Topic: Error when creating new playlist tab (Read 2405 times) previous topic - next topic
Something strange with radio webcast. What I do:
1 - open foobar2000 directly to my "radio" playlist tab.
2 - create a new playlist tab.
3 - launch one of the web broadcast radio stations.
4 - go to the new playlist tab that's just been created.
I do these operations in the order 1-2-3-4 or 1-3-2-4. At step 4, foobar2000 freezes and I get that message. Other times no error message is displayed. And just one "failure.txt" file is created. But other times 360 "failure.txt" files are created.
failure.txt (when there is only one that's created):
Illegal operation:
Code: C0000005h, flags: 00000000h, address: 784AB3AFh
Access violation, operation: write, address: 00000005h
Additional info: main message loop
Code bytes:
784AB38Fh:  87 52 16 00 00 80 7D 14 00 0F 85 6A 37 00 00 57
784AB39Fh:  53 E8 95 E1 FB FF 8B 4F 0C 8B 47 08 3B C1 89 01
784AB3AFh:  89 48 04 74 4D 8A 47 05 A8 04 0F 85 21 FD FF FF
784AB3BFh:  8A 46 05 24 10 A8 10 88 47 05 0F 85 CB 17 00 00
Version info:
foobar2000 v0.7.2 beta 8
UNICODE
When 360 "failure.txt" files are created: all the files are in this zip file.
- W2kSP4 with fb2k beta 8.
- The links I include may work badly, sorry for that.
similer thing here:
ERROR (CORE) : playlist_switcher_callback failure
when removing tabs,
to reproduce, create two new empty tabs
close fb2k
you may get these two errors
Illegal operation:
Code: C0000005h, flags: 00000000h, address: 77F58D2Ch
Access violation, operation: write, address: 00000000h
Module: "ntdll", loaded at 77F50000h - 77FF7000h
Symbol: "RtlFreeHeap" (+000002EEh)
Additional info: main thread root filter
Code bytes:
77F58D0Ch:  8D 84 38 58 01 00 00 33 C9 8A 08 0B CA 88 08 8D
77F58D1Ch:  46 08 89 45 A0 8B 4B 04 89 4D 9C 89 18 89 48 04
77F58D2Ch:  89 01 89 43 04 8B 45 CC 01 47 28 E9 4F 01 00 00
77F58D3Ch:  3B 47 20 72 0A 8B 4F 28 03 C8 3B 4F 24 73 27 8B
Version info:
UNICODE
Illegal operation:
Code: C0000005h, flags: 00000010h, address: 77F58D2Ch
This is your 2-nd crash. When reporting the problem to a developer, please try to post info about the first crash instead.
Code bytes:
Version info:
UNICODE
then open fb2k again.
right click the two new empty playlists (last one first) and choose remove
you get
havent tried on completely clean install yet.
Try removing foo_shuffle.
yes, thank you, that fixed my problems.
I will investigate later, and pray for a playback list that operates independent of the visible playlist, so I don't have to track playlist switches. (Unless multiple history sets are a must.)
