in the menu one i know but i dont like it that way , i  want something that i can set up on my config. you know what i mean boss...
