Topic: Is -production working in Psytel AACenc 2.x? (Read 3438 times) previous topic - next topic
When I use *-production -br 128 -c 15995* it results in:
in:  44100 Hz, 2 Channel(s)
out: 44100 Hz, CBR 128000 bits/s (AAC Profile: Low Complexity)
Cut-off frequency: 15995 Hz
There is basically no speed difference between using -production and not using it.  aacenc 2.1 @ around 2.0-2.8x on my Athlon 1000mhz.
Now if I go back to one of the older encoders I get:
out: 44100 Hz, CBR 128000 bits/s (Codec Type: Professional/Slow)
out: 44100 Hz, CBR 128000 bits/s (Codec Type: Consumer/Fast)
The Consumer/Fast being twice the speed as the Professional.  2x vs 1x.
Is -production working in the 2.x encoders?
You can't kill the Elephant.
Indeed... here, I got quite a speed boost when changing from 1.5 -production to 2.0 -production
I thought it was because if internal code tweaks for velocity.
Hum... Thanks for the info, JohnV.
So, is -production switch obsolete? Or should it still be used for CBR encodings?
