Topic: fmod wav (Read 3296 times) previous topic - next topic
fmod wav
Hi i have some waves created with fmod  www.fmod.org (fsb) but i cant' play it with a normal player, i knows ( think) it's a wav ima apdcm headerless.
Somebody knows how to reconvert or any program to wav pcm 16?
My knowledegments in programation it's closed to 0.
fmod wav
Never tested, but foobar 0.9 with foo_adpcm sounds like an option.  That component should let you load the file into foobar, at which point you can use Converter to create a 16 bit PCM WAVE, or other format.
kode54's foo_adpcm for foobar 0.8.3 can be found here.
I'm on a horse.
fmod wav
[{POST_SNAPBACK}][/a]
thanks but give me "Could not load info (Unsupported format or corrupted file) from:test1.wav"
Here the sample:
[a href="http://rapidshare.de/files/14092462/test1.wav.html]http://rapidshare.de/files/14092462/test1.wav.html[/url]
Somebody knows how convert to wav pcm?
