Topic: Program to rename files from a txt file. (Read 4355 times) previous topic - next topic
Is there a program, for windows, that will rename a bunch of files with information contained in a text file.
I realize that, with Linux, it is very easy to so this with a "3 line" shell script, but I don't have Linux installed and I don't feel like writing a "3 page" Java program with windows.
Why not use something simpler then, like Python.
You could easily do something like this with Python in relatively few lines.
By the way, this has nothing to do with audio so I've moved it to the off-topic section.
Or even easier you could do it with a batch file
FOR /F "tokens=1,2 delims='='" %%i in (textfile.txt) DO MOVE %%i %%j
Just 1 line needed, this presumes that the format of the text file is
oldname=newname
oldname=newname
Hmmm... tried that, got "Syntax error"!
Win98. Changed "textfile.txt" to match the file I was using. Otherwise my batch file was exactly as above.
Alan
Which OS you using?
This only works in NT-based OSes
-Eugene
The  greatest  programming  project of all took six days;  on the seventh  day  the  programmer  rested.  We've been trying to debug the !@#$%&* thing ever since. Moral: design before you implement.
Win98 (as I said above). More to the point which OS should I be using?
Edit: Thanks Eugene, your reply wasn't there when I first re-opened this page.
Alan
Alan
You might want to get 4DOS then. But the syntax is different, IIRC.
-Eugene
[deleted]
