Topic: Columns UI (Read 4577485 times) previous topic - next topic
Columns UI
Reply #5150
I seem to have ran into some trouble with the Artwork View:
I have tried setting Displayed Track to "Automatic (current selection/playing item)" and "Automatic (playlist selection/playing item)" but neither is following my current selection.  However, just setting it to "Current Selection" works as expected.  Am I misunderstanding "Automatic (current selection/playing item)" -- I'm interpreting it to be show the artwork for whatever item I have currently selected otherwise show the artwork for my currently playing item.
If there's an item playing, it automatically displays corresponding album art, if not it shows either "current selection" (any selected item in whatever panel) or "playlist selection" (selected item in playlist, nowhere else)
fb2k on OSX: flac q8 > rockboxed Sansa e280v1: Vorbis q5.0
Columns UI
Reply #5151
Would it be possible to add an variable to grouping patterns returning count of grouped elements?
Columns UI
Reply #5153
Sorry, missed that. Still - we know it's not possible atm, but I was asking about possibility of implementing it (-;
Columns UI
Reply #5154
hi. is it possible to replace the filters from columns ui through the filters from facets?
greets
Columns UI
Reply #5155
Facets its for the Default UI and not for Columns UI
Columns UI
Reply #5156
i know but is there a way to get a similiar solution to this problem?
the filters in the CUI don't have a good search system, but in the default UI the tracks are played which i select. (which i actually don't want)
Columns UI
Reply #5157
So I'm guessing if I want only the current selection to show (regardless of if any item is being played), I cannot select either of the Automatic but rather "Current Selection" and turn on "Cursor follows Playback" ?
Thanks for your help!
Columns UI
Reply #5158
See the Columns UI wiki for a list of requests and feature suggestions. It's listed there below NG Playlist.
While I'm at it: Is it planned to have the ability to disable the album art for certain groups? I'm thinking of displaying album art only if the number of items in the group is equal %totaltracks%. This would be extremely useful for playlists with full albums and single tracks mixed. It would also be possible to display album art only for albums which have more tracks than just two or three. Saves space.
Columns UI
Reply #5159
An option to change the vertical padding of the group headers would be very useful.
Columns UI
Reply #5160
@andrea.ippo
By default incoming files will be path sorted, so i guess your files are named without a tracknumber at the beginning. They are alphabetically in their folders?
If you don't want to rename your files, go to: Preferences-->General "Sort incoming files by" and type %album artist% %date% %album% %tracknumber%
That should do the job next time you'll add files to your playlists
Oh, and the grouping in NG Playlist:
I have set it up as
[$upper(%album artist%)][ $char(8226) %album%] and it works here.
EDIT: typo
what about artists that begin with "the"? i dont want them in with the artists that begin with "t" if you know what i mean
Columns UI
Reply #5161
[$stripprefix($upper(%album artist%))][ $char(8226) %album%]
to remove the "The" (and an "A", too) or
[$swapprefix($upper(%album artist%))][ $char(8226) %album%]
if you want to keep the "The" (and an "A") after a comma at the end of the artists name.
The same for sorting the incoming files:
$stripprefix(%album artist%) %date% %album% %tracknumber%
or
$swapprefix(%album artist%) %date% %album% %tracknumber%
Columns UI
Reply #5162
or
thanks
so itd be
[$stripprefix($upper(%album artist%))] - %DATE% - [ $char(8226) %album%] - %DISCNUMBER% - %TRACKNUMBER% - %TITLE%
? also once ive done that, how do i have it sort that way by default?
Columns UI
Reply #5163
It sorts automatically all incoming files if you paste this string into "Preferences --> General --> Sort incoming files by".
For already existing playlists i advice to select all files, right-click in the playlist and choose "Sort --> Sort by...", than copy and paste this string into the box.
Columns UI
Reply #5164
@musicmusic:
I don't know if this is a bug, but in the earlier builds you could "search" (just type a letter) in the filter panels without open the search box
maybe you could readd this feature?
take care
Chris-
Columns UI
Reply #5165
Is it possible to hide taskbar entry with columnsUI or possible to add the feature?
Columns UI
Reply #5167
Damn that sucks I don't want foobar cluttering my taskbar suppose I can just tolerate it till win7.
Columns UI
Reply #5168
Why don't you want to have a taskbar button when foobar2000 is open anyways? If you want it hidden, just minimize foobar2000. This is standard acceptable behavior on Windows. All top level windows deserve a taskbar button.
Blame it on the taskbar instead, but don't you ever blame it on applications that your taskbar is "cluttered".
And yes, Windows 7's taskbar is a lot less cluttered. Finally MS fixed it.
Columns UI
Reply #5169
There are 3rd party tools that allows you to hide it.  Also you can minimize it to the System Tray (Minimize to Tray).
I'm assuming [Start Menu === Task Bar ===== System Tray = Clock].
This is probably one of the many utilities that can hide it for you.  I have used this before and it was relatively simple though not as straightforward.
Columns UI
Reply #5170
Calm down mate i'm not blaming the applications, the taskbar should have these options yes. As I have foobar on the desktop and visible all the time I don't need it to be on the taskbar.
Netvets that tool looks useful but i'm on x64 so it won't work.
Columns UI
Reply #5171
Maybe just a (setting for the) minimum number of tracks in a group before displayed the art.
I didn't change anything, but it seems it was broken if there was a colour code in the way. I will fix that, thanks.
Columns UI
Reply #5172
Lifehacker mentions an application you can look at.  I somewhat doubt it'll work on x64 but it's worth a look.  This seems to minimize to tray which is already available with Columns UI but minimizes them all to one spot.  Maybe this can work (similar to CMDOW but more recent).  Hopefully these helped.
Columns UI
Reply #5173
I'm having a problem mixing bitmap and PNG button icons.
If I set a png as an icon after (lower in the list than) some bitmaps then all the bitmaps display as the png file:
If it comes before they are blank (stop has no associated image):
I've downloaded the latest zlib/pnglib from the columns website.
Core (2009-02-25 17:28:28)
    foobar2000 core 0.9.6.3
foo_abx.dll (2008-05-24 15:23:50)
    ABX Comparator 1.3.3
foo_albumlist.dll (2009-02-23 23:06:48)
    Album List 4.3
foo_audioscrobbler.dll (2008-03-09 19:08:00)
    Audioscrobbler 1.3.16
foo_bubble_coverflow.dll (2008-01-20 03:13:00)
    Cover Flow 0.1
foo_cdda.dll (2009-02-23 23:06:42)
    CD Audio Decoder 2.1.4
foo_comserver2.dll (2006-07-31 19:13:20)
    COM Automation server 0.7 alpha 6
foo_converter.dll (2009-02-23 23:06:38)
    Converter 1.2
foo_dsp_std.dll (2009-02-23 23:07:00)
    Standard DSP Array 1.0
foo_dumb.dll (2006-05-18 18:12:00)
    DUMB module decoder 0.9.7.1
foo_fileops.dll (2009-02-23 23:06:12)
    File Operations 2.1.1
foo_freedb2.dll (2009-02-23 23:07:04)
    freedb Tagger 0.6.1
foo_input_shorten.dll (2006-03-11 18:25:13)
    Shorten decoder 0.4.2a
foo_input_std.dll (2009-02-23 23:07:38)
    Standard Input Array 1.0
foo_jesus.dll (2009-01-09 20:41:00)
    Autosave 0.0.2
foo_lastfm_radio.dll (2009-02-25 22:05:00)
    Last.fm Radio 0.5.6b
foo_lnk.dll (2006-04-29 18:15:23)
    Shell Link Resolver 1.2
foo_lyricsdb.dll (2006-07-19 22:45:00)
    foo_lyricsdb 0.0.7 beta 4
foo_masstag.dll (2008-11-29 20:46:00)
    Masstagger 1.7.1
foo_msnalt.dll (2008-11-29 14:50:00)
    MSN Now Playing (alt) 2.4
foo_osd.dll (2006-02-28 14:08:00)
    On-Screen Display GDI+ 1.52
foo_playcount.dll (2008-10-29 13:26:00)
    Playback Statistics 2.1.6
foo_pqview.dll (2006-03-12 23:23:29)
foo_quicktag.dll (2008-05-01 18:39:00)
    Quick Tagger 1.0.1
foo_rgscan.dll (2009-02-23 23:06:40)
    ReplayGain Scanner 2.0.8
foo_run.dll (2008-01-17 20:32:00)
    Run services 0.3.4
foo_ui_columns.dll (2009-02-21 23:42:02)
    Columns UI 0.3.6.7
foo_ui_std.dll (2009-02-23 23:06:56)
    Default User Interface 0.9.5
foo_uie_albumart.dll (2007-12-16 00:22:00)
    Album Art Panel 0.2.7.1
foo_uie_albumlist.dll (2008-09-24 19:29:01)
    Album list panel 0.3.2
foo_uie_graphical_browser.dll (2008-03-10 10:59:02)
    Graphical Browser rev011
foo_uie_lyrics.dll (2008-12-12 09:39:20)
    Lyric Show Panel 0.3.3.9 [Dec 12 2008 - 17:39:01]
foo_uie_lyrics_panel.dll (2007-08-17 22:56:00)
    Lyrics panel 0.35
foo_uie_tabs.dll (2006-10-17 21:54:00)
    Tabbed panel modified 0.2.5
foo_uie_trackinfo.dll (2008-11-01 13:24:00)
    Track info panel 0.8
foo_uie_vis_channel_spectrum.dll (2007-08-29 21:55:00)
    Channel Spectrum panel 0.07
foo_uie_vis_egoh.dll (2007-01-13 05:20:00)
    Egoh Spectrum analyser (uie) 1.1.0
foo_upnp.dll (2009-02-25 23:29:25)
    UPnP/DLNA Media Server and Browser 0.91
foo_winamp_ipc.dll (2007-11-03 03:49:00)
    Winamp IPC emulator 0.1.0
Columns UI
Reply #5174
Yes slightly odd behaviour.. but it's probably something to do with them not being the same dimensions. Default buttons are 16x16 now.
